Question about MSI nVidia GeForce 7600GS 256MB Dual DVI Fansink P Graphic Card
Tv out cables colour layuots
What are the colours of the tv out
Dvd plays black and white tv is colour
be sure to check all your input/output connections & cables
Nov 26, 2013 | Digihome LCD TV
How to connect samsung ps50c55og to sony dav s500 home theatre system
You need a set of normal rca cables (red.yellow,white) and another single rca cable..
OPTION 1 :If you have a digital satellite receiver, Connect the 3 colour cables to the corresponding colour jacks on VIDEO 2 of your dvd player to corresponding colour jacks on the VIDEO OUT Of your digital satellite receiver...Connect the single stand alone rca cable to MONITOR OUT on your player to the VIDEO IN input of your tv..
OPTION 2 STRAIGHT TO TV: connect the 3 colour cables directly to the corresponding colour jacks on the SIDE of the tv...Connect the single stand alone rca cable to MONITOR OUT on your player to the VIDEO IN input of your tv..
OPTION 3 IF YOUR PLAYER HAS AN OPTICAL INPUT: if this is the case you can just connect a single optical cable to the optical ports on your player and tv and this will enable the sound from your tv to play through your dvd player as well
Feb 12, 2013 | Audio Players & Recorders
Sony KLV32T400A LCD TV. Colour Problem With Black colour of hair showing blue. Other than that the TV is fine. What solution
Hello, Sounds like an LVDS Cable or T-con Board.
Usually this will slowly get worse until it is repaired. It is caused by a failing T-con (Control) Board or connecting cable. T-Con Will Need replacement. This picture show's more extreme T-con board failures
Feb 18, 2012 | Sony Televison & Video
Yellow tv colour tint
PLEASE CLERIFY ARE YOU USING COMPONENT CABLE OR COMPOSITE .DID YOU TRYED TO CONNECT TO DIFFERENT TV WAS IT FINE .
Dec 17, 2011 | Panasonic TX-32LM70 32 in. LCD TV TV/HD...
Component Input 1 & 2 gives black & white picture
You will need to connect all the cables for component to get a colour image.
The component cable has 3 connectors all for video. If you have connected only one cable for video then you will not get colour information. Component needs all 3 to get colour and luminence information. You can use a regular composite cable but you have make sure you match up the colour codes on both sides i.e to TV and to the source. The other two Red and White a separate cable is for Audio.
Y-> Green
Cb-> Blue
Cr-> Red
Jan 17, 2011 | LG 46LD550 46 in. LCD TV
Cable on TV suddenly went to black & white (and a bit fuzzy)(some channels show faint colour). Was fine, nothing was changed, one day was suddenly B&W. TV screen is not the problem, all other cable...
Was playing around with the TV's menu and changed the Tuning Band from "HRC cable" to "IRC cable". Suddenly I have colour again. No one had adjusted any of the controls, so still not sure why one day it was fine and the next day it had gone to black and white, but changing the Tuning Band fixed the colour problem for me.
Sep 13, 2009 | Televison & Video
I'm connecting my laptop to my plasma tv to watch
It sounds like the cable is faulty. I presume it is a VGA cable as these are prone to wires breaking inside and colours going missing. Try bending the cable around a bit esp. near the connectors and see if the colour flashes on and off as you do this. If so you might be able to temporarily fix it if you can find a position for the cable where the colours are all working and tape the cable in this position. It might also mean than a pin is missing in one of the connectors.
Either way, I reckon you are going to need a new cable.
Jul 18, 2009 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
The tv
could it be your cables to your tv? try it on a differant tv if not try someone elses cables if its neither of those you made need to get it repaired
Jun 22, 2008 | Microsoft Xbox 360 Console
Help
Not a home repair take it to a repair store.
May 24, 2007 | Apex Digital PF3230 32" TV
MSI nVidia GeForce 7600GS 256MB Dual DVI Fansink P Graphic Card Logo
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
