Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
Slight picture issue under specific conditions.
Ok, i run my computer off of it. I happen to have alot of discs that are mpeg2's and for some reason with them if i try running them off my computer the figure outlines within images kind of flake out if they're moving too fast. Not sure if brightness of the images are a factor as well. I'm pretty sure my current connection types SVGA. I'm wondering if putting a better connection option in my pc would help this problem. Or if reading that format from disc just doesn't work so well. I've no issues with DVD's. Just the mpeg2 disc's so i'm just lost and hoping theres a solution cause some of my discs kind of require playing on dvd-rom in order to play through and i'd reall like to be able to get a clear image consistantly. Thanks for any input.
  • 513 Answers
In any case, this is not a problem with your TV. You see regular DVD's ok, so the TV itself is fine, and your post is a little out of place in this product page. What I would suggest is that you take the mpeg2's to a friend with a different PC rig, and compare results. It could be your graphics card, and also the software/codecs you use, even the encoding quality of the discs. Try one of the Video coding forums. In general, LCDs aren't as good as standard CRTs when it comes to moving images, I guess you're seing that enhanced through that file format, or in combination with the software you're using. Good luck
Posted on Jun 05, 2006
SOURCE:
How much to fix head gasket on 2001 suzuki 1200
Hi Richard, for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix or parts inquiry. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. Good luck and have a nice day.
2001 Suzuki Motorcycle Service Repair Workshop Manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 13, 2013 | 2001 Suzuki GSF 1200 Bandit S
Duplicator freezes
Freezing can be from many reasons. I can sort of list a few common ones that I have run across with duplicators.
o Defective drive in the drive chain (very common).
o Power supply is having a slight failure or instability.
o Connector in the system having poor contact (not very common)
o Fault condition in the controller, and or the mother board.
o Corruption in the firmware (operating program in the mother board).
Jerry G.
Sep 08, 2012 | Copystars CD copier Duplicator 1 To 10...
Died going down the road, have gas and spark, but wont start now.
For an engine to run, you need three things to happen inside the engine, compression, fuel and ignition, without any one of these components the engine will not run.
  • Compression - Engine compression caused by crankshaft rotation and pistons moving up and down inside the engine block. If the timing belt or timing chain fails it will cause the camshaft to become out of correlation with the crankshaft or allow the camshaft to stop rotating. Either of these conditions will cause the engine to lose compression and sometimes cause internal engine damage.
  • Fuel Delivery System - The fuel system includes: fuel pump, fuel injectors, pressure regulator, fuel filter and pressure lines. This system is used to supply fuel under pressure to the fuel injection system, the lack of fuel pressure or volume will cause the fuel delivery system to fail and the engine to stall or not start.
  • Ignition Spark Delivery System - The ignition system components include: spark plugs, spark plug wires, distributor (if applicable), crankshaft angle sensor, camshaft angle sensor, ignition coil, ignition module, knock sensor and ECM (engine control module). The engine relies on the ignition spark to be delivered to the combustion camber at the correct time. If the ignition spark stops or is delivered at the wrong time the engine will not run or run poorly.
If Your Engine Cranks but Does Not Start Follow this Troubleshooting Guide
Most vehicles operate by the same principle; basic troubleshooting procedures apply to most cars.
  • Step 1: Anytime you have a problem with electronically controlled components such as an engine, transmission, ABS brake, or SRS (supplemental restraint system, Air Bag) inspect all fuses using a test light and check the under hood power distribution center and under dash fuse panels. If all fuses test ok continue to the next step.
  • Step 2: To check for problems with electronically controlled components such as an engine, transmission, ABS brake, or SRS (supplemental restraint system, Air Bag ) and the fuses test ok a trouble code scan is needed to identify any system trouble. Use a simple scanner tool to retrieve trouble codes and see if they relate to the specific problem, like a crank angle sensor failure code. If the trouble code present does not pertain to the immediate problem like an EVAP code ignore it until a later time, after the car is running. The reason we repair non-related codes after the engine is running is because sometime false codes can be triggered by the engine not running. Once the engine is running again the code present might cycle and turn itself off. You might say "if the engine doesn't run shouldn't it have a trouble code?" Sometimes conditions occur that will not be detected by the computer, example: if the fuel pump fails the computer cannot detect the failure, so the engine doesn't start and the computer thinks everything is ok with no codes. If no trouble codes are present proceed to the next step.
  • Step 3: The spark plugs in your engine are used to ignite the compressed fuel air mixture. If the condition of the spark plugs are fouled by excessive fuel or carbon the engine will not start, backfire or run rough. Remove all spark plugs to inspect their condition. Please use this spark plug condition reference guide to see how the spark plugs are operating.
Nov 24, 2010 | 1999 Dodge Ram
I have windows xp with a dvd burner for a drive. i have Heroes Season 3, i am trying to simply watch the 6 dvd's on my computer. i wached disc one perfectly, my computer wont read disc 2, but it reads all...
most of the time this is a simple lens issue where the cd drive in computer is slightly distorted causing it to be a little more frigidity about playing dvd that are not otherwise pristine I would go to walgreens and buy a can of compressed air give your dive a few sprays and you should have alot less problems like this
hope this helped
please leave feedback
thanks
Robb
Apr 25, 2010 | Toshiba D-R5 DVD Recorder
Im having alot of problems with my computer freezing and having to refresh or press shift alt delete it says something isnt working and has to restart. Has to do with enlarging picture
This can happen due to many reasons one if the ram is defective or there are lots of junk files like in the temp directory/folder etc...please remove them and then check the issue.
Apr 08, 2010 | HP Pavilion a6600f Desktop PC
How long should I be able to expect my brakes and rotors to last? I have a two year old car with less than 30,000 miles on it. 2007 Saturn Vue. I don't know what the Green Line is supposed to mean but it...
it all depends on your driving conditions if you have a lot of stop and go traffic everyday you will wear them out alot faster than highway travel. generally a good set of brakes especially original brakes should last about 50,000 miles if not driven to hard or under extreme conditions, most rotors can be machined atleast once before having to be replaced with new ones unless your vehicle runs composite rotors they will have to be replaced everytime you have new pads installed.
Aug 28, 2009 | 2007 Saturn VUE Green Line
Playstation3 turns on and then turns back off with a blinking red light and has a disc inside
O.K sounds like you could have alot of reasons:, one have you cleaned the intake fan grill, cause it will cause it to run "Hot", WHATEVER YOU DO DO NOT RUN IT NEAR A "VAC", that will create Static that will play all kinds of heck with it! use a can of compressed air with it, also check to make sure that your "eye" is O.K. one way you can do this is to run a regular "cd" cleaner disk through it, it will play sound,and (or) music, if this plays o.k. then chances are your "eye" is on track,if these two help, but the "problem still happens from time to time, invest in a small fan, (like the clip on kind), and point it towards the clean air intake, this should stop it from running "hot", make sure you keep your games "clean", a good way is to just squirt some dawn on the bottom of the disk, (and Gently) rub it around with your finger, then under cold to WARM water ONLY, no HOT, rinse the game and "pat" it dry with a towel again don't rub, let me know if this helps, happy 4th, and god bless
Jul 05, 2009 | Sony Playstation 3 (PS3) Console
Mini dvd's not recognized by pc
I had a similar issue at first... needed to ensure that I had the Sony Picture Motion Browser Software downloaded to the system and then it was ok.
Tom.
Mar 14, 2008 | Sony Handycam HDR-UX1 DVD Camcorder
Which file formats are supported
mpeg 2 is avi does mp3s reads alot samsung has one of best readers i seen best bet is mpeg2 tho 720x480 29.97 fps wide ok
Jan 09, 2008 | Samsung HT-DS140 System
Issue with trying to play mpeg2's on my computer.
I think the problem is either software related, or is the disk itself. Firstly make sure you have all the proper mpeg-2 decoders. I'd assume you do, but looking for an update for whichever software you use to watch the dvd may help. You should also troubleshoot the software by trying an alternative program and seeing if that helps. (if you use VLC, try cyberlink, etc.) Secondly, there is a chance the actual distortion lies on the disk itself. You could narrow this down by trying the disk on a dvd player and the dvd rom, paying close attention to where the problems arise. If the dvd player and dvd rom both have trouble with the same section (or if the dvd player freezes in the same place the dvd rom starts to flake) the problem may be the disk. In either case, I highly doubt your computer itself has hany flaws in it. It is either software, or the disk itself.
Jun 06, 2006 | HP Pavilion Media Center a1350n (EL472AA)...
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
81 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
