LG VX3100 Cellular Phone
Problem for LG VX3100
Phone does not work properly
By zakia on Jun 02, 2006
my phone got in some water and i was able to take out the batterry right away and let it dry for a few minutes. when i replace the battery and turn the phone on , the message was that the phone was completely charged and the battery meter was blinking as if still charging. also the phone does not produce any sound at all.
Same Problem
Aug 01, 2008
-   i do not know how to get the battery out, i think it is lose-   Guest
Best Solution
posted on Jun 24, 2007
Very Helpful)
dll932
Rank: Wiz
Rating: 82%, 77 votes
Since cellphones have ways of indicating water damage (internally AND externally), warranty service is pretty much out of the question. You can TRY using a blowdryer (on LOW heat) to make sure the insides of the phone are dry, and put the battery back in to see if works.
Incidently, the lithium-ion batteries in cellphones are potentially dangerous; anything that might short them out, like physical damage, water inside, could cause them to catch fire and burn like a flare! Also, you don't want to get them too hot, say over 140 degrees F-same result.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jun 01, 2007
Somewhat Helpful)
krizanto81
Rank: Wiz
Rating: 79%, 112 votes
the phone must a short circuit on the devices inside. it will consume the battery triple than its normal consumption. also your buzzer interface get wet or your buzzer damaged.
Was this helpful?
Yes
No
Solution #3
posted on Jun 03, 2006
Somewhat Helpful)
soldierruel
Rank: Wiz
Rating: 75%, 872 votes
your phone got the worst thing that could ever happens to a phone.
Its now liquid damage even if you got the phone fix there is no guaranty that the phone will ever work properly. My suggest to you is when you get pisst off about your phone cos its not working properly....is repalce it with a new one.
soldierruel
Was this helpful?
Yes
No
Solution #4
posted on Jun 26, 2008
Very Helpful)
macattack123
Rank: Apprentice
Rating: 100%, 1 votes
take apart the phone and put it in a plastic bag with silica gel(the things you find in a shoebox in a packet labled DO NOT EAT) this acts a dessicant and aborbs the water right out. its also used to keep moisture outta the shoes. fun fact for ya there
Was this helpful?
Yes
No
Solution #5
posted on Feb 29, 2008
Somewhat Helpful)
debrob22
Rank: Apprentice
Rating: 75%, 1 votes
You need a new battery.
Was this helpful?
Yes
No
Solution #6
posted on Sep 04, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
The audio circuit have short probably,the motherboard have replace to new one...or change the component of the board
Solution #7
posted on Aug 08, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
my phone screen satys white an changes to its normal state when it feels like. [ LG cg300 ]
Solution #8
posted on Aug 10, 2007
Not Rated)
Agbons
Rank: Apprentice
Rating: 78%, 2 votes
Try reprogramming your phone or flash it.
Was this helpful?
Yes
No
Solution #9
posted on Jul 23, 2007
Not Rated)
emmaskitch
Rank: Apprentice
Rating: 0%, 0 votes
i suggest takeing it appart letting it dry out for bout a week then it should work, ive damaged a the k610i this way and that is what i did now it works!
Was this helpful?
Yes
No
Solution #10
posted on Jul 05, 2007
Not Rated)
tonydsc
Rank: Apprentice
Rating: 0%, 0 votes
You have to wait more than a few minutes.. try a few days with the battery off.
Was this helpful?
Yes
No
Solution #11
posted on Jun 14, 2007
Not Rated)
Becc
Rank: Apprentice
Rating: 0%, 0 votes
When I waterlogged my phone...I took out the battery and sim etc. and dried it all with a hairdryer...this dries even the parts you can't see. Mine worked fine after that. Might help...
Was this helpful?
Yes
No
Popular Solutions for LG VX3100 Cellular Phone
Questions and Unsolved Problems for LG VX3100 Cellular Phone
Do you recommend LG VX3100?
Answer
Answer
how do i find password on my tracfone???
Answer
I want to put my cell phone in a new case any help in opening case so i can put workings in new case... (More)
Answer
I switched phones and no longer need my vx3100, but I can't seem to remove my number from the phone.
Answer
Yes I Got My Razor Phone V3xx Washed And I Blow Dried It With A Blow Drier And Now It Don't Work How... (More)
Answer
my phone is on roaming and i would like to know how i would be able to take it off. it also have on... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For LG VX3100 Cellular Phone:
Top Cellular Phone Experts
Rank: Guru Guru
Solutions: 567
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Cellular Phone Experts
Top Cell Phone Repair
(918) 955-1100
The Cellular Phone Repair Center opened in March...
cellularphonerepaircenter
CPR
(800) 818-8800
We offer hight quality OEM such as travel charges,...
CPR
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
