When I put the washing machine (Hoover Six 1100) on it takes the water into the drum then nothing happens. There's a kind of clicking noise at the switch as if it's trying to do something. I have tried to start it on every programme without success.
  • 139 Answers
Hiya
the problem with your washing machine seems to be that once the water has entered the machine it is not going on to turn the drum. This Probelm is that the carbon brushes on the motor are worn. If you remove the back panel you will see the motor at the bottom of the drum. remove the motor and and you will seee two black holders either side of it remover the screws from it and replace with new ones.
hope this helps please rate if it helps.
Cheers Washdoctor
Posted on Oct 17, 2008
Can any body tell me what size the front drum bearing is for a hoover softwave 1100 ,model No A8754 washing machine is ?
You can buy a drum bearing kit on the net or from Espares.co.uk depending where you are..Some kits are sold as a Half drum with prefitted units quite Expensive......
Feb 10, 2011 | Hoover Washing Machines
Hoover performa 1100 ac110 not emptying
After syphoning water out of drum, remove and clean filter located at bottom front left of washer, if there is a screw in the filter cover, unscrew this first.
Remove filter by unscrewing anti-clockwise.
Feb 06, 2010 | Hoover Washing Machines
Washine machine fills but drum does not turn
hoover hd 1400 aaa motor turns and so does drive belt but the drum doesn't? what is the problem?
Sep 25, 2009 | Hoover Washing Machines
HNF7167 Hoover Washing machine no spinning
how do i put the belt on my washing machine
Dec 07, 2008 | Hoover AAA160 Front Load Washer
HOOVER 500M0AUS WASHING MACHINE
I have a Second Hoover HTC243 , I don't have the user manual . I don't know how to use it , can u tell me how to use it
Aug 15, 2008 | Hoover HTC243 Top Load Washer
HOOVER WASHING MACHINE
I have found a solution in a UK website. Machine fixed.
Jun 09, 2008 | Hoover Washing Machines
Hoover 800el not spinning
hi all, I have a hoover 800el washing machine and it's making a clicking/ratchet noise. any idea what's causing it?
Kind regards
Louis
May 18, 2008 | Washing Machines
Washing Machine Hoover H100M fills too much water in the drum.
this is 1 of 2 solutions  2 this problem the first thing to check is the vacuum system or it is a split in the pressure switch hose
Mar 05, 2008 | Hoover AAA140 Front Load Washer
Hoover washing machine HF7160E
I am a recently retired appliance engineer of 20 years, and this at first sounds like motor carbons, the belt needs to be placed on from the bottom motor pulley first the onto the drum pulley last, not easy to describe in words, anyway start with the carbons, then if they ok there is a module (main PCB circuit board) normally on Hoover washes located top of machine inside front right corner in a plastic casing, look for burn marks. work safe with electrics, always unplug first
Sep 09, 2007 | Hoover HF7 160E Front Load Washer
Washing Machines Logo
78 people viewed this question
Top Washing Machines Experts
Richard Roth
Richard Roth
