The e310 Chipset is SD only, and so does not support SDHC for more then 2GB. You may try non-standard, non-SDHC 4GB cards which are out of specification for SD, but work in "some" SD enabled devices. Depends on device-software...
I cannot make first connection. I have installed the latest Active Sync but cannot complete...
(More)
I cannot make first connection. I have installed the latest Active Sync but cannot complete installation of the Pocket Pc Connection Wizard that came on the CD because it does not show connected but active sync does see it. When I plug in the device Active Sync starts connecting but does not finish. It seems to be a setting but has eluded me so far! Please Help. Thank-You
How do you connect a toshiba e310 to the internet? I heard you need an SD wireless card but i do not...
(More)
How do you connect a toshiba e310 to the internet? I heard you need an SD wireless card but i do not know which to look for, any suggestions?I've looked but can't find any, apparantly the device won't support non toshiba or newer wifi SD cards.
when i charge the Toshiba Pocket pc e310, it appears to be charging, but when i unplug it, it does...
(More)
when i charge the Toshiba Pocket pc e310, it appears to be charging, but when i unplug it, it does not turn on
