Question about Toshiba 51H93 51" Rear Projection HDTV
Tv struck by lightning
Tv will not turn on. reset doesn't move. no power is displayed going into the unit.
  • CBOhlson Dec 28, 2007
    Similar problem with our Toshiba. Power surge apparently cooked power supply unit, estimate for repair is $350 from a shop here in San Diego. Doesn't that seem a bit high? How much could the power supply cost? Could it be replaced/repaired by a novice (me)?
    Thanks,
    Bill
    President:
  • 3,130 Answers
This set is pretty common for the regulator IC to go bad. Its inside on the power supply Printed circuit boad assy. It will start with STR#### and have 4 digits after the STR####, depending on the model of the set. Good Luck
Posted on Jun 03, 2006
  • Larry  Dillon
    Larry Dillon Jun 10, 2006
    But if your not a tech BEE carefull as this set is loaded with Hi Voltage.
TV turning off and on and stays black
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here
Jun 22, 2016 | Panasonic Televison & Video
My laptop struck by the lightning. The power LED doesn't turn on, but the wi-fi LED turns on without power on, CPU fan starts as soon as i turn on the charger. But turning on power button has no...
Try to check if battery is removable. Remove all power source (battery and charger). Press power button for 10-20 seconds. Plug in with charger. Power on.
Sep 14, 2013 | Computers & Internet
ILO 42" flat screen I think was struck by lightening and now there is no color. Is there anything I can do to fix myself?
tried to reset the tv first, if struck by lightning the tuner will be damaged or the main board but since the tv is still working so i think not the lightning was the main cause.
Aug 30, 2012 | Televison & Video
Samsung tv lightning strike reset
It is likely the ac fuse which the power cord goes directly to got hit.
back would have to be removed and fuse checked.
Mar 18, 2012 | Samsung Televison & Video
Lightning struck my house last night, the tv is plugged into a surge protector. When I turn the tv on the screen is black. How do I reset the tv?
physically remove the power cable for about 10 mins then reconnect it no joke this is important
if it does not work the power supply is needing replaced
do you have cable or sky
Jun 26, 2010 | Hitachi 57F710 TV
I have a 58'' HP Pavillion Projection screen TV. It was struck by lightning. the power cord is good. It will not turn on at all, no fans running, etc. What do you think I will have to fix?
As u have just said that it was struck by lightning the only way to get the TV back working is to replace burnt items on the moterboard .becouse lightning must have demaged some components on the power supply, if possible i would preffer a new power supply board
Aug 31, 2009 | Televison & Video
NO POWER ON
Hi! your tv power supply is busted, you need to contact a qualified technician for repair.
Jul 27, 2009 | Televison & Video
Ilo TV,32", storm last night, lightning struck, pop,no TV.help?
Hello DJ,
I am sorry to say but it sounds like you had a major surge go through your tv. Go to this area: TV Repair man in your area
Find a repair place near you and have them check it out.
Jun 14, 2009 | iLO IWT3206 TV
Struck by lightning and won't power up
WOW!
Warranty voider there.
Hate to see a $1,000 TV go down the toilet.
If your lucky, you can try checking the fuses inside the TV.
The lightning may have taking out only your power supply board, shopjimmy.com may have replacements for about $100. But, I can't tell you for sure that will fix the problem.
You may have to take to a repair shop to find out for sure.
Good Luck
Feb 11, 2009 | Philips 47PFL3603D LCD TV
Broken TV in building hit by lightning
hi
depending on the intensity of the lightning strike.Your tv may have blown components in the power supply section of the motherboard.
unfortunately its very very difficult to acertain level of damage unless its looked at by a trained tech/engineer
cheers
Jun 16, 2008 | Televison & Video
Toshiba 51H93 51" Rear Projection HDTV Logo
184 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
