Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Headlight doesnt work 2000 Flstf
It was working on are last trip but then turned off. Bought a new headlight but nothing and even the light that appears for the bright when its on doesnt work. Is there a fuse that I can replace and if so were is it located????
  • 25 Answers
Common problem, remove headlight and look for a broken ground wire in side the housing the motor company grouded it to a rivet comon fix is to drill a bolt in to a descreat location and install 2 nuts to make a good ground stud
Posted on Nov 26, 2008
I have a 1995 ford mustang and im experiencing something kinda werid if i let the car sit for more than a couple of hours my dome light doesnt work when i open the door but i can pull the headlight switch...
If you have a light control module then that is probably failing. However if the dome light is activated by small switches in the door pillars it is possible that the contact points may be rusty or have a bad earth.
Dec 20, 2014 | 1995 Ford Mustang
Nissan pickup headlight
check the ground wires..
Dec 14, 2013 | Cars & Trucks
2000 s-10 blazer interior lights not working
Not working at all or not working when door is open or not working when the override on the headlight switch is rotated to turn them on? Either way check fuses door jamb switches and the last thing would be the headlight switch itself.
Dec 06, 2013 | 2000 Chevrolet Blazer
No power to warning and idicaters
The power to your warning and indicator lights is provide by the "lights" circuit breaker under the dash. This same circuit breaker provides power to your headlight. If your headlight is working, the circuit breaker is not tripped. I would suspect that the bulbs are either blown or have come "unplugged". Since each warning and indicator comes from a different location, it's doubtful that you have a short somewhere.
Good Luck
steve
Nov 10, 2010 | 1993 Harley Davidson FLSTF Fat boy
Bike is dead. battery ok. not even a headlight???
The fuses are probably behind the trianglular plate on the right side of the bike. It may be that the bike has a security system on it as well and something has tripped it preventing it from being started.
Jul 14, 2010 | 2000 Harley Davidson XL 1200 C Sportster...
Right headlight not working properly left headlight not working
You have a short in your electrical system or bad ECM.
Jul 05, 2009 | 2000 Pontiac Firebird
After turning ignition, only parking lights work. low beam headlights were replaced recently. parking lights wont even turn off. headlights
I had an S-70 with the same problem what happens is the headlight switch tabs that hol it together broke and the switch was slightly separated and connection was not there for the headlights and also check the high beam see if headlights come on i dont think it is a relay or fuse??? proballally the headlight switch and easy to replace you even can use one from an 850 model
May 17, 2009 | 2001 Volvo S80
Help with 1995 Caprice Classic Headlight Replacement
you turn the black harnes clock wise and then the light bulb and harnes shuld come out
Nov 12, 2008 | 1995 Chevrolet Caprice Classic
Lands Phones Logo
183 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
