Question about OKI C9300 Led Printer
Error number 172
Printer just went bump after printing 30 pages and then on the Led window . . . Service Call . . . 172:Fatal Error. I have try nothing to resolve problem because I just had the mechanics replace the transfer belt.
  • 1 more comment
  • Anonymous Apr 01, 2008
    after printing 50 A4 pages the led displayed Service Call 172 Fatal error.
    On switching off the printer and putting it on again the message did not show. But is problem has been persisting for some time now.
  • DJoye Apr 28, 2008
    Got the same fatal error this morning on my Oki C9300. Recycled the power & it went away & returned to printing normally. Signs that the fuser may be going?
  • jefreecu Apr 15, 2009
    I have also got same problem when I come back today morining. what excatly this 172 error means?? is it the end of fuser life?? please put your valuable reply. thanks in advance
Jeap is right, I had the same Error message on my Oki 9600, it would start up, spin and inititalize, and then sometimes stop with the "172: Fatal Error" messgae, or it would stop halfway through printing a docuent with same message. Changed the fuser unit and problem solved.
Posted on Sep 12, 2008
  • 114 Answers
The problem is on the fuser unit, ther thermistor on it is damaged.
Posted on Jan 17, 2007
OKI C330dn Call Service fatal Error:980
That particular error indicates a fuser failure. Try turning off the printer and re-seating the fuser. If this does not clear the message then the fuser needs to be replaced. With such a low number of prints warranty should cover it.
Aug 29, 2014 | Oki Electric Industry C330dn Led Card...
The orange lights are flashing, is there something wrong?
Try:
1 Resolution may vary based on printer driver setting. Color ink droplets can be placed with a horizontal pitch of 1/4800 inch at minimum.
2 PPM print speeds are based on the highest speed printer driver mode. Photo print speeds are based on the default mode driver setting using Canon Photo Paper Plus Glossy paper. Print speeds will vary depending on system configuration, interface, software, document complexity, print mode, types of paper used and page coverage. CPM copy speeds based on fast mode setting using plain paper. Copy speeds may vary based on document complexity, copy mode, page coverage and number of copies.
3 USB 2.0 Hi-Speed requires Windows XP, 2000 or Mac OS X operating systems. For Windows 98, Me and Mac OS X v.10.2 to 10.2.6 operating systems, the printer will operate at USB 1.1 specifications.
Oct 22, 2010 | Canon PIXMA MP150 All-In-One InkJet...
I have an OKI 5650 printer and am getting a 172: Fatal Error - how do I fix this?
Abnormal temperature
detected by
fuser thermistor
(high-temp or low
temp.)
Turn power ON again.
Replace fuser unit.
Feb 12, 2010 | OKI C9300 Led Printer
"fatal print spooler error" error message
Completely uninstall the printer driver and install again. If this does not work, there is a corruption in the windows registry or in the print spooler cache files.
For a temporary workaround, disable print spooling. But, if you do, you will need to remember to never close an application you print from until printing is actually finished.
Jun 28, 2009 | Konica Minolta magicolor 5430 DL Laser...
Service Call 172 Fatal Error
Hi stuart34:
Here is your problem.
Service Call
172: Error
176: Error
High temperature
error detected at
Thermistor.
1) Is the error message displayed?
2) Does the error repeat?
Yes
Yes
Turn off/on the printer.
Replace the Thermistor and turn off the
1 Upper roller 2 Lower roller 1
b
Thermostat Thermostat
Heater Between pins a and b:
Between pins c and d: 231.4kω
Between pins e and f: 231.4kω (at 25°C)
Between pins c and d: 0ω or open
Fuser Unit
a
b
Heater
e
f
Thermistor
c
d
Fuse
e
f
Thermistor
c
d
printer. Leave it for 30 min.
The Thermistors are located in the fuser assembly.
Hope this helps
May 29, 2009 | OKI C9300hdn Led Printer
OKI C5600 printer is printing Blank pages
you looking at 3 posibles one is the scanner may need to be replace or the low voltage power supply or you looking at a posible drum problem
Nov 22, 2008 | Ricoh Aficio 250 Copier
Fatal Error
Did you try cleaning the led heads
Apr 02, 2008 | OKI C9600hdn Led Printer
Fatal error 172
From OKI error list:
Error 172 - Upper Heater Temp State: High
Heat Roller Thermistor indicates high temp
Solution:
Turn off printer, let cool down.
If problem still exists seek service
Mar 07, 2008 | OKI C5300n Led Printer
Service Call: 173: Fatal Error
That is a fuser erron code. Abnormal temperature. You will need to replace the fuser. Sometimes I have sen a buildup of toner on the thermistor. If you can get to it. You can try to clean the toner off. Be careful. Very hot.
Aug 10, 2007 | OKI C5150n Led Printer
OKI C9300 Led Printer Logo
2,467 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
