No sorry it wasn't the answer I was looking for but it may been because I wasnt clear enough with my question. I have since sorted the problem.No sorry it wasn't the answer I was looking for but it may been because I wasnt clear enough with my question. I have since sorted the problem.
If File Explorer won't open or start, there are a few possible causes and solutions:
Corrupted system files: If the system files that File Explorer relies on are corrupted, it may not be able to start. Running the System File Checker (SFC) tool can help fix corrupted system files. To run SFC, open the Command Prompt as an administrator and type "sfc /scannow".
Third-party software: Some third-party software can interfere with File Explorer and prevent it from starting. Uninstalling any recently installed software that may be causing the issue may solve the problem.
Registry errors: Registry errors can also prevent File Explorer from starting. Running a registry cleaner can help fix any errors and get File Explorer working again.
Disk errors: Disk errors can also prevent File Explorer from starting. Running CHKDSK tool can help fix any disk errors.
malware or virus: File Explorer may not open or start if your computer is infected with malware or a virus. Running a full system scan with a reputable antivirus program can help detect and remove any malware or viruses that may be causing the issue.
Re-registering the File Explorer: Re-registering the File Explorer can also fix the issue. Open the Command Prompt as an administrator and type "powershell -ExecutionPolicy Unrestricted -Command "& {$manifest = (Get-AppxPackage Microsoft.Windows.ShellExperienceHost).InstallLocation + '\AppxManifest.xml' ; Add-AppxPackage -DisableDevelopmentMode -Register $manifest}"
If none of these solutions work, you may need to perform a system restore or a clean install of Windows to fix the issue.
The USe of utility software in increasing pc speed has been shown to tune up pc peed up to 100%. <a href="http://618f9448ja45vlznf3j3xn9r3k.hop.clickbank.net/" style="font-weight: bold;">OPEN UTILITY TWEAK SOFTWARE HERE</a><br /><br /><br />
The
Windows XP registry is your computer's repository for system settings
and configuration data. Over time, the registry can become bloated and
even corrupted. Problems with the registry can slow down your <a href="http://af3be13cq785qiu23hhen-r83p.hop.clickbank.net/"><span>computer</span></a>
and cause programs to malfunction. To maintain a clean, healthy system,
you should periodically scan your registry for errors and fix them when
found. You could do this manually, but Microsoft suggests that you use
registry cleaning software instead. These programs can be downloaded
from <a href="http://1ce798yesa-crllct7rhppgx5f.hop.clickbank.net/"><span>the Internet</span></a>. Before you make any changes to the registry, back it up first.<span><br /><br /><span style="text-decoration: underline;"><a href="http://af3be13cq785qiu23hhen-r83p.hop.clickbank.net/" style="font-weight: bold;">The guide below is for technical person. But the software approach can do the operations without tasks of following instructions: open access <br /></a><br /></span></span>
<span>Instructions</span>
<b>Things You'll Need:</b>
<ul>
<li>
<span>Registry cleaning software</span>
</li></ul>
<ol>
<li>
Back Up the Registry
<ul>
<li>
<span>1</span>
Click the Windows XP "Start Menu", type regedit and press "Enter". The registry window will open.<br />
</li>
<li>
<span>2</span>
Click "file" (at the top of the window) and select "Export". You can choose any name that is easy to remember.<br />
</li>
<li>
<span>3</span>
Type a name for the registry file that you want to
create and click "Save". A copy of your registry will be saved to that
file. If problems occur after you clean your registry, you can restore
your Windows XP registry by double-clicking the file that you saved. It
will have a file extension of reg. Be sure to remember where you save
the file.<br />
</li></ul>
</li>
<li>
Fix the Registry
<ul>
<li>
<span>1</span>
Download a registry cleaning program, such as CCleaner
or nCleaner, and install it. These programs are specifically designed to
clean and fix your registry. You can find links for this in the
Resources section.<br />
</li>
<li>
<span>2</span>
Run the program's "Scan for errors" function. The
software will locate any problems that it finds and display a list along
with recommendations for proceeding. This intermediate step enables you
to view any errors before you fix them. All registry cleaners may not
have a button that says "Scan for errors", but they will have one that
performs the task. See your program's documentation for details.<br />
</li>
<li>
<span>3</span>
Decide on a cleaning option. Some registry cleaners have
an "auto-clean" button. Pressing this will automatically repair all
errors shown on the error list. PC World suggests that you never select
that auto-clean option. Instead, review the list of changes and select
the ones recommended by the software.<br />
</li>
<li>
<span>4</span>
Click the program's repair button to fix the registry.
The software will repair the registry and show you a list of corrections
when it is finished.<br /></li></ul><br /><a href="http://digitalpowering.blogspot.com/2010/12/guide-to-increase-computer-laptop-pc.html" style="font-weight: bold;">PC USe guide on COMPLETE PC WORLD BLOG- OPEN HERE</a><br /></li></ol><br />
<span>Tips & Warnings</span>
<ul>
<li>Many registry
cleaners exist. Some of them perform remarkably well while others are
only partially good at finding errors. <a href="http://af3be13cq785qiu23hhen-r83p.hop.clickbank.net/" style="font-weight: bold;">Check the Internet for reviews
and recommendations</a> when choosing one to download. You can find many
excellent free cleaners as well.<br /></li></ul><br />
<ul>
<li>The
Windows XP registry is a critical system component on your computer and
serious problems can occur if the registry is incorrectly managed.
Follow your registry cleaner's instructions carefully and you should not
have any problems.<br /></li></ul><span><br /><br /><a href="http://www.ehow.com/how_6309011_clean-windows-xp-registry-errors.html#ixzz18AekXPrp"><br /></a></span><span><br /><br /><br /></span><br /><br />
I always use Reginout to fix corrupt registry properly.
Following are the main benefits of using Reginout:-
- Repair and clean registry errors crashes and freezes in applications and programs.
- Optimize and speed up internet through the internet optimizer feature.
- Clean up the backyard.
- System Cleanup Registry Cleaner
- Internet Optimizer feature Services Optimizer
- Defragmenter Startup Manager
Hi Good day!! Remove unused programs in your computer. run disk cleanup remove unnecessary files. if still slow I'll suggest to you to increase your RAM (memory). RAM (Memory) can improve your loading performance. Thank you for using FixYa Don't forget to vote thanks!!!!
Clean up your computer through a registry repairing tool to fix Windows errors.
* Update your sound drivers.
* Update your flash player if need be. The flash player corruption
is a great nuisance and it shall be fixed before it damages all the
browsers present in your system. Repairing your Windows registry errors
through a powerful registry cleaning tool which will fix the active-x
and file association errors will surely help you to prevent the browser
and flash crashes and consequently your YouTube videos will run faster.
* Improve your internet connection if you have currently been using a slow internet connection.
* Use the fast forward option on the YouTube player to run videos quickly.
*Wait a little to let the videos load before you play them in one go.
* Clear up the cache and internet history.
*Optimize your RAM and your Windows performance through a PC optimizer tool. Make
it sure your computer is not internally slower due to the registry
corruption. The registry is the database of program files and codes
which define the rules for these programs to run normally. If there is
something wrong in this sector then you may expect that every program
and even your browser will be running slower.
If you are really interested to speed up YouTube then you
should follow the guidelines above and use this speed booster utility
called RegInOut.
