Question about Panasonic Toughbook 34 PC Notebook
Upgrading Panasoic Toughbook model CF M34
I have 3 Panasonic CF-M34 acquired at an auction. They have the HDD removed. They will boot up to BIOS and may ask for a password, which I don't have and say, '...Operating System not found'. I try to install Windows XP by using a remote disk drive, but with no way to load the software for it the system reports "PXE-61: Media test failure, check cable..." Catch 22.
I have also acquired the hard drive for this model but when I try to load the software still no joy.
ToughbookNovice
  • ToughBookee Oct 17, 2008
    BIOS is compatible with Windows XP
    I have 3 Panasonic CF-M34 acquired at an auction. They have the HDD removed. They will boot up to BIOS and may ask for a password, which I don't have and say, '...Operating System not found'. I try to install Windows XP by using a remote disk drive, but with no way to load the software for the drive, system reports "PXE-61: Media test failure, check cable..." Catch 22.
    The CF-M34 is a small scale laptop and does not have a CD ROM drive.
    I have also acquired the hard drive for this model but when I try to load the software still no joy. BIOS is compatible with Windows XP
    Brigadier General:
  • 6,966 Answers
Might this help?
Hope that this be of initial idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 17, 2008
    Sergeant:
  • 352 Answers
Hi tough,
reboot, before it asks for pw hit the F button option for entering BIOS setup. Once in change what ever you want i.e. password boot options etc...
anaanymous
  • anaanymous Oct 17, 2008
    p.s. the setup F button option screen goes by quickly so be ready to act.
    anaanymous
    Sergeant:
  • 320 Answers
You need to remove the bios password.. In desktop systems you can remove cmos battery from motherboard and clean the password. but in laptops and in other types you need to short the jumpers. for that please click on the below link and follow the image.
http://images.google.co.in/imgres?imgurl=http://www.pcbuyerbeware.co.uk/ClearCMOS.gif&imgrefurl=http://www.pcbuyerbeware.co.uk/ClearBIOS.htm&h=728&w=546&sz=18&hl=en&start=3&um=1&usg=__LxchryVCJTZvmufhnbWSIKWT2Ls=&tbnid=_x_3clEXoNn4oM:&tbnh=141&tbnw=106&prev=/images%3Fq%3DMotherboard%2Bmanuals%2Bfor%2Bjumper%2Bsettings%26um%3D1%26hl%3Den%26client%3Dfirefox-a%26rls%3Dorg.mozilla:en-US:official%26sa%3DG
or else Install operating system from a CD-ROM.. in which you do not require any password.. you better install it from CD-ROM.. Its very easy also..Have any queries, please let me know..
Thank you.........
    Master:
  • 505 Answers
First you need to flash the BIOS by disconnecting the battery on the motherboard.
2. Connect the battery again. Go to BIOS. Select the first boot device as CD ROM. Also you have to make sure that the Hard drive is connected to the motherboard and it has to be a primary drive. Also the Hard drive should show in the BIOS.
3. Once done save setting of the BIOS. Also insert the Windows XP installation CD
4. Once the computer restart you will get the option 'Press any key to boot from CD'. We have to be very fast in pressing a key.
5. It will start booting from CD. Accept the licent agreement. Click on fresh install. Format the drive using NTFS Quick and start installation. While installing you will get the window which will ask for regional and language setting. You need to make sure to select correct date and time.
6. In the network wizard select standard and the installation will be successfull.
7. Please go to www.windowsreinstall.com for the different screen you will get during installation.
Thanks.
  • 1,879 Answers
You got to have the BIOS password as the laptop is now set to boot from a network, hence why PXE is showing up
  • Panasonic Master
  • 19,396 Answers
You need to install XP using a CD rom, it wont work from a remote disk.
  • 3 more comments
  • Ginko
    Ginko Oct 17, 2008
    First remove the bios password, to do that you need to remove the cmos battery mounted on the motherboard and put it back.
    Here is a picture of the battery:
    Once you can access the bios, set it up for starting from CD (in boot sequence put CD first), then install Windows from a bootable CD.
    An alternative ismaking the hard disk bootable, and copying into the HDs a copy of all install files, but that is more complicate.
    See also
    Repair4Laptop: How to Upgrade, Repair, Disassemble a Panasonic ...
  • Ginko
    Ginko Oct 17, 2008
    "I try to install Windows XP by using a remote disk drive"
    That won't work, that is all.
    "PXE (pronounce Pixie) is an agent used to boot on to the network
    It's using the DHCP protocol to localise a server where the image of the OS is located
    In order to PXE boot press F12 at startup or configure the boot order in BIOS to display 'Network' before 'Hard Drive C:'
    If, for any reason, the hard drive is not seen the computer will attempt to boot on the network controller.
    That is caused by the hard drive is missing, unplugged or failed "
    That is because you use an external HD to install Windows, and by the way what kind of external HD do you use?
    I amj tired of typing info for askers that do not bother in reading
    bye
  • Ginko
    Ginko Oct 17, 2008
    More, you need the HD to be seen in Bios first, you need to access bios, reset bios password to proceed.
  • Ginko
    Ginko Oct 17, 2008
    If you do not have CD rom you have few choices:
    1 You buy an external CD rom for Panasonic CF-M34, that is difficult to find even on Ebay, but have a look.
    2 you mount the HD on a different laptop, setup system, then mount the HD back on the Thoughbook, install drivers and other stuff using a usb disk.
    3. You find a boot floppy and perform a network installation.
    We are talking here of a laptop that is over five years old, I do not think this laptop has Bios drivers to install the system from a usb removable disk, that is probably the reason why you get the error message.
  • Ginko
    Ginko Oct 17, 2008
    another solution, that will work, and is relatively easy to do, is the following:
    Connect the HD to a different computer, using an adapter or a USB 2.5 HD caddy, Copy the wole content of a Windows XP SP1 , or win ME/98/2000 setup disk on the HD. Do this on all 3 HDs.
    Put back disk inside Pana Thoughbook.
    Start the Toughbookusing a boot CD, then from dos browse the HD and start setup.Exe.
    This wont work on Vista or some XP sp2.
    Master:
  • 538 Answers
Ok...well..that may mean that the bios and operating system are incompatible...can you provide the revision of the bios and the operating system and we will see if they match up?
  • 1 more comment
  • A Womans Computer Man
    A Womans Computer Man Oct 17, 2008
    drive compatibility is rarely solved by attempting to install software that is potentially incompatible with the bios. the equipment you have, may not be compatible. i find the rating to be oddly configured..good luck with this one.
    hmm..best solution...????..did you make that decision, mr asker?
    what type of hard disk to you have`? this is rarely as easy as one might think.
Remove bios password for a panasonic toughbook cf-30k
  • Press "F2" on your keyboard when you see the Panasonic logo appear on the screen. You will immediately be prompted to enter your Panasonic Toughbook Cf-29 BIOS password. Type the word "Biostar" into the password prompt. This is your Panasonic Toughbook Cf-29 backdoor BIOS password. Press the "Enter" key to unlock your Panasonic Toughbook Cf-29 BIOS.
  • Mar 10, 2014 | Panasonic Toughbook CF-30K (CF-30K3PAQAM)...
    Swapped out hdd cf-52 nothing happening
    When you swapped out the Hard Disk Drive
    of the Panasonic Toughbook CF52 it is very
    importatnt that you did not "hot" swap the HDD
    but that you turned off the unit with a full shutdown
    and unplugged it as well.
    Once you removed the Hard Disk Drive (HDD)
    I am assuming that you replaced the drive with
    another drive that had a proper operating system
    already installed. If not, then of course nothing
    happened since you replaced the HDD with a blank
    or unformatted HDD.
    One way to verify if the replacement Hard Drive
    is recognized by the Toughbook is to go into
    the BIOS by pressing the F2 function key and
    checking the size or capacity of the replacement
    Hard Disk Drive. If it shows the proper value,
    then the HDD is recognized at the Hardware Level.
    If it shows HDD as None or Zero then the replacement
    HDD is NOT recognized and you have to try a different
    drive which is functional.
    Good Luck!
    Regards,
    Richard - Montreal Based
    Panasonic Canada Toughbook Authorized Dealer since 1989
    Nov 08, 2013 | Panasonic Toughbook CF-52 (CF-52ELNBDAM)...
    Cf-30 disable touchscreen
    On all Panasonic Toughbook Notebooks,
    you must get into the BIOS by pressing
    the F2 Function key when you turn on the
    Toughbook as it is booting. Press F2 repeatedly.
    This must be done in the 1-2 seconds before
    Windows starts to load. Then you will see
    Touchscreen usually on the 2nd page with the
    word "Enable". Simply select enable and press
    "Enter" and the choice between enable and disable
    will appear. Then select "Disable" with the cursor
    and then press Enter. Finally you need to
    "Save and Exit" the changes in the BIOS.
    That is it. Good Luck to you.
    Regards,
    Panasonic Toughbook Authorized Dealer since 1989
    Nov 13, 2012 | Panasonic Toughbook CF-30 Notebook
    I have a Panasonic Toughbook CF-28 Mk III P3 1Ghz 512Mb Ram , I have installed a brand new DVD rom Drive in the MP Bay it reconises in bios also reads upon first post however, will not boot from any os cd...
    Some bios menu allows you to boot from USB. (Some are locked this option by makers.)
    Run safety mode and try again to see whether your DVD rom is working.
    Best way will be go to device manager; go to properties of DVD rom; go to driver and click roll back driver.
    If this is not working (in case), uninstall driver and reinstall it.
    May 29, 2011 | Panasonic 30gb laptop hard drive for...
    I have panasonic toughbook laptop cf-73 and i forget bios password now what i do?
    RESET BIOS JUST REMOVE BATTERY AND DISCONNECT FROM POWER .. ALSO DISCONECT BIOS BATTERY TO RESET BIOS , AND BIOS PASWORD
    Nov 25, 2010 | Panasonic Toughbook CF-73 Notebook
    My Panasonic Toughbook T2 was shut down properly and kept for about a month. now it does not boot. Even inital BIOS check function is not performed. Though HDD movement can be heard. Checked RAM by...
    Is there any chance the video output is switched to feed the rear VGA connector? ie the screen is black due the video being routed away from the screen. Try hitting F5 key.
    Can you hit the Delete key to try and enter the bIOS screen? (it may be another key such as F1 or F2. See your Toughbook manual)
    Can you have someone make you a bootable USB thumb drive and try booting up with that?
    Its also possible that the hard drive has failed, but usually the BIOS POST check will initiate and indicate a failed hard drive or bad RAM etc
    Can you remove the 2.5 inch hard drive? Usually its accessible under a removable panel under the laptop.
    Feel free to ask more questions.
    Cheers,
    Steve
    PS have you tried the discussion forums on the Panasonic website?
    May 03, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
    Panasonic cf-50
    go to panasonic.com and download a bios update to a floopy then turn on your comp hit f2 to bring up your configs select boot then boot from floppy then restart your comp
    Dec 09, 2008 | Panasonic Toughbook 50 Notebook
    Panasonic Toughbook 34 PC Notebook Logo
    1,654 people viewed this question
    Top Panasonic Computers & Internet Experts
    Oloyede Monsuru
    micky dee
    Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
