Toshiba 36ZP picture frame shake - Televison & Video
Toshiba 30HF84 Picture Doubling and Shaking
Check its main power regulator section for any faulty capacitors.
Sep 01, 2012 | Toshiba 30HF84 30" TV
Hi i Have a Toshiba 50H82 all the colors is good but the picture is really blur and shake, does someone knows of to fix it, im not shure if its call the tuner of the tv....
If the video is shaking, zig zag looking, etc your hypermodule has failed. This is common on your model. Some peeople call it hyper board, hyper module, etc..all the same.
You can get a repair kit for this from www.TvRepairKits.com
Oct 19, 2010 | Toshiba 50H82 50" Rear Projection...
Picture comes out blurry and there appears a hand that appears to be shaking in the top left hand corner of the picture screen
Hand shake means shutter speed is too low to avoid blurred picture(due to low light)
Either increase lighting or
Use flash and turn it on or use higher ISO setting or
Use lowest aperture number.
Last when there is nothing moving in the frame you can use tripod at any P.A.S settings in any lighting
Jun 27, 2010 | Kodak EasyShare V1003 Digital Camera
My toshiba 42h83 has a shaking picture with a 2 to 3 " green stripe at the top of the screen. How can I fix this?? thank's Karl
Check all wires cables go to the tv,shakes,jiggles might,see the prob.than change the wires cables.Not wires cables,than ur main video board is the prob.must change.
Oct 27, 2009 | Toshiba 42H83 42" Rear Projection...
Have sony 36 trinitron about 5 years or older..the picture just shakes. never lose the picture or the sound. just cant get it to stop shaking.
U have magnatic degausing coil problem.Take the tv aparts,there a solid back coil all around inside the front frame of ur tv.That the cause,unplug that coil,should not effect the tv pic if have no magnatics problems.
Feb 22, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
TV picture shaking!!!
You have a Hyper module problem.Very common with these chassis.Toshiba part # 23148024.This part is no longer available,but it can be repaired.I dont know how much electronics training you may have but it`s a pretty detailed job.The hyper board is the silver stand up module inside the unit right behind the external Audio/Video jack panel.There are 11 little capacitors that all need to be replaced.The value of these caps are 10uf @ 16VDC.I do this job for about $245.00 and the unit works fine.Check with your local shop if it is too much for you.If you don`t know what you are doing you can ruin this module then it`s time for a new set.Good luck.
Jan 15, 2009 | Toshiba 42H82 42" Rear Projection...
Television response.
Its the IR sensor. You could go the DIY router and solder a new one back on, or buy an add on one if your set accepts it.
Oct 05, 2008 | Toshiba 36A40 36" TV
Violent shaking picture initially but slowly tapers off but still shakes
Do you have a service manual for your tv? If not I would suggest you get one because there could be several things causing this I will post a website whre not only can you get a manual for your tv but they also supply free online tech support to help you troubleshoot and fix your problem
http://servicemanuals.vstore.ca/
May 06, 2008 | Toshiba 50H72 50" Rear Projection...
Tw40f80 toshiba
YOU SHOULD CALL YOUR THE TOSHIBA COMPANY FOR THEM TO FIX IT.
Jan 16, 2008 | Toshiba TW40F80 40" Rear Projection...
It sounds like the Hyper board is begining to fail....Does the menu shake too?
May 16, 2007 | Toshiba 50HX70 50" Rear Projection...
Televison & Video Logo
128 people viewed this question
Top Televison & Video Experts
