Question about Whirlpool Dryers
MY drier heating element shows 9 ohms continuity, it also shows 120 volts into and out of it when the drier is running. But the heating element wont heat up?
  • 5,911 Answers
Have you checked the voltage at the outlet? You're supposed to read 220-240 VAC at the heating element. Your dryer heating circuits require at least 220 VAC to work. The motor, however, only uses 120 VAC. That's why your dryer may be running, but the heating circuits aren't heating. I would go back and check your outlet. You may be missing one leg of the 220 service, or have a loose, burned, or broken wire in the plug or terminal block (on the back of the dryer). Let me know what you find. I hope this helps you.
Posted on Oct 17, 2008
When this unit runs it doesn't get very warm. I checked the elements they are good. I read 211 volts on each of the 6 elements, and 22 volts on the control side??
did u check the element for continuity?
ELECTRIC Dryer no heat or little heat:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
Mar 30, 2015 | Dryers
Troubleshoot Heating Element
Unplug the heating element. Take volt-ohm meter, set it to continuity and touch a lead to each unplugged wire on the element. If you get a reading (numbers indicating ohms) The element is good if it doesn't show continuity the element is burned out somewhere and needs replacing.
Oct 12, 2014 | Dryers
Electric smoker won't heat up
yeah you could retro fit it and hope for the best..just dont leave it unattended in use..
Jan 11, 2014 | Bruce Foods Cajun Injector Creole Garlic...
How do I test the heating elements on Bosch Powerstar AE125 with multimeter
Product manual shows electro-mechanical thermal cutout page 9 but offers no troubleshoot steps except to say that overheating is cause.
http://waterheatertimer.org/pdf/Bosch-AE115-AE125_manual.pdf
http://www.bosch-climate.us/files/201009211859150.EP-23_Removing_and_replacing_element_assembly.pdf
Test elements:
Remove both wires off element.
Set multimeter to read ohms.
Watt and volt rating appear on side of each element.
Ohm = Volts squared divided by wattage.
For example:
Assume 240Volt circuit (240 Volts squared = 57600)
Assume 9000 watt element > check side of element for rating.
So 57600 divided by 9000 watt element = 6.4 ohms
http://waterheatertimer.org/images/ohm-reading-for-emements.jpg
Have you de-limed this unit?
Is there a check valve causing closed system in the plumbing, that might also cause decreased water flow?
Are there reduced-flow faucets or clogged aerators?
What happens when suspect cut-out element is no longer connected? The unit should continue heating.
Sep 25, 2012 | Bosch PowerStar AE125 AE125 Whole House...
Dryer operates perfectly except there is no heat. What do I need to replace or look at? Thanks
You can look at something simple first. Do check the household power if you have fuses then maybe one can be blown if you have breakers switch off and back on if still no heat then you can look to a thermal link depending on the style of dryer if you have a back panel that is held on by 9 screws unplug the power cord from wall then you, will need a OHM meter and set to read Ohm's remove the wiring on the white 1 1/2 long plastic piece to see if you have a reading if no replace the thermal link. Then if good then unplug the wiring to the heating element and check for a reading good? Then put wires back on and up from the heating element there is a stat unplug take a reading if none replace the thermal cutoff kit. And after that being said if no back panel then you front type disassembly is different but check the same described items.
Apr 02, 2011 | Kenmore Dryers
Bottom element not working what can i check can it be a fuse or how do i know if it is the element itself
there are no internal element fuses, check the element for any "HOT-SPOTS" dis-colored areas where it may break if not heating or partially heating,an ohm-meter will show this, make sure BOTH your input power legs are there so you have 240 volts first it won't heat on 120 volts
Nov 04, 2009 | Ovens
Dryer works but no heat, have a multimeter but need to know how to use and what to test
no heat at all? open front to access heater box, set meter to ohms. (unplug dryer), test for continuity across element connections. (disco at least one wire at each part to ensure accurate results for each check. then reconnect when done) some ohms is good here. if OL on meter then its open/bad. check each thermostat on side. they should all be 0 ohms. post results.
At terminal block in rear check voltage while plugged in. set meter to volts AC. each outside terminal to center should show 120 V approx. then together 240v. if 120 only on one side or one side significantly less than 120 then check outlet. Missing one phase/leg of supply can cause motor to run but no heat.
May 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Powers on wont heat lg dle2532w
better to unplug the unit for an hour.
Mar 23, 2009 | LG DLE2532W Electric Dryer
Dryer does not heat
Verify 220 volts at the terminal block where the cord attaches.
Also, 120 volts from each leg to neutral at the same check point.
Check the thermal fuse at the top of the heat element canister for continuity.
Check the high limit switch at the heater terminals for continuity.
Mar 12, 2009 | Kenmore Dryers
Dryers Logo
69 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
