Question about Samsung SyncMaster 955 DF 19" CRT Monitor
Shaking Monitor When I turn on my monitor, it shakes really bad. What could be the problem and how might I fix or correct this problem? Thank you
  • 3 more comments
  • Anonymous Jan 08, 2008
    when i turn on my monitor it shakes so badly. I even don't know what i need to do. my monitor is HP 7550
  • Anonymous Apr 05, 2008
    Monitor shaking
  • Anonymous Aug 25, 2008
    Solution #2 fixed it. I had apowerboard at the back of the Monitor plus a sub-woofer speaker which I have now relocated.
    Thanks for the help.
  • Anonymous Sep 05, 2008
    Shaking every couple secods its ver anoying...
  • barajas3495 Feb 08, 2009
    i have the same problem
  • 4 Answers
I had the same problem when I reached in back of my pc and disconnected a web cam from a usb port. Them my monitor started shaking and i thought it was related to the web cam unplugging from the usb. I tried uninstalling my video card driver, and re-installing. Still no fix for the shake. So i tried turning off the monitor, and removing the monitor cable from the back of the pc. I re-attached the monitor cable, and powered on the monitor. Bam! No more shaking, all was good with monitor picture. The problem is, and was, as i unplugged the web cam usb plug from the usb port, i bumped into the monitor cable near where it plugs into the pc port. The problem is that there is a weak solder joint in the motherboard in the video card holder socket. I will need to either find the weak solder joint, and fix it, or replce the motherboard. I have a older dell antique dimension 8100 that i still like. It is the original motherboard and it is from 2002. I know i should replace this old pc, but i have done a lot of upgrades on it, and has been a great old pc. After shelling out over $2,000 for this unit in 2002, i want to keep running it. It does all i need to do. They don't build pc's this solid anymore. I hope this helps someone. Thank you!
Posted on Feb 02, 2010
WOW, something so simple and i was about to get a new monitor, I like my HP p720 monitor a lot and it started shaking bad, thanks to the tip, i have removed my speakers and the monitor works like new again
Posted on Mar 09, 2007
I had the same problem and it was because my power board was sitting too close to my computer. Moving it up a shelf fixed the problem immedietly.
Posted on Nov 05, 2007
It may be due to shorted main filter capacitor, or due to disturbance any mobile or any other electronical gadget, so check it and place far to monitor.
Posted on Aug 07, 2006
  • 215 Answers
Do you have anything sitting very close to the monitor which runs on mains power apart from your computer. I've seen this many times when my old apprentice put two monitors together almost touching. The screens shook like they were jelly. Unscreened speakers (mains powered) DVD players or virtually anything sitting close to the monitor which runs off mains power will cause it unless it's screened. Sometimes moving the offending item 6 inches away can stop the shakes. Other units may need more distance. If it's not that then you have a repair shop to visit. BMW
Posted on Jun 02, 2006
  • Anjanette Mable-Spencer
    i was about to throw out my monitor all because i had a small desk fan next to it that caused all the shaking
Shaking Monitor
Posted on May 06, 2011
Just turn down the refresh rate.
Posted on Jun 03, 2008
Its probably the degaus causing what you describe as "shaking"
Posted on Feb 02, 2007
I experienced a similar problem on a Dell computer from which someone deleted the video card drivers. I found that by reducing the refresh rate under Display Properties, Settings Tab, Advanced button, corrected the problem.
Posted on Jan 24, 2007
HAHA!!!He doesn't read his manual.This isn't a problem.This is a function on most every CRT monitor of LG.It's called Degauss and it serve тo remove magnetism from a device like your monitor.Other monitors have this function in their menus,LG just got better solution.That's all. ^^Galio^^
Posted on Jan 25, 2007
2 Suggested Answers
dan231
  • 236 Answers
SOURCE: picture on monitor is shaking
Make sure you have no fans, radios and type of magnet around yuor monitor.
Then check to see fi you can change the refresh rate to see if that helps.
  • Right-click desktop
  • Go to properties
  • Settings
  • Advanced
  • Monitor Tab
Posted on Dec 12, 2008
When my pole saw is extended it is shaking really bad runs fine when it's not what could this be ?
I am assuming you have checked all screws are tight. Unfortunately a tiny shake in your hand ince travelled the distance of the saw will turn into a large shake by the time it gets to the end. Make sure your holding it correctly and if all else fails it could be a slightly bent bar which is very dangerous to use.
Feb 26, 2015 | Garden
My Acer 21.5'' wide screen monitor shakes when I
Get a better stand to hold the monitor. There is nothing wrong with the monitor, it's the operator.
Jun 24, 2011 | Acer Computers & Internet
I have a 1440x900 21" soyo monitor SHAKING!!!
please boot on the safe mode. you can adjust it there on its default settings.
Mar 05, 2010 | Soyo DYLM1788 Monitor
HP L1906 flat monitor
why not test the monitor on another PC
works there good.,
if not the monitor is bad.
can be monitor bad, cables bad, power pack if fitted bad.
test it on another PC.
win
if bad monitor start a post how to fix a bad monitor (endless answers)
Mar 20, 2017 | HP vs19 (Silver) 19" LCD Monitor
1995 Toyota Corolla Shakes at freeway Speeds?
You need to have your alignment, cambering diagnosed for you to know the real position of your four tires. yes you really need to check the tie rods.
Heating up the metal would most likely damage your paint and anti corrosion properties of your metal, try re-aligning the doors hinges by loosening the screws enough for the door to move, dont dismantle it.
Nov 18, 2008 | 1995 Toyota Corolla
Samsung, SyncMaster 1100MB
Hi idil that is very simple
in only 4 conditions the monitors shakes like that they are
1. Give 1 feet gap between speakers and the monitor
2. Give 1 feet gap between Ups and the monitor
3. Give 6 feet gap between all the radiation things
4. Check the power voltage up and downs
Thank you
Apr 16, 2008 | Samsung SyncMaster 1100MB 21" CRT Monitor
Skipping and Shaking cursor
There is a problem with the compatability of your tablet and your monitor. You either have to change your monitor to a different refresh rate or simply move your tablet abit further way from your monitor. If possible, you could change your tablet to "single mode" (depending on your tablet).
Mar 17, 2008 | Wacom Intuos3 6X8 USB with Pen&Mouse [...
I think it's busted
you need to open the case and check the capacitors and if they seem doomed or color is leaking then replace the bad ones that should stabilize the power to the vertical ic chip
Nov 20, 2007 | Mag Innovision LT782S 17" Flat Panel LCD...
A pink vertical line appears suddenly on the screen
i have a samsung 15inch monitor.which is only 6month old.giving blue vertical line along the right side of monitor (almost 2 inches from right side) how to remove it plz someone help me.my mail id is kakhilesh83@yahoo.com.thank you..
Apr 09, 2007 | Samsung SyncMaster 740N 17" LCD Monitor
Monitor Flashing
Then it goes away? That sounds like the normal degauss feature is working.
Jan 08, 2007 | BenQ P992 19" CRT Monitor
Samsung SyncMaster 955 DF 19" CRT Monitor Logo
4,929 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
ismael castillo
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
