Question about Memorex MT1091 Television
TV won't come on
When I push the power button on the front of the television, all I hear is a double "click" coming from inside the tv. Then, nothing happens. Any suggestions???
  • 2 more comments
  • Anonymous Jan 25, 2008
    tv wont come on when i press the power button it makes a sound like itis coming on but it dont green light blinks and then a red light comes on which is the timer light
  • RA66 Mar 12, 2008
    The transformer (E190246 HF-41217L2TN) on my KCR210 is showing no output. Were can I get a replacement or a substitute? Do you know the voltage output?
  • Anonymous Jun 13, 2008
    i replaced one fuse i found the set turned on for about a week or more now it wont turn on ?
  • Anonymous Feb 18, 2009
    When i hit the remote power button or the button on the set, all i hear is a double click.
  • 513 Answers
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. This is probably a startup problem. It may be as simple as an open resistor that provides initial drive to the horizontal deflection. Check for power to the horizontal output transistor. If there is, check for drive. Could also be a bad flyback transformer. Another problem might be that the set is in high voltage shutdown, possibly due to a faulty voltage regulator. Check the regulated voltage going to the flyback primary (it should be marked on the circuit board what that voltage should be... 120V-140V in most TV's). If it is too low, the flyback transformer or one of its secondaries is probably loading down the primary input. If the voltage is too low, try disconnecting the secondaries. If the voltage remains too low, try disconnecting the primaries too. If the voltage is then normal, the flyback is bad. A REALLY bad flyback will also blow a fuse. don't leave the TV on too long with a shorted flyback, the h. output transistor can get too hot and probably fry, if it isn't fried already. If the primary voltage is too high, then the set is probably in high voltage shutdown, possibly caused by the voltage regulator. Good luck, and stay away from it if you haven't done this before. Take it to a lab if it's worth the repair.
Posted on Jun 05, 2006
Check the HOT
Posted on Aug 15, 2007
We had EXACTLY this same problem with our Naxa NX-518 combo TV-DVD. This WEIRD solution is what worked for us: My husband started to take the back of the TV off; took the four screws off, and as soon as he loosened the back, VOILA~! The TV came on! Magic! We think it might have something to do with pressure on top of the TV or something.
Posted on Sep 18, 2006
When I push the power button on the tv I hear a click and then another click but the tv won;t turn on. The white led on the front comes on momentarily the goes out. I have replaced the power suppy boa
sounds like a capacitor sometimes they look fine but don;t work. I had this problem in my lg replaced 3 caps and it fired up. caps are cheap.
Jan 23, 2015 | Televison & Video
I have a Sony NSX-40GT1 that won't power on. You can hear the relay click after plugging in, and the red power led comes on, but when you push the power button it does nothing. Any ideas?
I'm having the same problem. Can anyone help. If possible i'd like to fix it rather than go return it. It worked fine for a while and then suddenly started turning itself off. Now every time i turn it on it turns itself off.
Jun 12, 2011 | Sony Google TV NSX-40GT1 40 in. HDTV LCD...
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Tv will not turn on
its a clicking of switching relay. cannot power on due to power supply failure.
May 30, 2009 | Sony KP-48S70 48" Rear Projection...
TV will not turn on.
hello..i think you have very big problems inside on you're TV you need a Electronics Technician to see inside the real problem.my tips is located in Power Supply Regulator..Can i know what kind TV Model???thanks
Apr 23, 2009 | Televison & Video
TV will not Turn On.
same thing,tv won,t come on,unplug the tv, nothing at all,just yesterday my tv was fine, this is the first time this has ever happen
Mar 13, 2009 | Samsung HC-P4363W 43 in. TV/DVD Combo
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
TV won't come on
I have a 32 inch tv was working great then went into standby mode and wont turn back on. I have unplugged and am waiting please help!!!!
May 18, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
TV won't power on
I am from Australia and this TV is a dud. We purchased it 12 months ago and it has been to repair twice. It is doing the same as the above message. Prior to this the screen would half, horizontally, go black or white with coloured vertical lines. Never buy another of these.
Dec 22, 2006 | Philips 42PF9966 42 in. HD-Ready Plasma...
Memorex MT1091 Television Logo
1,358 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Steve Allison
Steve Allison
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
