Question about Emerson MW8102SS 1100 Watts Microwave Oven
Emerson MW81111ss Makes a pop and cracking sound
I have the above listed model. When you turn it on (it only does this sometimes) it makes a loud poppping sound inside. I have tried several things. If you take the turntable's glass plate out, it does fine. When you replace it, it makes the popping sound again. Also the heating of food is always way over heated. Anybody else had the same problem? Any suggestions?
    Problem Solver:
  • 14 Answers
The popping sound is the turntable not being attached fully. Look through the turntable and see if it is attached properly.
Posted on Aug 12, 2009
  • Emerson Master
  • 9,098 Answers
(I'm thinking that's model number MW8115SS?)
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
Thewaveguide cover (also called a spatter shield) is usually about thesize of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating a servicer or parts at 1-800-695-0098.
Emerson parts are distributed by Fox International and their number is 800-321-6993. Or you might try e-mailing researchdept@fox-international.com
Many Emerson microwave owner's manuals are available for free download here.
Posted on Oct 20, 2008
What could cause loud popping sounds?
The sounds you are hearing is the defrosted water, from auto defrosting, running onto the hot compressor. This evaporates the defrosted water. This is quite normal.
Mar 23, 2014 | Samsung RF260BEAEWW
I bought a used Emerson microwave from a neighbor moving out of the building. He did not have an Owner's Manual to give me. I'm trying to find one online but there are so many models that Emerson makes. Is...
The model that you show in the picture is the MW8107WA which has that model number right on the microwave just at the very bottom of the keypad. I'm guessing that you've already looked in the back of yours for a metal plate or sticker that lists your model number on it. Sometimes this information can be found where the door latch meets the door handle on the inside of the microwave.
The manual for the model you have pictured can be found on this very site.
It's here:
http://www.fixya.com/support/p113437-emerson_mw8107wa_1000_watts_microwave/manual-11318
The instructions are all pretty basic as far as preset buttons and setting the clock and whatnot and so they should pretty much apply to most of the microwaves that Emerson has available.
As far as the instructions regarding weight defrosting of meats and poultry that's usually trial and error anyway.
The best way I know of to see as many pictures of Emerson Microwaves as possible would be to put the words:
Emerson Microwaves
into Google and then click the link for "images" (found near the top upper left the page) instead of the "search" button.
That should bring up plenty of pictures of their microwaves.
Jun 29, 2010 | Emerson MW8107WA Microwave Oven
Keurig makes loud noise and sounds as it refills
hIi would return this should be under warranty
Jan 22, 2010 | Microwave Ovens
I HAVE OVER HEATED SOME BOILING EGGS AND IT BUST IN SIDE THE MICROWAVE NOW ITS MAKING THIS POP AND CRACKING SOUND IS IT SAFE FOR ME TO STILL USE IT
Chances are it just needs to be cleaned thoroughly.
If there's any food debris or grease left in the oven, it can arc and pop.
Dec 06, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
My goldstar above the stove microwave popped and now won't heat. Everything else on the unit still works. Is this a problem that can be repaired? Thanks.
Did it make a loud pop like a firecracker?
Sounds like the High Voltage Diode shorted out and it probably is making a low or loud growling noise now..... ???
Sep 11, 2009 | Microwave Ovens
Ge above range microwave, when it is turned on it makes a rattili
is this noise a loud noise or low. and tell me the make and what the model. please
Mar 20, 2009 | Goldstar MV-1501 Microwave Oven
Emerson Microwave oven and grill MWG9111SL
teashas_tasty_treats@yahooo.com
i have the same problem too! please help if you can.
Oct 25, 2008 | Microwave Ovens
Microwave made a loud pop,won't heat,sounds like it's only on half power, makes a low intermittent hum
This is almost certainly a blown high voltage diode.
Please reply back with your brand and model number so we can help you.
May 31, 2008 | Microwave Ovens
Emerson 1000 Watt Microwave
There is a good possibility that microwave energy is leaking near the magnetron tube, or some other high voltage electrical problem is occurring. I would recommend having it tested by qualified microwave repair technician. A few things you can do....
-Make sure the door seal is clean and no corrosion.
-Check the interior for rust spots or holes and make sure it's clean inside.
Jan 16, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Emerson MW8102SS 1100 Watts Microwave Oven Logo
263 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
