Question about TruTech PLV16320 Television
Trutech TV PLV16320 - Power Supply Caapacitor Values
I have a TruTech TV PLV16320 and need the values of the following Capacitors on the power board. My friend had removed the capacitors and not written down the values
Can someone please help me with the values. They are in 3 sizes based on the circles and holes on the board
Size 1: C15,C39,C50,C65
Size 2: C47 and C48
Size 3: C55,C56,C57,C60
Any help will be appreciated. Thanks
    Champion:
  • 367 Answers
I take it you didn't save the capacitors?Or you just don't know what hole they came out of?I have someone that is supose to be sending me their power board from the same model TV.When I get it,if I do,I will let you know what they are.I did replace the bad ones on a 26" Trutech,and to me,they appeared to have the same board.If you wanted to take the chance,and replace the ones I did,here is what they were.Mine had three different diameters as well,but two had different voltages,and height.The measurements read diameter,and then height.(2) 35V 1000UF 13MM X 22MM (1) 25V 680UF 10MM X 16MM (1) 35V 680UF 10MM X 20MM (4) 10V 1000UF 8MM X 14mm When you do go to replace them,you can get ones with a higher value on both specs,but not lower.For example,if there is a 10V 1000UF,and a 16V 1000 UF,you can replace them both with 16V 1000UF,and it will work perfect.You can also use different heights as well,as long as there is enough room.How is the big black 450V 150UF,and the 400V 10UF capacitors?You have to check the bottoms of them as well.I had fixed one that these were the only two that were bad.I hope this helps.If you have any other questions,please let me know.Thank You very much!
Tyler
Posted on Oct 23, 2008
Tv will not turn on
This is a protection circuit that prevents the tv from coming on (to stop damage of the components) ....you need to check your voltages off the power supply and make sure they all read well (EX: 24v12v5v etc). Also look for popped capacitors that would make the values lower than need be for the tv to power on properly.
Once you repair the power supply then you may need to replace other components if needed (EX: backlight inverter)!
Please rate if this helps! :D
Replacing capacitors is ALWAYS the cheaper option, but you need to have experience it, or you'll create more damage than good!
May 11, 2011 | TruTech PLV16320 Television
I have a19 Thin LCD tV mODEL nO PLV16190 WONT TRUN ON so what can i do
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Mar 31, 2011 | TruTech PLV16190 Television
Yes i am tyler thank you trutech plv16320vm tv/monitor, will not come on,when you plug it in you get a red stand by light ,when you press the power on button. it goes off and nothing happens. or after u...
I would have to say that you have bad capacitors in the power supply.Open the back of the TV,and look at the can shaped items called capacitors on the board with the power cord.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Mar 08, 2011 | TruTech PLV16320 Television
Where can i find a power supply for a trutech 17" PVS21175S1 tv/dvd combo.
Most tv's don't need a power supply, just a couple capacitors. Look at the capacitors in the power supply section for bulging at the top. Much cheaper.
Feb 25, 2011 | TruTech PVS31170S1W 17 in. LCD Television
TruTech PLV16320 power suply
What is wrong with your power supply?Please let me know.Thank You very much!
Tyler
Sep 21, 2010 | TruTech PLV16320 Television
NEED POWER SUPPLY FOR TRUTECH PLV16320
Tyler
May 19, 2009 | TruTech PLV16320 Television
USED TRUTECH TV
you have a high voltage problem I would guess its in the power supply B+ voltage is missing hope this helps you.
Sep 15, 2008 | TruTech PLV16320 Television
TruTech PLV16320 LCD TV
Hi
I like to know if the power supply transformer was buzzing when this caps burned , I"am responding
on bandita's 2012 e-mail regarding her TV that has no piture or sound and no red or green indicator lights, the power button does
not turn the TV power off regarding the transformer buzzing.
Thank you RichE
Jun 18, 2008 | TruTech PLV16320 Television
Troubleshooting
noavatar_s.png By nonexpert_s.gif Greasmonk
Rank: Apprentice
Rating: 0%, 0 votes
Heres what mine did:no picture no sound, when i hit the remote the indicator light went out....piece of crap is six months old, cant find any info on it, cant get a hold of anyone at Trutech.
So i took it apart, on the board that the power cord is attached to, i found six blown capacitors. There is also a big ass one in the middle of that board which looked ok but blew out the bottom.I replaced them, and im watching it as i type.
Its fairly easy but if your not comfortable soldering on a cheap circuit board, take it to someone.
I hope it helps, i think this repair will fix the other Trutech models with the same problems.
Eric
ed44309@hotmail.com
Dec 24, 2007 | TruTech PLV16320 Television
TV Screen Not Working
Rank: Apprentice
Rating: 0%, 0 votes
Eric
ed44309@hotmail.com
Nov 09, 2007 | TruTech PLV16320 Television
TruTech PLV16320 Television Logo
243 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
