Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
My Cuisinart Grind and Brew gets wet grinds in the shoot that clogs up. This does not allow the grinds to go down the shoot. I clean it correctly & frequntly. The grinds are never powder & always wet. How can I fix this problem? Modle#-DGB-7008C Serial#-7120 7C
  • Anonymous Mar 29, 2014
    It grinds but the light is always blinking
  • 8,596 Answers
Switch to paper filters -some coffees are too fine for that gold tone filter.
Posted on Dec 17, 2008
We have a Cuisinart DGB-900 BC Grind and Brew Thermal Coffeemaker. Our Problem is that the bean grinder has stopped working. We purchased the coffee maker on 2/25/10. Prior to this happening, we were...
try cleaning the grind chute again. if problem persists:
this is a cronic problem with the DGB900BC even after cleaning. the problem is the gate or trap to the grounds needs to open/remain open during grinding or all backs up and jams. my unit opens the door (correctly) during the rotation but closes just before grinding (over-rotation?). Cuisinart is not aware of this problem (800-726-0190). please call them; i just have.
Aug 30, 2010 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
Cuisinart grind and brew 10 cup grinder stopped working
My grind and brew is a little different, but when I have this problem, I havve to remove the beans and vaccuum out the bean reseviour. It gets clogged and then it won't grind.
Mar 23, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart grind and brew--water does not come down
If the water is not coming out of the filter basket, and is instead leaking over the edges, then replace the brew basket.
If there is no water at all, call Cuisinart - those coffee makers have a 3-year warranty.
Feb 25, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee grinder on brew and grind won't work
Make sure the slot between the grind basket and filter basket is clean and free of grounds - then inspect the area near the grinder motor - use the brush that came supplied with the Cuisinart to clean that area out. Once thoroughly cleaned, try one more time to Grind. Let me know if it works.
-Tha Mp3 Doctor
Jan 06, 2009 | Cuisinart Thermal DGB-600 Grinder
Cuisinart grind and brew beeps, but won't brew
we unplugged it for 10 minutes or so, plugged it in again, beeping stopped and it works again.
Nov 16, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart 10 cup auto grind and brew
Here is a link for the PDF version of the Instruction Booklet for the DGB-600BCC (from the name you provided I’m assuming this is the correct product).
If it’s not the right product, check out the Cuisinart.ca website, you can select the product you are looking for and download the instruction booklet from the product page.
http://www.cuisinart.ca/en/pdf/ibs/DGB-600BCC_en.pdf
Hope that helps!
Oct 15, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
I cannot remove the grinder from my cuisinart Grind and Brew Coffeemaker. It still makes great coffee, but I want to clean the grinding mechasim and cannot remove it.
Common with the DGB-600 - you can try icing it down for 10 minutes - once removed, clean exterior with vinegar applied to a rag to get oils off - endemic to this unit - replacing it with exact same model will not help.
Oct 13, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
Oct 07, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
227 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
EugenesDIYDen
EugenesDIYDen
Custom Exchange
Custom Exchange
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
