Question about Singer Quantum XL-6000 Computerized Sewing Machine
Embroidery pattern trouble
My problem is that the pattern is coming out 'clean.' Half is great, then I get an error message to confirm my top thread spool, I rethread, begin, and it is a jumbled mess of loose string. Can you advise, please?
  • 4 Answers
When mine did this, I had a little tiny bit of thread stuck in the winding path of the endless bobbin. After I cleaned it of all thread, it went back to perfect work.
Posted on Dec 13, 2008
Why doesn't the bobbin thread low message show (although setting on 2) and machine doesn't stop when no bobbin thread?
Um, why would the technician only do half the job???
Could be that the bobbin sensor is dirty. Most likely covered with lint or loose thread.
Oct 13, 2016 | Janome 11000 Memory Craft Special Edition...
My machine keeps showing the bobbin error but there is nothing wrong in the bobbin
Assuming you have threaded the bobbin case correctly, you might try using a different bobbin. There may be something wrong with it. Make sure that there is no thread sticking out of the side of the bobbin.
If there is a bobbin thread sensor, it could be dirty causing it to not read the bobbin correctly.
When you thread the upper thread, be sure to ALWAYS RAISE the presser foot so the tension disk is released and the thread can seat properly.
Oct 11, 2016 | Bernina Artista 640E Sewing, Quilting and...
Quantum XL150 embroidery patterns error messages occur with some patterns. The patterns are rejected for "too many stitches". Does this make sense to anyone?
The computer in the sewing machine can only hold so much. It's rally not very big. I expect the particular color block in your design is too "large" to fit in the computer.
If you can break the problem block(s) in half, the problem should stop.
Oct 30, 2011 | Singer CE-200 Quantum Futura Computerized...
I have a ce 100 and the bobbin thread comes up and gets into my embroidery pattern. how do i loosen the top tension to stop this from happening. my purple flower has white in it from the bobbin :(
Just an FYI-the bobbin thread needs to match your top thread. The majority of the thread that appears in the top of your embroidery actually IS the bobbin thread. The machine is working correctly. Don't use a bobbin full of white thread-instead, thread a bobbin with the color your doing the embroidery work in to match and you will have a perfectly beautiful embroidery.
Nov 11, 2010 | Singer CE-100 Futura Computerized Sewing...
My bobbin thread keeps coming to the top of my fabric during embroidering on my Singer Futura CE350, I've tried bobbin embroidery thread, regular embroidery thread and clear nylon thread, I've tried...
With the embroidering, some of the bobbin thread is SUPPOSED to show on the top of your embroidery-the machine isn't doing anything incorrectly. You'll need to thread your bobbin with the same thread as you are using with the top. I had the same "problem" when I first got the machine and took it to a wonderful local technician whose helped me with a lot of things who informed me that this is perfectly normal on embroidery machines.
Oct 23, 2010 | Singer CE350
Stitching trouble
Here is a trouble shooting chart -
I would start with cleaning (see maintenance section of the user's manual).
This has to be done more often with sewing/embroidery machines that have a drop-in bobbin.
Be sure to use bobbin thread for machine embroidery.
Always thread the machine with the presser foot up. This will insure the thread is seating into the tension control.
Apr 30, 2010 | Brother Disney PE-180D Computerized Sewing...
Bobbin thread
Not completely sure on your model but you have to adjust (loosen) the tension on the top thread to match the tension on the bottom thread. Usually there is a wheel on the upper right of the machine. the tension adjust is the knob inside that wheel. Turn counter clockwise about 1/8 turn. Then try and repeat until it works. Check owners manual for top thread tension adjustment if needed.
Good luck.
Please rate me.
Nov 21, 2009 | Sewing Machines
Baby Lock Embroidery Sewing Machine "ELLURE" Model ESL- Problem: Defective Embroidery Memory Card (part#35205-4) used with the "PTS BOX" and the Palette Ver 1.0 Software Program to transfer embroidery...
I had the same problem and after buying a new card, found out that you get that message if the pattern you are trying to transfer is too big. reduce the size of the pattern and see if that works
Jul 11, 2009 | Baby Lock Ellure
Thread wad on undersurface
machine not threaded properly? wadding thread underside means upper thread does not have tension.
Jun 30, 2009 | Brother SE-270D Computerized Sewing...
Singer Quantum XL-6000 Computerized Sewing Machine Logo
83 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
