Question about HP OfficeJet 6110 All-In-One InkJet Printer
6110xi all in one will not even turn on
My printer will not respond to pushing the power button. I have tried unplugging, pushing all buttons etc. and the power will not come on. It is like it blew a fuse.
  • 54 Answers
Check whether plugins are correct and check the other end of  the wire is correctly connected to the printer bcos itr may be loose contact if every thing is right still not working better service in an authorised service centre
Posted on Oct 17, 2008
Samsung Washer Model WF209ANW1XAA not responding to anything. Power comes on but will not operate when pushing any buttons. Will not even allow me to go into test mode.
try unplugging, then while unplugged, hold in power button for 10 secs or so. then plug back in. (if that does not work, try holding in power button while plugging back in) good luck.
Mar 10, 2015 | Samsung Washing Machines
Officejet pro 8500a premium power light on but touch screen is off and will not respond and the power button will not respond either
hi, Mr Justin Becker
i think its a power supply problem, first you should try another dc adaptor, if your printer works fine with the new one, you have to replace it or take it for repair.
if it is a DC Adaptor problem it cost about: US $29.74
HP OfficeJet Pro 8500 AIO GSA printer power supply ac adapter cord...
Mar 06, 2014 | HP Office Equipment & Supplies
My Canon printer status monitor shows the printer has an error code 5100. I cannot find any reference to this in the manual. The printer does not power up. I have tried to unplug it to no avail.
The error 5100 indicates that there's something obstructing the movement of the cartridges. You need to check everything, like gears, Timing Strip, carriage, etc.. After cleaning everything and verified that there's no foreign particles like pieces of paper, or etc.. etc.. try this :
  • Turn off printer
  • Hold down Resume button and press Power button.
  • Keep holding down Power button and let Resume button go.
  • Press Resume button 2 times then let BOTH buttons go.
  • Green lights will flash and then stop blinking.
  • When green lights are solid, press the Resume button 4 times.
  • Press the Power button and the printer should turn off, if not, press the Power button once more.
  • Your printer should respond as normal
These steps varies from model to model, so if you need further help, let me know with the model number of your Canon.
Good luck.
Thanks for using FixYa.
Aug 23, 2010 | Office Equipment & Supplies
The TV will not turn on.
I have the same problem, push button to turn on tv but it only does a click like it is going to turn on and then another click bit it wont turn on. Finally a red light is just blinking.
Any suggestions, is there a freeze button or code that I need to push.
Jul 03, 2009 | RCA HD52W140 52" Rear Projection...
Help Urgent
Hi Natasha,
If the button settings didn't help, then try resetting the printer.I have mentioned all 3 kinds of resetting, try and let me know.
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON button for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait until the ON light flashes, then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-Remove the Ink Cartridges, then unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait until the ON light flashes,or wait for 20 seconds then release the button.If the printer goes off don't worry release the button and Push the ON button.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
(Notes - resets will take a while)
Thanks n Regards
Rizwan
rizwan84tx@gmail.com
Dec 07, 2008 | HP OfficeJet 4255 All-In-One InkJet...
My remote is not responding to the tv even i have changed the new baterry
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 21, 2008 | Samsung BN59-00599A Remote Control
Error number 1700 canon s9000 printer
knowing printer manufacturers I doubt they even have a sensor to detect that its full at all, they probably based on something crumby like print count. here are some instructions to reset the waste ink tank, the instructions vary so try them until one does the job :
Waste Ink Tank Reset
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice, then release all buttons
5: When the indicator lights steady, press RESUME three or four times. The indicator should be orange.
6: Press Power to set data
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
1. power off Printer
2. Push and hold resume button and push power button
3. Hold Power button and release Resume button
4. Push Resume button twice ( 2x ), and now release resume button and power button
5. Green light will blinking and stop.
6. When green light on, push resume button 4 x
7. Push Power button and printer will off, if that isn't off, push power butto again until print off position.
Aug 20, 2008 | Office Equipment & Supplies
Problem with k80 hp printer
ok..turn it off...and then press the power button, remove the power cord..wait 30 seconds..plug it back in..try that..
Jul 10, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
Chatters
i belive that your printer needs to be resetted. Just try the reset options which are for HP 6110xi.
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON buton for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the buttons.
SEMI_FULL RESET:-Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off dont worry release the button and Push the ON button.
Thank You
Feb 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Error problem on Canon BJC-80
Try this:
1: Unplug Power Cord
2: Hold POWER and RESUME buttons
3: Plug in Power Cord
4: Release buttons after the printers starts up
5: Hold CARTRIDGE and RESUME
6: Press POWER
7: Release all buttons after the beeps
8: Press CARTRIDGE 16 times
9: Press RESUME
10: Unplug the Power cord
Jan 17, 2008 | Canon BJC 80 InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
