Question about Brother Office Equipment & Supplies
Brother dcp 330c unable to print 50 - Brother Office Equipment & Supplies
Print unable 4f
Posted on Jul 15, 2010
UNABLE TO PRINT 4F
Posted on Jun 18, 2010
    Problem Solver:
  • 12 Answers
Some part need to be replace it like a Engine that move the rubber thing....the rubber that move the head...either the mainboard need to be replace or that small engine need to be replace..... Usually using generic ink will coz the faulty try not using any chemical to waste the print head...
Posted on Apr 25, 2009
nandini789
  • 430 Answers
SOURCE: unable to print 46
This is mainly due to dirty machine. Try following my steps:-
1. Press the Menu & Mono start keys. Next press the up arrow key 4 times to make the machine enter the maintenance mode.
2. Enter 8 & 0 by using the up arrow key & SET keys.
3. Press the mono start key several times untill the purge count appears on the LCD.
4. Enter 2 7 8 & 3 by using the up arrow key & set keys to reset the purge count to zero.
5. Press the stop/exit key to return to the initial stage of the maintanance mode.
6. Enter 9 twice by using the up arrow & set key's to exit from maintenance mode
Posted on Aug 21, 2009
pineworks
  • 4041 Answers
SOURCE: brother printer dcp 330c - unable to print 50
Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
  • 215 Answers
SOURCE: Brother DCP 330C 'unable to clean 46' printer will not print
responded to this on a error 46 post by joachim.
hth,
razors
Posted on Mar 30, 2009
Davethesnake
  • 689 Answers
SOURCE: unable to print 50
simple driver configuration problem linux is (the Cups printing system) is pretty universal just get your settings right or even cr even surrogate settings it should work
Posted on Sep 06, 2010
Samyfam
  • 379 Answers
SOURCE: I am getting error Unable
I'm afraid there is no simple solution to this problem.
Error codes 50 and 51 refer to problems with the purging mechanism - some of the whirring and clicking noises you hear when the machine self cleans or starts up are it purging ink from the print head. Through some very clever mechanics, the machine uses the paper feed motor (running in the opposite direction to normal) to perform purging.
Possible causes listed in the Brother Service Manual for this error code range from "simple" things like a misaligned cam, to complex problems with the main control board. However, whatever it is, dismantling these machines isn't staright forward and parts are very diffciult to obtain and very, very expensive, so much so that 99 times out of a 100, it isn't cost effective to repair.
You could approach a Brother service agent, but it's highly probably that they will charge you more than buying an equivalent brand new machine.
Sorry.
Posted on Apr 02, 2011
My printer brother dcp-330c have "unable to clean 46" problem.. the answer in your website doesn't help as i was unable to enter the maintenance mode from the instruction.. my printer does not...
I developed the same problem "unable to clean 46" on my brother dcp -330c printer.. after taking to a maintenance guy... he told me to remove my ink absorption pads and wash them out with water and leave to dry then once dry replace back in..
Apr 14, 2011 | Brother DCP-330C All-In-One InkJet Printer
I am getting error Unable to Clean 50 My brother printer model is DCP -330C..Anyone got any idea??Plz help
Sorry.
Apr 02, 2011 | Brother DCP-330C All-In-One InkJet Printer
My Brother DCP 330C says " Unable to print 4F" What does this mean and what can i do to fix it please??...... Thank you Kindest reagrds Milli
Hi millih,
An error coded 4F means that there is a mechanical problem with the printer, usually, "unable to print means one of two things. Firstly an empty cartridge, secondly a full absorbing pad. I am guessing that the latter is not the priblem as the code would be #46, so if the ink cartridges are empty, get them replaced or refilled then disconnect the machine from the power for about 5 minutes, then reconnect and it should reset itself.
Sincerely
rover620
Sep 20, 2010 | Brother DCP-330C All-In-One InkJet Printer
Brpther DCP 330c does not recognise new black ink cartridge
Usually there is more than one cartridge empty when you receive this kind of problem. Try opening the top cover and check if the display changes - it should change to specify one (or more) of the color cartridges as empty. That one(s) should be changed too.
Jun 03, 2009 | Brother DCP-330C All-In-One InkJet Printer
hth,
razors
Mar 24, 2009 | Brother DCP-330C All-In-One InkJet Printer
Unable to print 50
Nov 27, 2008 | Brother MFC-440CN InkJet Printer
Brother DCP 330C
This COULD BE that there is some paper stuck in the dcp. Open cover and try to see if there is some paper left in the machine. I ve noticed, that -seeing from behind!- on the right side paperpieces are stuck and disturb the disk (foil) which give the printer info what to do. Open cover and try to look into the edges (seeing from the front: its the left side -where the modell name is printed) In some cases this means that the purgecamshaft is defective.
Aug 17, 2007 | Brother DCP-330C All-In-One InkJet Printer
1,287 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
