Question about Hoover Nextra HNT 2135 Top Load Washer
Water overflows. Water will not stop filling. empties OK. spins OK. does not agitate. tried water level control and reset control, doesn't seem to work.
  • 641 Answers
Water supply to the washer is done through an electromagnet valve,loocated at the pipe's enterance to the machine. A defect in the valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it, and the valve may leak and drip water into the tub.Test that it get power (with a multi- meter). In case it get power and dosen't work - You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from the machine before doing it !!!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace for a new valve. Good luck !!
Posted on Jun 04, 2006
General Electric Washing Machine want agitate. The washer fills, spins, drains but simply stops agitating or washing during different cycles. I have checked the lid switch, coupling under the agitator and...
The water level switch may be going bad. As the water level rises to the proper level, it switches a set of contacts inside to stop the water fill and cause the machine to start agitation. Make sure machine is empty before you replace the water level switch---it works off of air pressure from a small hose attached to it.
Feb 16, 2015 | General Electric Washing Machines
Frigidaire FWT647GHSO when it gets to rinse first rinse cycle, it doesn't stop filling with water. It won't agitate or spin. It works well in the wash cycle, agitates and spins and advances
probably you've got something blocking the water pump from doing its job properly so check that the water pump is free running emptying all the water if not then there is a blockage in the pump normally ist a button, paper clip or other debris out of a trouser pocket eric
Dec 25, 2017 | Frigidaire Washing Machines
Water fills to over flowing and never starts agitate or spin cycle
With the tub empty disconnect the air hose from the water level switch in the console. Blow through it to see if its kinked or restricted. Check the air bell for a buildup of **** especially near the opening where the air hose attaches.
If all is OK reattach the hose and disconnect it from the air bell. Turn your water off and set it to wash. Blow through the hose to see if the switch goes from fill to agitate.
Jan 03, 2012 | Maytag Performa PAV2200
The washer fills agitate but won't spin & drain
Possible fault with the program controller unit. You need to check the program cycle outputs using a multimeter connected to measure the output voltage. On start the inlet should open and then close as the water level sensors works and then proceed to wash. So this much seems OK. Now in the next step the drain valve must open to drain off, then fill once again with the inlet working and water level being sensed. If there is no output in this section cycle then the prrogram controller has errors within the memory . You can remove the panel and reset all connectors and connections.
Oct 30, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer will not spin or agitate Washer will fil and pump water out motor will not come on Have replaced the motor and the lid switch After replacing the motor the washer worked ok for about 4 or 5...
This is sounding like either a timer or a water level switch problem. I would elimnate the water level switch first. Here is why..... You had to tip the unit to change the motor. Tipping the unit would ensure that the small tube that runs from the bottom (side) of the wash tub to the water level control pressure switch cavitated. Once this is clear the water level control was for a while able to sense proper water levels and the diaphragm inside the pressure switch cycled normally. If the sens line had a pin hole in it or the water level control pressure switch contacts have a problem it will present the symptom you currently have.
I cheat.... I hook up an equal sized tube to the water level pressure switch and add pressure and release pressure orally to force the pressure switch to work. (Automotive vacuum line works like a charm!) If it works by physically forcing it to work then the timer is fine. The Pressure switch is probably ok also. The sense tube running from the presure switch to the tub would be the problem. With all water removed... (drain hose lowered too to empty the machine) tip the unit again. Then see if it will fill and agitate on a small load. Also check to see if it spins. IF it agitates and spins... the sense line if most likely the problem. (pin hole chaffed etc)
There is still a remote possibility of the Timer causing the problem OR the contacts inside the water level pressure switch as the problem. If you can find the tech data sheet inside the console there should be a wiring diagram. Check the water level control for power in and out both with water level reached and empty. If the contacts are working on the water level control pressure switch... your probably looking at the timer as the problem.
Thanks for choosing FixYa,
Kelly
Aug 31, 2011 | GE Profile WPRE6150KWT Colossal Capacity...
My GE WCSR4170D AWW top loading washing machine will not stop filling with water. i can get it to agitate when i blow into the air line hose attached to the water level switch. BUT it never stops filling...
Thanks for choosing FixYa and welcome. You probably have a bad water level switch. As for the agitation, the drive motor controls the agitation, spinning, and draining. It is possible for the machine to not agitate, but yet spin and drain. The motor runs clockwise and counterclockwise. It may be bad and if so, will need changed.
Apr 30, 2011 | General Electric WCSR4170D Top Load Washer
My masher wont stop filling with water or agitate
if water stops coming into machine when you pull the plug you have faulty water level control or the hose going to it.
check the hose for cracks or worn spots, repair or replace.
If the hose is ok you have a faulty control.
If water does not stop when you pull the plug you have a faulty water valve.
You can try dismanling it and cleaning or simply replace it.
Jul 03, 2009 | Whirlpool LSR5132PQ Top Load Washer
Agitator wont spin
Water level controls - The water level control is also know as a pressure switch, this is where you set the water level ( small - medium - large ). The water level control is responsible to shut off the power to the fill valve and direct that power to the timer so the washing machine can start up. The WLC has electrical contacts in it that sends power to the fill valve and when the WLC is satisfied the water level is correct the electrical contacts open power to the fill valve and send the power to the timer and the washer starts. Picture of this here. How the water level control knows when it is time to shut the water off is, a air tight hose runs from the outer washer tank to the water level control. As the water fills the outer tank air is pushed up the hose, depending on which setting you have made ( small- medium - large ) is takes a certain amount of this pressure to make the WLC cycle over and shut off the water and send this power to the timer. If this hose develops a leak or a pin hole the washer can over fill as the WLC may not be able to shut the water off. The water level control can also break down and allow the washer to over fill as well.
Testing a  water level control or a fill valve can be done by using a Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter. Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter. Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter.
A couple of tips from readers (Thankx!! ):
~ If you have a loose hose on the water level control or tank end, use a plastic wire tie to help hold the hose tighter and make a tight fit.
~ The water level tube (tube that runs from the square box), access panel on the outer drum where the bleach tube also ends) from the pressure sensor switch (front panel) can become clogged.  Or the two holes from the outer tub into this square box panel on the outside of the outer tub can become clogged. Either clog, I am told by my help repair guy can cause the sensor to think that there is still too much water in the tub and so will not allow motor to activate spin.
~ If the water level control contact is bad, it may also stop the filling ok, but not tell the washer to start agitating.
Maytag Dependable care washer.....Locate a 1/4 inch screw on the side of the agitator, ( about 3/4 of the way down) remove this screw and lift up on the agitator...picture.
Maytag Atlantis, Norge, Performa by Maytag.....Remove the cap and softener dispenser by pulling it off and locate the agitator bolt, remove bolt and lift up on the agitator...picture.
Nov 13, 2008 | Maytag PAV2300 Top Load Washer
Frigidaire stackable will not stop filling with water or agitate.
yes unless pressure switch(water level switch)detects proper fill level wash will never start agitating some washer will not spin if switch does not detect empty tub
Jun 02, 2008 | Whirlpool LTE6234D Top Load Stacked...
Hoover Nextra HNT 2135 Top Load Washer Logo
75 people viewed this question
Top Hoover Washing Machines Experts
shaun taylor
Hjalmer Lamminen
Hjalmer Lamminen
Steve F
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
