Question about Samsung Pleomax Zirex UHD-8G USB Hard Drive
PLEOMAX 5GB Thumbdrive
My computer no longer will recognize my thumbdrive. How can I get it to work or retrieve the files from it. Thanks.
Sean
  • fadester15 Oct 17, 2008
    Thanks, I have already tried all the above solutions.
    Sean
  • bobdidit Apr 21, 2009
    I have the same problem with the Pleomax 5 GB hard drive. The green light does not turn on when connected to the USB port of any computer. I have learned that there is a problem with the electronics on the main board, and have contacted Samsung Pleomax to see if they will fix it to that I can retrieve my files, but they have not responded yet.
  • 94 Answers
Do you see a message on your system tray when it is plugged in? If you don't see any message, it means that the drive is not being detected. You can't retrieve any data or files on the thumb drive if it is not detected. Things you can try to isolate the problem:
1. Try a different USB port on your computer. Check if your thumb drive will be detected.
2. Try a different USB device like mouse on your USB port. If it is detected, it means that the problem is the thumb drive. If not, it means that the USB port is not working or is disabled.
3. Try the thumb drive on a different computer.
Hope this helps. ;-)
Posted on Oct 17, 2008
I have files backed up on a Cruisersyc thumbdrive from and old computer. Currently running Windows 7 and cannot run the LaunchU3.exe file.
You might have scan or let the windows 7 checked your thumbdrive that might be the cause that the *.exe file is destroyed or scan and fix by an antivirus software. Also the exe file may not be compatible with the windows 7. Try searching a Launchu3.exe compatible for windows 7 if unable to, manually copy the files and paste it to your new computer
Sep 21, 2011 | Computers & Internet
Tip
How To Remove A Virus From Your Computer
Requirements: On an uninfected PC connected to the Internet, download the following programs to a thumbdrive. We will need this to fix the infected computer.
Instructions:
  1. Shut down the computer as soon as you realize there is a problem. Pop-ups, program errors, dll errors, fake Anti-Virus scanners, and similar are signs there is a problem. Shut down the computer normally, or hold the power button in until the computer shuts off.
  2. Power on the computer, and hit F8 before the Windows Startup screen appears. Select Safe Mode.
  3. Login if asked to, if not select Yes to continue.
  4. Click on the Start menu, select Run, type msconfig and press Ok, or type msconfig into the Start menu search box and press Enter.
  5. Under the General tab, select Diagnostic Startup. Press Apply.
  6. Under the Services tab, check the Hide All Microsoft Services box, and uncheck any services you don't recognize in the window.
  7. Under the Startup tab, select Disable All. Press Apply and Ok.
  8. Don't restart the computer yet.
  9. The System Restore Utility backs up selected files automatically to the Restore folder. Quite often are infected files stored there as backup files, and many Virus Scanners are unable to delete these files. If you suspect your computer may be infected, it is recommended that you disable the System Restore Utility to remove the infected files from the Restore folder.Select your OS for directions on how to disable the System Restore Utility - XP, Vista, 7
  10. While in Safe Mode, insert your USB thumbdrive and open it in My Computer.
  11. Open Combofix.exe, select Ok when it asks. Let Combofix scan and remove any infections it finds. It should restart the computer when it is done. When it restarts, boot up into Windows normally.
  12. Login if asked to, open your thumbdrive in My Computer again, and run Combofix.exe once more.
  13. Open up SmitFraudFix.exe from your thumbdrive. Press any key to continue when asked. Type 2, and press enter. When the scan is complete, restart your computer.
  14. If you had a fake Anti-Virus Scanner infection, open up Remove Fake Antivirus.exe from your thumbdrive. Press Start, and press Yes. When the scan and removal is Complete, restart the computer again.
  15. Install Microsoft Security Essentials, or your choice of Anti-Virus Software when the computer returns back to the desktop.
  16. Restart if asked to, and when the computer restarts, run a Full Scan in Microsoft Security Essentials.
on Feb 25, 2011 | Computers & Internet
My computer has no cd slot how can i install a wireless G plus mimo usb network adapter.thanks
You can download the device drivers here. Once downloaded, double click the .exe file to install them. Then, your device should be ready to go!
May 02, 2011 | Computers & Internet
SanDisk 4gb Cruzer Micro USB not recognized
If you want to add that to my ever growing pile of sandisk cruzers you are welcome.
Quality from sandisk has dropped considerably as can be seen from comments on their web site or doing a google search. It is very rare that I see other brands for data recovery. The cruzers have some software of their own on the drive that can get corrupted or deleted very easily. Once that happens you may as well toss it in the garbage.
Aug 10, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Need GameBridge to install on a computer without a cd drive.
You need to utilize a program that will allow you to create an ISO copy of the CD to the thumbdrive. When you do this all the files on the USB should be removed BEFORE the copy.
Jul 25, 2009 | Adaptec GameBridge AVC-1400 (2179900)...
Computer reboots when i connect my Thumbdrive
More then likely you have a defective thumbdrive,buy a new one and see if you still have the problem, you can all ways take it back if you still have the problem, Remember new ones can also be defective.
Mar 03, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
Securing thumbdrive
Toucan is a small utility
allowing you to secure your data.(AES-256 encryption)
http://portableapps.com/apps/utilities/toucan
Jan 24, 2009 | Samsung Pleomax Zirex UHD-8G USB Hard...
Usb device not recognized
If your laptop is running Windows ME, 2000, XP or above, it should automatically do the New Hardware thing, and mount the drive. If using Windows 98se, you can probably get the drivers from the vendors web site.
Sometimes a usb port will not provide enough power for a specific device. Does the thumbdrive work in other computers? And do other USB devices work when connected to the laptop?
Feb 06, 2008 | Toshiba Satellite A135-S2276 Notebook
Acer 5100 laptop USB ports freezing touch pad
Maybe your thumbdrive is the problem try to format the thumbdrive first
Jan 22, 2008 | Computers & Internet
Samsung Pleomax Zirex UHD-8G USB Hard Drive Logo
340 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
