Question about HP LaserJet 1320n Printer
Paper is winkeled comming out of my 1320 n printer
When I print, the paper comes out the printer all wrinkeled. I can't see anything stuck on the rollers.
Window xp.i have same problem about paper coming pcl xl error position: 8.
Posted on Oct 19, 2008
Fails to print
Restart the printer after checking for a piece of paper that may be stuck. Also check your pick up rollers.
Jan 04, 2014 | HP LaserJet 1320 Printer
My hp laserjet 1320 takes in more than one paper while printing, which get stuck.
Cleaning the pickup roller will only temporarily delay problem. The pickup roller and separation pad needs to be replaced to correct the multiple paper pickup problem. The roller and separation pad is easy to replace. These parts come in a kit caller RK-1320 the parts kit is available here:
http://www.ccl-la.com/catalog/product_info.php?products_id=71
Mar 28, 2013 | HP LaserJet 1320 Printer
Printer can't pickup paper to print
When the printer can not pic up paper this indicates the pick up roller and separation pad need to be replaced. These two parts come in the preventative maintenance kit under part number RK-1320 this kit is available here:
http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_42&products_id=71
I hope this helps,
BuddyMc
Jun 05, 2012 | HP LaserJet 1320 Printer
When printing on HP Laserjet 1320 it brings the red light and it does not shows any error. no printout.
there is a paper in it's roller to remove it pull out the tonner and check the roller ther will be a paper stuck in it remove that papre printing will be contnue
Jan 19, 2011 | HP LaserJet 1320 Printer
I have HP1320 printer when i send the print command printer paper out blank no printing?
1-There is a plastic knob that press the laser unit's shutter at the front door check and make sure that it is OK .
2-there are some earthing wire, at left side that connect with toner,some time these wires pressed down and not connected with toner and the print comes blank.
Jul 10, 2010 | HP LaserJet 1320 Printer
Hp laserjet 1320 paper jams constantly. not even one page prints. what could be the problem?
could actually be the paper your using. make sure your using at the very least multipurpose paper or laser paper. check to make sure your settings for paper is also set to regular paper and not cardstock or special paper or anything else
Jul 30, 2009 | HP LaserJet 1320 Printer
HP LaserJet 1320 folds over top left corner of every page printed
I see this problem alot after a paper jam occurs and someone has pulled the stuck paper out. There is probably a piece of paper stuck in the printer somwhere. If you open the front toner door and take the cartridge out, you will see a roller at the bottom front. DON"T touch the roller but take it out. You may find the paper there!
May 24, 2009 | HP LaserJet 1320 Printer
Hp laserjet 1320tn folds the upper right-hand corner of the page
Check carefully for any small scraps of paper caught in the paper path. Do a 1/2 way test, do a print job, listen for the paper to get just under the toner then quickly open the front of the printer (may take a few tries) see if the paper is folded there or if it's happening later that way. If it is folded before entering the fuser, you probably have a small piece of paper in the paper chute somewhere. If it's not and folds later, the fuser is probably worn badly.
Feb 09, 2009 | HP Laser Jet 1320 Printer
HP 1320 duplex printing paper jam
Managed to solve this myself: I disassembled the printer and noticed there was a paper jammed in the duplex tray. Rolls were all ok, but the paper blocked the use of the duplex pathway. For disassembly help check the HP 1320 service manual, which you can find on the net as a PDF.
Jul 14, 2008 | HP LaserJet 1320 Printer
Printing Issue
switch off the printer and open up the cover and remove the toner and see is ther any paper is stuck inside. or try to print a single sheet from front panel. bye
Sep 21, 2007 | HP LaserJet 1320 Printer
HP LaserJet 1320n Printer Logo
41 people viewed this question
Seeker5211
Seeker5211
