Question about Mach Speed MS945G-GLV Motherboard
My computer wont start, no setup, no bios, nothing...
Im building a computer using a machspeed ms945g and a intel core 2 duo, i put everything together and at the moment of fire it up i only get the processor fan on and the hard drive licks in also, but in my screen it appears as if was not conected, try my monitor in another computer and works fine, i isolated my mobo but i get the same result, i cleared the cmos moving the pin but it seems not to work, can somebody helpe me out please?
  • Francisco Vivas Oct 21, 2008
    thanks for the solution, i tried that, but it's the same result, there is nothing... may need new chip? or perhaps mobo or processor?
    any sugestions are welcome...
    thanks
Don't call glv he will sell you a bad one
Posted on Dec 11, 2010
  • 778 Answers
This is only a stab in the dark but are all your M/board fixing connected correctly
Hard drive etc.
One other way is to disconnect everything from M/board except for Video and memory and try to boot up if it does then connect hard drive etc one at a time rebooting each time until it will not boot that is the wrongly connected one
Posted on Oct 18, 2008
Problem upgrading CPU
Try to update the BIOS with the old CPU in, if not the new CPU could be faulty, yes I know it's new but it is entirely possible
Apr 19, 2014 | eMachines W3619 PC Desktop
Intel core 2 duo e4500 drivers
What is the bios number . Go by this and google search bios . The drivers are usually linked to the bios and the motherboard and hardware devices attached or integrated within the motherboard.
Go into bios setup and find bios number.
Apr 16, 2014 | Intel Cpu Pentium Dual-Core E2180 2.0Ghz...
I have used LENOVO laptop. System Information
Try looking on the Lenovo website for the Audio driver you need.
Jul 31, 2013 | Intel Computers & Internet
My core 2 duo E6550 does not work on my foxconn g41mxe motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813186187
Motherboard supports Processors with a Front Side Bus (FSB) of either 800Megahertz, or 1066MHz.
1333MHz FSB support is done with OVERCLOCKING.
http://ark.intel.com/products/30783/Intel-Core2-Duo-Processor-E6550-%284M-Cache-2_33-GHz-1333-MHz-FSB%29
Intel Core2 Duo E6550 processor has a 1333MHz FSB.
http://www.manualowl.com/m/Foxconn/G41MXE/Manual/297328
I reduced the view size to 120 percent. Go to Page 27.
Press DELete key to enter BIOS Setup.
Use Down Arrow key to highlight - Fox Central Control Unit
Press the Enter key
CPU Frequency Setting should be set to 333 (333MHz)
Intel processors are 'Quad Pumped'
333MHz x 4 = Approximately 1333MHz. (1332)
http://www.foxconnsupport.com/cpusupportlist.aspx?type=mb&socket=Socket%20775&model=G41MXE&cputype=Intel
Note the version of the BIOS program also.
Regards,
joecoolvette
Sep 25, 2012 | Foxconn G41MXE Core 2 Quad Intel G41 DDR3...
Hi I just bought a Intel Core 2 Quad q8400 for my gigabyte GA-G31M-S2L. It won't boot up!!! It freezes when I try to enter bios setup and if I do manage to get in, it freezes at the options screen. It...
What size power supply are you running? If you are not running a minimum of 400watt , I would anticipate issues with this type of processor. Since it is freezing right away, it could be bad memory. You can try memtest86.com to download a memory test tool to verify.
Secondly, you may want to reset the board by moving the jumper from normal mode to reset mode.
last thing, it's not impossible for a processor to be bad. Since it is an Intel processor; it should have a 3 year warranty on it. Any dealer who sells Intel should be able to warranty replace it for you.
Dec 31, 2010 | Intel Core 2 Quad Q8400 Computer System...
Sir mercury 945 system board interface with core 2 duo processore.how i want to set the bios set up
I am assuming that your question is how to access the bios for your pc. The most common bios entry is to hit the DEL button after switching on. If this does not work, try F2 or F1 buttons after switching on.
Other than these, I am unaware of any other methods for entering the BIOS.
Best wishes,
Graemevm
Dec 21, 2009 | Mach Speed MS945G-GLV Motherboard
F672cr(m1610)and intel core duo?
The Acer M1610 was available with the following processors: Intel Core 2 Duo, Intel Pentium Dual-Core, Intel Pentium D/4, Intel Celeron D/4 2.0GHz.
Based on this information, It is likely that you can support a Core Duo or a Core 2 Duo, however may be limited to the 2.0GHz models due to clock and multiplier limitations on the BIOS. This may be different if there is BIOS upgrades to support faster processors.
Your best option of the above listed processors will be the Core 2 Duo, however their system specifications report that only the Core 2 with 800MHz or less Front Side Bus are supported.
Also note that the Celeron 430 is a 64bit processor, so it is not likely to work on this system either.
Sep 05, 2009 | Acer Computers & Internet
Processor Error
Possibly a clock error or bios setting error. Thats an odd one !
Aug 18, 2009 | Intel Core Duo T2300E, 1.66 GHz...
No Microcode Update Loaded for Boot
It means the motherboard does not support that processor and you need to update the bios. You didn't say which Celcius you have, but the BIOS will have to come from Fujitsu.
Jan 23, 2009 | Intel Core 2 Duo Retail Boxed E7200...
Mach Speed MS945G-GLV Motherboard Logo
149 people viewed this question
Top Mach Speed Computers & Internet Experts
Justin
Justin
David
David
Abhinandan  Patil
Abhinandan Patil
Are you a Mach Speed Computer and Internet Expert? Answer questions, earn points and help others
