Question about Lexmark X5495 Printer
Refilled x5495 cartridge
I have a Lexmark X5495 printer and I had it refilled , I still have a message that goes "Order new ink" or something and i check the cartridge but it is full. I try restarting the printer and even the computer but the printer STILL won't let me print.
  • jwcobb Nov 07, 2008
    I have the same issue. I would like to disable this prompt as it won't let me print at all....even though the previous page before the error appeared printed in perfect black.
  • Anonymous Jan 26, 2009
    I have the same problem.  Lexmark told me that you have to use Lexmark ink to have technical support.  Tried to clean it and it still isn't working.
Hey jose022-it sounds like the ink on the header has dried up . Try pulling the cartridge back out and blotting it on a clean napkin .I f there isn't a small display of the three colors on the napkin , the cartridge end probably dried up before you refilled it.In this case you need to use the head cleaner kit and follow the instuctions that comes with it.
If there isn't aclear low of all three colors coming out the sensor will recognize it as only as the previous empty cartridge.
good luck !
trackrunner11
Posted on Dec 28, 2008
Go to http://www.lexmark.com and select "Drivers and Downloads." I believe there is a new driver for the Cartridge Wizard software that you can download and install. Good luck!
Posted on Dec 10, 2008
I have a Lexmark X5495 printer, and I refilled the black cartridge. Is there any way to override the ink levels?
Once a cartridge is refilled, it can no longer report it's true ink level. Just an FYI: you might not get the print quality you expect from ink that is specially formulated by Lexmark to pass through microscopic nozzles at extremely high temperatures.
May 17, 2011 | Lexmark X5495 Printer
Refillable cartridges for X5495
34 and 35 are refillable. The ones you get with your printer aren't.
Now, I don't understand why the colors are mixed. Is the 35 you tried a new cartridge or a refilled one?
Apr 04, 2010 | Lexmark X5470 All-In-One InkJet Printer
I have a lexmark x5495, what is the file that that moniters and reports ink levels? It is what stops me from being able to use my own refilled ink cartridges.
Hi there
Lexmark and Brother printers has made the pritners this way so it can not use refills.
You can not reset the inks that I know of on a Lexmark sorry.
All the best Pineworks
Mar 19, 2010 | Lexmark X5495 All-in-One &USB...
When i get my ink cartridge refilled printer says cartridge low on ink
The magic words "refilled cartridge" says it all. Like all the other makers they put a little bit of ID info on each cartridge. This is detected when "replacing" there own existing empty / dried up cartridge.
Refilling uses the same cartridge and so no new cartridge ... so to the simple low tech sensor .. you are still out of ink. Lex usually asks questions to verify old new etc. Don't worry enjoy the low cost re filling gives you. You can also turn off the messages .. GL be happy
Nov 20, 2009 | Lexmark X5495 Printer
Lexmark x5495
Lexmark does not allow refilled cartridge on any of their products.
Lexmark, HP and Canon and-many other vendors use proprietary code to protect themselves against the damage of OEM inks.
All companies will void warranties.
Apr 24, 2009 | Lexmark X5495 All-in-One &USB...
I just refilled black ink of my new printer Lexmark x5495. Does not recognise the black cartilage and keeps on asking for alignment. When it prints alignment page it does not use the refilled black ink....
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Apr 10, 2009 | Lexmark X5470 All-In-One InkJet Printer
Printer will not work after installing a new ink cartridge?
did you see a piece of plastic stuck on the back of your cartridge?
Mar 21, 2009 | Lexmark C533DN InkJet Printer
Refilling Ink Cartrdige failer!
I have a Lexmark X5495 printer and I had it refilled a couple of weeks ago, suddenly i have a message that goes "Order new ink" or something and i check the cartridge but it is still full. I try restarting the printer and even the computer but the printer STILL won't let me print.
Oct 11, 2008 | Lexmark X5495 Printer
HOW TO REFILL LEXMARK X5495 PRINTER
When you try refilling your ink cartridges, you are taking chances that something may go wrong. I would search the web and purchase re-manufactured ink cartridges, which would be less expensive than the new ones from Lexmark.
http://www.ink-refills-ink.com/printer/Lexmark+X5495+Ink/15981/?src=gpsearch&gpprod=Lexmark+X5495&gptype=bulk
http://www.internet-ink.co.uk/lexmark-ink-cartridges-X5495/
Please remember to rate all users who assist you for free :)
Sep 20, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x5495
Lexmark advertises the cartridges supplied with this printer as cart. #28 and #29. They claim these are nonrefillable. The refillable cartridges are #28a,29a, 34 and 35, the last two being the high yield carts. Make sure you have one of these.
Mar 29, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5495 Printer Logo
267 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
