Question about Canon Cameras
Canon power shot a610, had camera in waterproof platic case. when i turned it on, the zoom focus lens wasnt lined up with tube it sits in and caught the edge stopping it from expanding out. now it wont come out at all. is it worth fixing?
  • Canon Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Oct 19, 2008
My rebel T1i won't take pictures on AF
If you have a specific zoom lens on and it will take shots in MF manual focus but wont in AF auto focus you could have a broken ribbon connector in the lens. Try with another zoom lens if you get the same problem it could be the camera. If it works OK then the ribbon in the affected lens may need replacing.
Jun 16, 2014 | Canon EOS 500D / Digital Rebel T1i Digital...
Canon power shot A610, will it support sundisk 16GB?
No. The A610 works with MMC and SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Dec 21, 2013 | Canon PowerShot A610 Digital Camera
I've dropped my Canon Power Shot SD960 IS with the lens out, and now the outer lens is tilted at an angle and wedged tight and the barrel of the zoom will not retract. I've tried turning it off and on,...
Try this first, power off and gently push the lens barrel sideways - not back in!, If the barrel and the lens move slightly, you will get it working after some more manipulation in the same way. If it does not budge, sorry to mention this but your camera sustained more damage and you cannot do do much on your own.
Aug 14, 2013 | Canon PowerShot SD960 IS Digital Camera
Just need a manual foor Nikon One.Touch Zoom 90s
Description: Sleek and stylish, the exciting new Nikon One-Touch Zoom 90QD offers real zoom power in a lightweight, easy-to-use design. The One-Touch Zoom 90QD has a sharp, clear, 2.5x zoom lens with a 38-90mm range and a macro mode for shots as close as 11 inches. The One-Touch Zoom 90QD features a built-in automatic flash with five versatile modes (auto flash, anytime flash, flash cancel, slow sync and red-eye reduction). The active infrared autofocus, infinity focus (for landscapes and faraway subjects), real-image zoom viewfinder and fully automatic exposure control all help to ensure clear and balanced photos.
7444ca6.jpg Depth 2.1 in. Film Type 35mm Width 4.6 in. Height 2.5 in. UPC 018208018789 Battery Type 1 x 3V Lithium Battery (CR-2) Weight 7.84 oz. Self Timer Yes Camera Type Point and Shoot Focus Type Autofocus Minimum Focus Distance 1 ft. ISO Range - Automatic Setting ISO 100 - 800 Red Eye Reduction With Red Eye Reduction Zoom Size 2.4 Auto Exposure Yes Min Aperture f10.5 Waterproof No Max Aperture f4.8 Zoom Lens With Zoom Lens Zoom Range 38 mm - 90 mm
User Manual can not be found up to now. Very soon will be available.
Jan 26, 2010 | Nikon One Touch Zoom 90S 35mm Point and...
I HAVE A CANON POWER SHOT A520. THE ZOOM LENS WAS OPENED AND I DROPPED THE CAMERIA AND THE LENS WHEN INTO THE CAMERIA. NOW THE ZOOM DOES NOT OPEN ANY MORE. THE LENSE IS OPEN AND DOES NOT CLOSE. I GET NO...
I know this is not the answer you want, but when you dropped the camera you damaged the lens tube (housing) and your camera will require professional repair.
Sep 13, 2009 | Cameras
Zoom lens will not retract.. Canon Power Shot S21S
the block is damaged ...see if the lens barrels are a little bent or something....
Mar 06, 2009 | Canon PowerShot A75 Digital Camera
The zoom lens won't close. It says to restart computer, but won't do anything when I try to turn it on. It's a canon power shot SX100 IS
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
May 27, 2008 | Canon Cameras
Zoom won't go in or out canon power shot sd870
zoom will not work in movei mode.
operate zoom before shooting in movei mode.
Apr 09, 2008 | Cameras
No picture and lens does not retract
Well some cameras has features that does not use the LCD screen of the camera, because to save battery power or to get better shots with the focus ring.
You can just use the area where you focus your eye to aim and shoot the object of image.
Try to enabled the LCD screen feature.
The Zoom Lens Wiggles 3 times because it is programmed to zoom at the standard zoom size, this is totaly normal for camera in digital and analog types.
Mar 05, 2008 | Sony Cyber-Shot DSC-P100 Digital Camera
Cameras Logo
56 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
