Netgear WG102 AP VLAN
I have a Netgear WG102 wireless PoE AP configured with VLANs connected to a tagged port on an Extreme Summit X450e (Layer-3).
Wireless clients can obtain the correct DHCP network address per VLAN however packet loss is 75-100%.
Netgear support states as long as Extreme hardware adheres to the standards it should work.
We have a MPLS network using different Cisco router models with no VLAN issues.
The Netgear WG102 AP works fine without 802.1q VLAN enabled.
Any ideas?
TIA
  • dailymanesh Feb 19, 2009
    I do have similar problem....? But in my case we don't have VLAN configure in our network.......
tech curly
  • 298 Answers
SOURCE: DHCP option is disabled when LAN IP is Dynamic on DWL-G700AP
that is right the access point does not have a dhcp server. that will give an ip address to all of your computers or device connected to it wireless. If you have a modem with a dhcp server there will be no problem with the IP but if the modem does not you must have a router and now an access point.
Posted on Aug 07, 2008
SteveRand
  • 210 Answers
SOURCE: Sending DHCP request across diffrent vlans
Hmm... on your DHCP server, try setting the "default router" IP for each pool to be the VLAN ID on the switch.
scope 172.16.0.0 /24
router 172.16.0.1
scope 10.20.8.0 /22
router 10.20.8.1
I think the DHCP replies aren't going back where they should. I've never done this without a router doing all the DHCP, but it does work and i've done it many times. Your config looks spot on for the switch.
Posted on Feb 05, 2009
SOURCE: Ip address for clients using autonomous cisco 1130ag witout dchp
the cisco1130ag will provide ip addresses and serve as a DHCP server for your laptops...
You still need an IP address for your 1130ag so either your ISP provides you a static ip that you can put in the 1130 or if your ISP provides dhcp then you should be able to plug and play with your 1130ag
Posted on Mar 12, 2009
SOURCE: problem using wireless access point to conect desktop PC to WLAN
I have solved the problem:
- first, I had to change the management address in CF-WFAP into address that could be recognized by the router (i used 192.168.1.2),
- DHCP turned off, and set default gateway and DNS to 192.168.1.1. as in router, computer IP was set to 192.168.1.xxx, push "apply", change web address to new one,
- set AP mode to station-infrastructure, push "apply" buton to restart AP,
- set security to same security as in router and copy key into proper field, push "apply" again to reset the AP
- finaly check wireless station around and choose the router (same encription)
Posted on Mar 22, 2009
  • 131 Answers
SOURCE: D-Link 2100 AP is working in Wireless Client mode.
Check in your router to see if your router is set up to be a DHCP Server. If your router and adsl are both set up to be DHCP servers, sometimes they will fight with each other and some computers seem to have problems getting adresses from this kind of setup. Make sure that only one is set up to give out adresses, then check on your second computer to make sure that it is set to obtain adress automaticaly. If someone has set a manual adress in that computer that is not on the same subnet as the router, they will not comunicate. If this does not solve your problem, try putting in manual adresses into both computers: IE 192.168.1.2, subnet mask 255.255.255.0, Default gateway 192.168.1.1 in the first, and 192.168.1.3 in the second with the same subnet and default gateway,
Posted on Nov 26, 2009
What Are the Differences in AP-side Switch Interface Configuration and Intermediate Switch Configuration in Direct and Tunnel Forwarding Modes?
Differences in configuration on switch interfaces connected to APs are as follows:
In tunnel forwarding mode, interfaces connected to APs transparently transmit only packets of the management VLAN. These interfaces must be added to the management VLAN in untagged mode. In direct forwarding mode, interfaces connected to APs must be trunk or hybrid interfaces. These interfaces must be added to the management VLAN in untagged mode and added to service VLANs in tagged mode. If a trunk interface is connected to an AP, the PVID of the interface must be set to the management VLAN ID.
Differences in configuration on intermediate switches are as follows:
In tunnel forwarding mode, intermediate switches transparently transmit only packets of the management VLAN. In direct forwarding mode, intermediate switches transparently transmit packets of both the management VLAN and service VLANs.
S5700 Switch Thunder link com
Oct 17, 2016 | The Office Equipment & Supplies
How Do I Restore the Default VLAN Configuration of an Interface?
We can take S5700-28P-PWR-LI-AC as example.
The default VLAN configuration of an interface involves the default VLAN of the interface and the VLAN that the interface joins. By default, the default VLAN configuration of an interface is as follows:
Access: The default VLAN is VLAN 1, and an access interface joins VLAN 1 in untagged mode.
Trunk: The default VLAN is VLAN 1, and a trunk interface joins VLAN 1 to VLAN 4094 in tagged mode. That is, a trunk interface allows all VLANs.
Hybrid: The default VLAN is VLAN 1, and a hybrid interface joins VLAN 1 in untagged mode.
Dot1q-tunnel: The default VLAN is VLAN 1, and an dot1q-tunnel interface joins VLAN .1
Negotiation-auto or Negotiation-desirable: If the interface is negotiated as an access interface, the default VLAN configuration of the interface is the same as that of the access interface. If the interface is negotiated as a trunk interface, the default VLAN is VLAN 1 and the interface joins VLANs 1 to 4094 in tagged mode. That is, the interface allows all VLANs.
Run the display this include-default ' include link-type command in the interface view to check the link type of the interface, and then perform one of the following configurations to restore the default configuration of the interface.
Restore the default VLAN configuration of an access or dot1q-tunnel interface.
<HUAWEI> system-view
[HUAWEI] interface gigabitethernet 0/0/1
[HUAWEI-GigabitEthernet0/0/1] undo port default vlan
Restore the default VLAN configuration of a trunk interface.
[HUAWEI-GigabitEthernet0/0/1] undo port trunk pvid vlan
[HUAWEI-GigabitEthernet0/0/1] undo port trunk allow-pass vlan all
[HUAWEI-GigabitEthernet0/0/1] port trunk allow-pass vlan 1
Restore the default VLAN configuration of a hybrid interface.
[HUAWEI-GigabitEthernet0/0/1] undo port hybrid pvid vlan
[HUAWEI-GigabitEthernet0/0/1] undo port hybrid vlan all
[HUAWEI-GigabitEthernet0/0/1] port hybrid untagged vlan 1
Restore the default VLAN configuration of the Negotiation-auto or Negotiation-desirable interface.
[HUAWEI-GigabitEthernet0/0/1] port trunk allow-pass vlan all
Jun 28, 2016 | Compex PS2216 16Port 10100Mbps Smart...
How to configure VLANS and Tagging
https://m.youtube.com/watch?v=krE16IRIHw4
Watch this video for switch port access . You will need to be in global config interface mode.
Jun 05, 2016 | HP ProCurve Computers & Internet
When I enable the vlan option in an EAP9550 I lose wireless access
Bruce,
Is the goal to use a different VLAN for each access point (AP)? If so then you will need to configure each NetGear port to use the same VLAN as the AP that is connected to it. You will then need either a switched virtual interface (SVI) for each VLAN on the NetGear or a trunk port (802.1q) from the NetGear to the Cisco. I'm not sure the NetGear will support SVIs but it will support trunks. An SVI basically creates a gateway for each VLAN's subnet. For example, let's say AP1 uses VLAN 10 and the subnet is 10.0.10.0/24 while AP2 uses VLAN 20 with a 10.0.20.0/24 subnet. The NetGear will need 2 SVIs, one for each VLAN/subnet. The first SVI for VLAN 10 can be configured with IP address 10.0.10.1/24 while the second SVI can be configured with 10.0.20.1/24 for VLAN 20. These IP addresses will be the gateway for each VLAN. Finally, the NetGear would need to act as a router and route each VLAN's subnet to the Cisco device. Once again I don't believe the FS726TP supports this.
The other solution would be to create a VLAN trunk port between the NetGear and the Cisco device but I believe the Cisco RV042 does not support trunking. If it does the trunk would be configured to carry all of the VLANs to the Cisco device which would then have SVIs created on it.
If neither of the above is possible you would need to use the same VLAN for each AP and each of the interfaces on the NetGear and Cisco devices which negates the need for the VLANs.
I hope this helps.
Mar 13, 2014 | EnGenius Computers & Internet
Does a netgear jgs524 support vlans?
The JGS is an unmanaged switch. It has no settings to configure or reset. When it receives a packet, it might preserve its VLAN tag when forwarding it, but there is no way to configure it to notice or handle VLANs in any particular way.
Jan 10, 2013 | NetGear ProSafe JGS524 (DHJGS524NA)
Vlan trunk on summit 24e2
Extreme uses tagged and I untagged instead of trunk/access, so it would look like this for a trunk:
conf vlan test add port gi1 tagged
(and of course you could put other VLAN's on this same port too since it's a trunk)
conf vlan user1 add port gi1 tagged
and this for handoff:
conf vlan lam test add port fa1 untagged
Feb 14, 2012 | Extreme Networks Summit 24e2 Networking...
Netgear FSM7352S - VLAN not connecting
Create the same VLAN on all the switches that will need this VLAN. All ports that link to another switch should have ALL VLAN's set to tagged.
This one VLAN should not have an IP address on any of your switches. This way it won't get routed by any of your users.
Apr 06, 2010 | NetGear ProSafe FSM7352S (0606449038880)...
ZyXEL IES-1000 with AAM1212 ADSL 12 port module step-by-step guid
Going through the GUI would take too long, so use CLI to add the commands below. After that, check the GUI and see how those changes appear.
VLANs:
On all equipment use 802.1q tagging. The example below puts adsl ports 1 to 10 in vlan10 and ports 11-12 in vlan2. These vlans are 802.1q tagged on the ethernet ports.
switch vlan set 1 1~12:X enet1~enet2:FT DEFAULT
switch vlan set 2 1~10:X 11~12:FU enet1~enet2:FT VLAN2
switch vlan set 10 1~10:FU 11~12:X enet1~enet2:FT VLAN10
switch vlan set 17 1~12:X enet1~enet2:FT VLAN17
switch vlan pvid 1~10 10
switch vlan pvid 11~12 2
switch vlan pvid enet1~enet2 1
switch vlan priority * 0
switch vlan gvrp * disable
switch vlan frametype * all
switch vlan cpu set 1
ATM circuit:
Each port requires one or more VPI/VCI circuit. You could map different circuits to corresponding vlans. The config below creates a primary circuit 1/35 on each port. On ports 5 and 9 is another circuit 1/32 mapped to vlan10
adsl pvc set * 1 35 super DEFVAL
adsl pvc set 5,9 1 32 10 0 DEFVAL
Remember a dslam is just a switch, bridging packets from a VC onto a VLAN or straight onto ethernet.
Mar 27, 2009 | Zyxel IP Express IES-1000 (91004098002)
Inter Vlan routing
Just For InterVLAN routing, Mark (enable) administration Access for ALL VLAN :P
Sep 18, 2007 | Computers & Internet
Computers & Internet Logo
609 people viewed this question
David Payne
David Payne
