Question about Mitsubishi VS-50605 50" Rear Projection Television
Mitsubishi 50605 Hi, Dan- Hvae you been able to come up witht he fix for the Mitsubishi 50605? Thanks again for the help!
  • 4,234 Answers
Got the info. Working on my second 16 hour day. I'll update this tonite. Sorry about the delay.
Dan
Posted on Oct 17, 2008
Picture rolling when I first turn on my tv
A rolling picture or loss of vertical sync can be caused by several components including a bad signal board or jack panel assy. You will not be able to resolve this yourself. contact a Mitsubishi authorized service center.
michtech
Feb 14, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Cost to replace signal board
The signal board is not likely to be the cause of this. I'll research this a bit and update this with some sugestions. Can you solder?
Dan
Feb 11, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi 50605 Convergence Board - Replacement?
I have responded to this in the original posting. I'd rather keep things there to retain the entire context.
Thanks,
Dan
Oct 13, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Replacing the whole board will fix it, but is a bit of overkill. If you can solder and feel comfortable working inside the set, you can fix this yourself. Let me know if you wish to attempt the repair and I'll proviode additional details and instructions.
Dan
Vs-50605 HD Ready Mitsubishi 50"
with the age of this set it is probably component input for the hd,,remember 480p is considered hi def..
Nov 27, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50605 - Colors separated
You have a convergence problem and need to reset
Nov 26, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Vs-50605 Mitsubishi
Infrared pcb is located inside mirror cavity mounted to CRT support frame.Follow lead to signal PCB--is it plugged in,to the correct location??----Then suspect bad infrared detector PCB.Or,possible bad signal PCB.
May 27, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Timer light flashes 3 times
the code means that your tv power supply is not functioning your tv needs to be repaired call the tech.good luck
Apr 26, 2007 | Mitsubishi VS-50605 50" Rear Projection...
VS-50605 (mitsubishi) techman please read
Possible IC301, NOT possible IC501. Consult schematic diagram.
Oct 12, 2006 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
67 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
