Settings for fax machine
When my home phone rings if I don't get to it by the second ring it automacticly goes to my fax machine. The numbers are different. I have the setting on faxtel how do I get to faxtel-auto? When you get it to faxtel-auto what do you do next so you know it stays there?
    Problem Solver:
  • 12 Answers
Depending on the model and make of your machine, there should be an option under the fax settings of the setup menu that will allow you to either increase the number of rings before auto answer (I suggest that you increase it to at least 5 rings to give you time to answer) or that whilst you are available change the answer setting to phone. This will mean that you have to answer all calls but if there is an incoming fax (you will hear the high pitched beeeping sound) before you place the phone back on the hook press the start button.
This should solve your dilema.
Posted on Oct 17, 2008
My Lexmark Interpret S405 fax?copy machine picks up incoming call from cell phone as fax. it goes onto fax automatically after 2 rings..
It seems that you're sharing your home phone line with your Lexmark fax machine. You can adjust the "pick-up" ring from the printer operator panel by pressing the Setup button > Fax Setup > Ringing and Answering > Pick Up On > select your preferred number of rings before the fax answers.
Please note:
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Nov 08, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Hpj4580- my phone is equipped with voicemail that picks up after the fourth ring of the phone. How do I set up the fax so that it works with my phone. Currently, when my phone goes to voicemail, the fax...
You need to go in and adjust the "Off Hook" setting so that it does not pick up the ring cycle before the answer machine does.
Next you have to find the instructions that will allow your phone answer machine to tell your fax machine that there is data for it.
More often than not this is accomplished by setting a software switch for example press number 4 to send me a fax. The answer machine in turns wakes up the fax machine and allow the connection to proceed.
It all in those books that came with your products. I know you keep them neatly filed away for instant retrieval, just the the rest of us do. :)
Jan 22, 2010 | HP OfficeJet J4580 All-In-One Laser...
>first run fax test, press set up go to tools menu then select run fax test,all entries should be pass
>then check your connections, do you have one line or number for your fax and phone?or a separate line or another number for fax and another number for phone?
>let me assume you only have one number for fax and phone..
>check connections, this should be downstream connection, the fax machine using the black phone cord provided by hp should be connected directly to the phone jack using line 1 at the back of the fax and the answering machine or the telephone should be connected to ext 2 or line 2 at the back of the fax...there should be no other devices phone or answering machine connected directly to the phone jack.
>next set rings to answer on the fax machine higher than the answering machine...if your rings to answer on answering machine is 4 rings, set the fax to 6 rings...if it is a voice call the answering machine will pick it up at 4 rings then if it detects that it it a fax tone then it will transfer the call to fax.
>also check if auto answer is on in your fax
>you can check auto answer and rings to answer by pressing set up or menu button on your machine look for it in basic fax settings or advance settings
>also check if your voice prompt for your answering machine is not too short there should be like at least 5 seconds after cutting your message to allow the machine to transfer the call to the fax if it is a fax tone.
Sep 14, 2009 | HP 1040 Plain Paper Inkjet Fax
Need to set up phone/fax instead of just fax
I have a HP Officejet J6480 All-In-One and needed the answering machine and fax to be on at the same time.  I called the help line at HP and they said I needed another phone line into the home but I tried this and it worked.
First I got a different phone number for the fax machine - they do this for no charge at my phone company. This is not another physical line into the home - it is just another phone number with a different ring - it rings 2 fast rings for the fax machine instead of the phones regular one ring. I set the answering machine built into the phone to pick up after 4 rings and I set the fax machine to pick up on 2 rings. Be sure to set it so the fax pick up number of rings are less than the answering machine pick up number of rings.  It worked for me. Hope this works for you too.
Apr 24, 2009 | Brother MFC-260C All-In-One InkJet Printer
When people call our home number sometimes the fax machine is reached instead of the home number. What would cause that? I called Quest and they said it was a problem with the fax and to call you. Our fax...
Make sure the fax machine is correctly set up for the ring pattern of its number. I suspect it's either not set or set for the wrong ring pattern, and is answering the phone before you do when people call. Once the fax machine is set for the proper ring pattern the problem should clear up.
You can download a copy of the manual here if you've misplaced yours. Just pick your product (fax machine) and model from the drop-down menus.
Mar 13, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Home phone line and fax on one line
Mine is free from Bellsouth. I do not know about other phone companies.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 30, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Fax machine will not reset to be able to answer the phone
When you set your fax machine to answer on a certain number of rings it will answer it on that number of rings expecting it to be another fax machine. If you do not answer it before the aloted number of rings you will not be able to talk since the fax machine will be trying to talk in computer speak. To help you may want to set it to answer after more rings.
Jan 15, 2009 | Office Equipment & Supplies
Incoming fax vs voice
Contact your telephone provider and see if they can offer you a second number for the line and "destinctive ring".
If your fax unit supports this feature, the fax number can do a double-ring where the normal number does a normal ring. The fax unit would then pick up double-ring calls.
Dec 27, 2008 | Canon MX300 Office All-In-One Printer
Answer a distinctive ring?
No, distinctive ring is not available on this machine.
May 24, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Fax\phone line
Here's how to change the ring count...and I'm also providing the link for support and troubleshooting your specific machine on Canon's website...
To Change the ring count 1. Press the <Menu> button repeatedly until [FAX SETTINGS] is displayed.
2. Use the [ left.gif] or [ right.gif] to select [RX SETTINGS] then press <OK>.
3. Use the [ left.gif] or [ right.gif] to select [INCOMING RING] then press <OK>.
4. Use the [ left.gif] or [ right.gif] to select [ON] then press <OK>.
5. Use the [ left.gif] or [ right.gif] to select the desired number of rings. Press <OK> then press <Stop/Reset>.
Hope this worked for you!
Feb 22, 2008 | Canon PIXMA MP530 All-In-One InkJet...
149 people viewed this question
