Question about Acer AL1916W 19" LCD Monitor
Monitor problem The monitor was working just fine. Now it won't show anything on screen.I checked it out on several computers and it still doesn't show anything. When I turn it on the green light comes on then it shows the orange light. It never shows the acer logo when turned on. My cables are ok cause they work fine with other monitors. This monitor is only few months old so it can't be old age
  • Fran Bednar
    Fran Bednar May 11, 2010
    A few months old !!?? Should be warranteed ??? How long (Time it ) till the blue turns to yellow ?
    Champion:
  • 293 Answers
Hi...there,
It's turns blue to power safe mode (yellow) it's prevent futher damaged to your monitor. It's seems you got a busted backlight inverter. Need to replaced a new one...Since you only got it for a few months, send it back to Acer for a replacement of a new backlight inverter... Have a nice day!
Posted on Oct 17, 2008
The monitor was working just fine. Now it won't show anything on screen.I checked it out on several computers and it still doesn't show anything. When I turn it on the green light comes on then it shows the orange light. It never shows the acer logo when turned on. My cables are ok cause they work fine with other monitors. This monitor is only 1 year old so it can't be old age
Posted on Nov 25, 2008
My dell inspiron 2400 won`t come on .it does not show anything on screen.
You first need to check the screen is working, disconnect the VGA/DVI cable from the monitor, then turn it on do you get anything on screen at all?
If that works reconnect the cable and turn it on, now boot the PC, do you see anything at all on the monitor?
No then check the cable/swop with new one or check the graphics card.
Yes but goes off after a few seconds, reboot and press the F8 key as soon as you hear the first beep, this should bring up a start menu, try safe mode, if that works load and windows it might be the graphics driver (has this been updated?) if yes try roll back to previous driver or you could even try system restore back to a date you know it all worked.
May 19, 2014 | Dell Inspiron 530s Desktop Computer
My hp v75 monitor doesn't come on. All the lights
Make sure the VGA cable is properly inserted to your pc and monitor
Jun 29, 2012 | Computers & Internet
Lcd monitor clicking
Hello
According to your detailed description, there are two chanses for this fault. Either its LCD panel of backlight inverter baord has some kind of short circuit. Detailed troubleshooting should be done. It is a highly skilled work. OK.
Feb 07, 2012 | Computers & Internet
Coby tv will not come on
Died and went to monitor heaven. U can always check out the power supply. But other than that you may need to go shopping.
Jul 28, 2017 | Coby 20" Flat Screen TFT LCD TV Monitor
My computer's tower turns on but it doesn't display on the monitor, the monitor shows the normal Self test box so the monitor doesn't seem to be the problem. Also when I press the power off...
Make sure that the cable is connected from your computer to the monitor, and if it is wiggle it and push it in all the way. If it has screws, screw them in. If that does not work, check that your monitor is on the correct input (if it has multiple) then see if anything comes on the monitor. If nothing happens you should buy a new cable from the store. If all of those steps do not work your computer or your monitor might have a more serious problem.
Jul 29, 2011 | Computers & Internet
I got this monitor off of craigslist "because it didn't work". The VGA has never worked, but the DVI worked fine for several months. Recently, the screen goes black, the screen shows a 'no...
Check the VGA output pins on your computer. Install a different monitor and see if it works on your computer. Or it could also be the VGA cable (pins) on the monitor is loose.
Dec 16, 2010 | Neovo E-19A 19" LCD Monitor
My monitor screen is black and the yellow standby light is blinking. I can not get the light to stop blinking or get the monitor to show anything, but a black screen. What can I do to coerrect the problem?
mcdevito75 here, Press the SHIFT key, a screen should come up telling you too click on your user name, left lower side of screen. If this doesn"t work, press the yellow blinking light on the monitor see if picture comes back, then follow the directions. If this doesn"t work, shut computer down with switch on the computer itself. Hope this helps.
Jul 17, 2010 | Acer Computers & Internet
I am trying to connect VTM-Lcd143 monitor to my computer and the screen doesn't show anything except the adjustment on the screen ... what can I do to make it work ?
Does the monitor have multiple inputs on the back of the panel? For example, there will be the power input, and at least one other input (Blue 15 pin or White DVI).
This could be a matter of the wrong input selected from your monitor's menu. I have seen this issue personally several times. Please check the settings and change the input.
If this does not work, please update this issue with the requested information. Look forward to hearing back from you.
Feb 26, 2010 | Vitek VTM-LCD143 14 inch LCD Monitor
LG LCD Monitor won't exit Power Saving Mode
Does your desktop/PC display show anything before the monitor goes into power save mode? If nothing comes up, its possible that you have a loose VGA connection or that your video card/motherboard are defective in some ways. Try using a different monitor.
If the other monitor works fine with your computer, try changing/lowering the screen resolution. If in XP right-click on the desktop and go to Properties, and select the tab for display settings and adjust the resolution. If in Vista/Win7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there. Then check and see if your LG monitor works on it.
If the other monitor also doesn't show any display, most likely the problem is either with your video cable or your PCs video card/motherboard, not the monitor.
Hope that helps. Good luck
Feb 15, 2010 | LG Computers & Internet
I have a samsung Syncmaster 2343 and I can turn it on just fine and my computer recognizes that it's hooked to a moniter but the moniter shows the screen for a few seconds and then it all goes black. It's...
If your up to opening the monitor it would do you well to look. It sounds close to what I experienced.Refer to Problems with Samsung SyncMaster 2053bw for info on opening.
Nov 11, 2009 | Computers & Internet
Acer AL1916W 19" LCD Monitor Logo
429 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
