Question about Sceptre X37sv-Naga 37 in. LCD Television
Sceptre X37sv-Naga 37 HDMI port is not making contact
Recenty, my Sceptre X37sv-Naga was not making good contact through the HDMI port giving me no picture or sound through that port. I could get it to sometimes work by manuevering the HDMI cable connector. Has anyone else seen this problem? Sceptre wants me to send it back to them because I have 1.5 months warranty left but if anyone knows how to fix the issue, it could save me the shipping costs.
David
  • 4 more comments
  • jsmithos2 Nov 29, 2008
    I have the same problem. The HDMI cable connection works some times and some times it doesn't. I was told by Septre that they would charge $200 to fix it but know guarentees. So I decided not to use it but would like to get it fixed. Does anyone know what the problem is. I will try to fix it myself since the power just went out on me and I think it is a power supply problem.
  • Anonymous Jan 23, 2009
    The soder job on their HDMI input sucks and breaks if you are not easy with it resoluting in loss of HDIM port because of bad or no conection.....
  • Anonymous Jan 30, 2009
    I have Sceptre X42GV-Naga (42" TV 1080p with Media Box). It has two HDMI ports, and neither of them works. Someone else had said that they had the same problem and fixed it by opening the media box and connecting some loose wires. Can someone tell me what to do?
    Thanks -JD
  • USMC82 Mar 03, 2009
    I have the same problem with my Sceptre X42 , both my hdmi ports do not function neither does the component cable ports.
    If someone has the instructions on how to fix this by opening the media box, please share, SCEPTRE is not helpful at resolving this issue and they want extra money. I wont be buying with them again, just purchased this tv 1 year 9 months ago. So annoyed, would like to experience this tv in hd quality, if anyone has the instructions on what wires to soder/fix, please share.
  • Anonymous Mar 04, 2009
    hdmi port has never worked on my x37. any suggestions?
  • spaznrq Mar 08, 2009
    I have the X37sv-naga as well with the same HDMI problem. It worked before for a bit, but as I used it more, it began working intermittently, and finally, HDMI broke completely.
    The problem seems to be a very loose HDMI connector. There simply isn't enough physical support for the port to handle the force experienced by tugging, pulling, or other pressures on the HDMI cable, therefore, breaking the connections of the connector to the circuit board.
    I seriously urge anyone with a working HDMI to STOP using it unless the port is reinforced (by Sceptre if still in warranty). Since my TV is out of warranty, I have to resort to trying to fix it myself. I currently don't have a solder iron tip small enough to fix it myself, but if you are inexperienced in working with electronics, I wouldn't suggest anyone doing it yourself due to breaking anything else or worse yet, risk of shock.
    Problem Solver:
  • 6 Answers
Hd EZ lock by Blue Echo Solutions is a Universal HDMI Locking Adapter, the only one on the market. It works with most HDMI Cables and components and attaches to your component's chassis, using the existing screw above or below your HDMI Input or with the supplied adhesive. It supports your HDMI Cable from the component's chassis, eliminating stress on your HDMI Input and keeping your HDMI Cable in place. www.blueechosolutions.com
Posted on Jun 28, 2009
SOURCE:
Reset color on Sceptre X 37
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 23, 2016 | Sceptre X37sv-Naga 37 in. LCD Television
How can i get sound on my computer from Sceptre flatscreen tv
If your Sceptre TV has audio output connections (often RCA connectors), you need an adapter cable with RCA plugs on one end and a miniature stereo plug on the other to connect to lhe LINE IN input of your computer's sound card
Aug 11, 2013 | Sceptre X37sv-Naga 37 in. LCD Television
Where can I get a Audio/Video cable and Power Cord for my Sceptre 30' LCD TV-X30SV-NAGA III?
They should be fairly generic and most major electronics stores should have them.
On the internet in North America look at MCM or Suburban Electronics as both carry a lot of these items.
Dec 21, 2012 | Sceptre X37sv-Naga 37 in. LCD Television
Picture upside down
Most likely a software/firmware issue---You need to contact the maker to find out if this set has updates or if this is a known issue in the model you have---seen this before= upside down or even backwards etc.
May 03, 2012 | Sceptre X37sv-Naga 37 in. LCD Television
Light comes on like itnhas power , but no display
Blue light keeps flashing as though it is on but no picture or sound and it does not turn off
May 13, 2011 | Sceptre X37sv-Naga 37 in. LCD Television
I lost the remote control to my TV. It is a 42in flat screen Sceptre. my e-mail address is: [email protected]
Hi just ring the manifacturer and they will post you one out it costs from 5 to 20 pounds hope this helps please give thumbs up thanks
Feb 13, 2011 | Sceptre X37sv-Naga 37 in. LCD Television
Where and how can you get a scepter x37sv naga power supply board?
Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power board.These two websites have the most exstensive tvs boards for the LCD and Plama tvs aruond.
Oct 16, 2010 | Sceptre X37sv-Naga 37 in. LCD Television
Damaged plastic screen cover of my flat panel LCD. Anybody have any fixes? T.V. works great but blemishes on plastic can be seen. I'm wondering if a new screen cover can even be bought. Sceptre X37sv-Naga...
most lcd/led tv,s the front panel is the display you can try polishing the screen with very fine abrasive like jewelers rouge or your local car dealer sell plastic polish to remove scratches from plastic headlamp lenses if not its a new display a new tv is poss a better option. i have used silver polish to rejuvinate car headlamp lenses to good effect
Dec 13, 2017 | Sceptre X37sv-Naga 37 in. LCD Television
Sceptre X37sv-Naga powers on no picture
Do you get sound? If you do, then the problem will be in the backlight inverter board. You should have 24vdc presents on the main power supply which supplys the power to the inverter board. Please verify that is the case.
Nov 02, 2009 | Sceptre X37sv-Naga 37 in. LCD Television
Sceptre X37sv-Naga 37 in. LCD Television Logo
1,627 people viewed this question
Top Sceptre Televison & Video Experts
leeboy3909
Level 1 Expert
Jaime Hernandez
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
