Question about Sony Ericsson W550i Cellular Phone
Seth thomas metronome.
Slider on metronome scale is missing. Can a new one be purchased? Grandkids lost the metal weight that acts as a slider on the regulator .
  • 1 more comment
  • Anonymous Dec 20, 2008
    I need a weight for a Seth Thomas Metronome too.
  • Anonymous Jan 21, 2009
    I have the same problem... I am going to try a replacement weight from Wittner Metronome replacement parts... I believe it may work!
    Cheap enough to try!
  • Anonymous Mar 17, 2014
    lost cover and keyfor seth thomas metronome
    Brigadier General:
  • 7,752 Answers
Yes you can have the housing replaced
Posted on Nov 02, 2008
I need parts for my seth thomas westminister ave marie clock I need the swinging mechanism the clock is a mantel clock, the bar and head is missing a parts list would help
Howard Miller Clock Parts ' eBay
www.ebay.com/bhp/howard-miller-clock-parts
eBayHermle 2115 Ave Maria Westminster 2 Chime Quartz Clock Movement ... hermle hamilton ridgeway howard miller seth thomas, clock winding key #7/4.00. $9.99.
Clock Repair & Replacement Parts - Movements, Motors ...
timesavers.com/c-325738.3-clock-repair-replacement-parts-movements-...
Items 121 - 180 of 249 - Front Plate - Seth Thomas #2, #77 Movement ... of #2, 77 movement parts that have been in storage since the 1970s. ... Hermle #2115Westminster/Ava Maria Quartz Movement ..... My Account; Login/Register · My Cart.
Jan 27, 2016 | Westminister Time Warp Shelf Clock
How do i slow down my 1920 1930 seth thomas matle clock. i tried slowing with the key but it doesnt slow down. it gains about an hour in every 12 hours
I wish I knew the name of the parts but here we go. On the swinging pendulum on your clock there should be a sliding weight on the bar. This will have a set screw or a thumb screw that you can loosen and slide the weight up and down to change the pace of the pendulum. Down is slower and up is faster.
Jan 18, 2015 | Seth Thomas Audio Players & Recorders
How do i set a radio controlled clock seth thomas hd 1688
  • Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
  • 2
    Turn your attention to the small lithium battery-powered digital clock display on the back of your clock. With the correct time zone set, the digital display should accurately reflect the current local time.
  • 3
    Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment.
  • 4
    Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner.
  • Read more: How to Set a Seth Thomas Atomic Clock ' eHow.com http://www.ehow.com/how_6120534_set-seth-thomas-atomic-clock.html#ixzz1GyAcVHP2 hope this helps you
    Mar 17, 2011 | Seth Thomas Radio Controlled Wall Clock -...
    Have old Seth Thomas Metronome ,only key turn about 1/4 turn.Is that normal for vintage one.
    It is not normal. Metronome should wind almost the same as a clock. The cause for this 1/4 turn of a winder is that the driving spring do not unwind completely. That means there are mechanical or oiling issues. Show your metronome to any clock repairer (not the watch repairer) and he/she should be able to fix that.
    Feb 27, 2011 | Watches
    Have a Seth Thomas Banjo clock - estimated to be @ 60-70 years old - was working perfectly for many years - recently moved and movers took off pendelem weight so not to lose it - now clock will not run...
    Is it spring wound or weighted with pine cones? I have a feeling the movers wound it up for you and over wound it. you can release the tension on the spring by carefully letting the key unwind while you hang on to the catch, I just got a clock from somebody, it was way over wound, took about 10 full turns out of it and got it running, it has been going for about a week without touching the spring. I haven't got the chimes back yet.,,, Now if it is a weighted mechanism, the chain may have jumped the track. Check that out. Other than that, I can't see why it shouldn't work. Hope this helps.
    May 22, 2010 | Seth Thomas St. Thomas Creations 6006.130...
    I want to unlock me memory card
    If you mean unlocking write capability, and if it's a full-size SD card, there is a small slider on the side of the card - it has to be in the upper position for the card to be read-write.
    Some cards don't have such option at all, and half of this gap shown in picture is filled permanently - SD specs say it's optional.
    However, sometimes this small plastic part is supposed to be there, but breaks or falls off. If the slider is missing, you will have to fill that gap with something - a tiny piece of neatly cut plastic or wood or whatever that will fill half of this rectangular recess. You can use any quick-acting cyanoacrylate glue (Super Glue, Krazy Glue etc.) to attach it in place.
    I don't recommend making this "false slider" of metal (like a piece of wire), as it may fall off accidentally when the card will be inside the equipment, and you don't want a metal part rattling inside an electronic device...
    Please come back with a testimonial if helped :)
    Dec 23, 2009 | SanDisk 1GB microSD Memory Card
    Missing weight for seth thomas metronome
    I used a Wittner weight on my old Seth Thomas and it worked just fine. Calibration was very close out of the box. You can get these for less than a couple dollars if you look around.
    Sep 25, 2009 | Sony Ericsson W550i Cellular Phone
    Gemini CDM3600 pitch slider
    I am having same problem..anyone ?
    Jul 01, 2009 | Audio Players & Recorders
    I have a Seth Thomas clock that needs started
    If it has a pendulum, you need to either lower the weight or adjust the ticker.
    Dec 26, 2008 | Seth Thomas St. Thomas Creations 6006.130...
    Sony Ericsson W550i Cellular Phone Logo
    439 people viewed this question
    Top Sony Ericsson Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Sandeep Shenoy
    Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
