Question about Canon PIXMA MP530 All-In-One InkJet Printer
Nozzle Blockage in Canon MP530
I have a nozzle block in the PGBK cartridge on my Canon MP530. I have tried cleaning the nozzle with alcohol and a q tip and it is still there. Any suggestions ?
  • 76 Answers
I hope you dont mean a snooker/pool q tip??
i would say to replace the printhead, this can be found on google.
part number is: QY6-0059-000
Posted on Oct 21, 2008
Mp860 black cartridge problem
You do a nozzle cleaning from the maintenance program and it should correct the problem. Also make sure the rollers are clean as well as to not cause streaking.
Aug 27, 2014 | Canon PIXMA MP830 All-In-One InkJet...
I am having trouble with my Canon MP530 printer. I can't print red. All my pictures or documents that should be red come out pink. I changed the large black cartridge today and the yellow as they ran...
If you are sure there is still ink in the cartridge try the procedure below:-
Ink may be new, but their nozzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it and the nozzle is not blocked. If not blotted or scantily blotted, it means ink is really low or nozzle is blocked. To be very sure of this, place nuzzle in a plate/saucer with a bit water so that the nozzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nozzles, the procedure may be repeated over to get results.
Good luck & God bless!
Mar 03, 2011 | Canon Office Equipment & Supplies
The PGBK cartridge doesn't print anything
Do a selftest on the printer. If the Selftest prints out something, uninstall the printer Driver and reinstall it again. If it still did not work checkin the printer to a qualified technican to have a look at it.
May 12, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
My printer will not print in color even though I have all new ink cartridges. Only a little yellow appears on the page.
It sounds like you are using aftermarket or refilled cartridges. There can gum up the nozzles and restrict or block the ink. To clear the sensors and nozzle, install new OEM cartridges, run deep cleaning a number of times (at least 3 times), and then the alignment utility.
Aftermarket/refilled cartridges do not always meet the manufacturer's specifications for quality. Try cartridges from LDproducts.com for your printer. I've never had a problem with their aftermarket cartridges. If you can, I would return the failing cartridges for replacement or refund.
Please rate this solution. Thanks.
May 10, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Canon mp530 - colors print dull and faded
The ink tanks may be full but sometimes the pins that connect the cartridges to the printer may have dried up ink on them preventing the ink from flowing. You can try to swab these with a bit of rubbing alcohol on a Qtip and letting it dry for moment or two. I would strongly suggest doing a couple of deep cleanings first and try test printing of the individual colours separately in a program such as paint to see which colour is affected.
Jan 24, 2010 | Canon PIXMA MP530 All-In-One InkJet...
MP530 PGBK not recognized
1. UNplug printer at outlet or power strip & wait a full minute.
2. Plug back in and check if ok now.
1. remove cartridge; look for "spit wad" stuck onto the cartridge or in the cartridge cavity in printer.
1. If of the above neither works; use a new cartridge, but don't discard old one.
Sep 01, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA MP500 New Black ink cartridge produces no ink
If you don't use it very often the black could have dried in the printhead, and you will need a new one. Another possibility is that the purge unit is not cleaning and priming the printhead properly. I have seen several defective purge units. For 1 year it can be replaced under warranty, after that it is a $90.00 repair job in the shop.
Jun 25, 2009 | Canon Pixma MP500 All-In-One InkJet...
PM530 printer: PGBK cartridge not working. Just
Clean the feeder use Que tip With Alcohol only let it dry and clean the cartridge the same way replace the That should solve the problem, Also keep in mind if you are using a cartridge that is a refill The cartridge sometimes dry out Have that checked it might be bad other words plugged up. Good luck with it
Feb 21, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Canon ip4200 one cartridge/nozzle does not work
Put isoproply alcohol on the nozzel with a connon swab until it melts(desolves) the drived ink.
Feb 07, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Plugged nozzle
I took my nozzle to ink specialist and had it cleaned only cost $15.00 but still better than buying new one
May 29, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
378 people viewed this question
old marine
old marine
