Question about PANDIGITAL 7-Inch Digital Photo Frame with 2 Interchangeable Frames (DPF701) Digital Picture Frame
TURNS OFF AND FLICKERS
HELLO
I HAVE HAD MY PANDIGITAL FOR A BOUT ONE YEAR. I HAVE MISPLACED MY MANUAL SO I AM IN THE DARK.
I HAVE TURNED MY DIGITAL OFF FOR A WHILE AND WHEN I TRIED TO GET IT GOING AGAIN IT STARTED ACTING UP.
SPECIFICALLY, IT FLICKERS A LITTLE AS IT GOES THROUGH THE 20 OR SO PICTURES THEN IT TURNS OFF.
I HAVE TO TURN THE SWITHC OFF AND THEN ON AND IT WILL GO THROUGH THIS SAME CYCLE AGAIN.
ANY IDEAS?
JERRY
  • sophie2008 Nov 07, 2008
    I have the same problem. The screef flickers as it's going through the pictures. It hasn't shut off like Jerry's. Any ideas on what's wrong?
3 Suggested Answers
  • 6 Answers
SOURCE: Unable to operate remote of Pandigital picture frame
remove the memory card and see if the remote works wit hthe built in memory pics. if it doesnt pic up your card you will just have to try another card. The frames dont read cards larger than 1 Gb very well either - reguardless of how many pics are on the card.
Posted on Dec 11, 2008
SOURCE: I need a manual for
I find that going to the manufacturer's web site and then going to Support usually gets me access to at least an on-line manual, but most often a downloadable manual.
Hope this helps.
Posted on Dec 16, 2008
PANDIGITAL Digital Photo Frame works perfectly except the SCREEN Flickers Black after a few moments
Annemarie, I had a similar problem with an off-brand photo frame from Wal-Mart last year, although in my case the frame would shut down entirely after it had flickered a few times. In my case, I was able to remove the back of the frame's case by removing 4 screws (two were hidden underneath model number stickers) and inspecting the device's innards... what I found was that, as you surmised, there was a loose connection from the female end of the DC-in power supply. The ground connection to the device's circuit board had been poorly soldered, leaving the connection itself loose and a small piece of solder on top of the board and very near the positive connection.
While not being the best solderer in the world, with the aid of a magnifying glass, a solder removal tool, and a ColdHeat soldering wand, I was able to heat the offending piece of solder and remove it from the circuit board and then, as I was personally uncertain of my ability to re-solder the connection without melting the board, I simply held the connection in place and applied a dab of hot glue to keep it there. After the glue cooled, I reassembled the case and the frame worked for almost another year before something else finally burned out and it was left cold and dark.
Hope this helps, good luck!
Dec 03, 2013 | PANDIGITAL 7-Inch Digital Photo Frame with...
I misplaced the power supply and need to find another but don
look at the specifications of the old power supply in the manual or on a sticker on the back of the unit. It should give a DC voltage and an amp value. Get any power supply that has the same DC voltage and same or slightly higher amp rating.
Oct 23, 2012 | PANDIGITAL (DPF802) Digital Picture Frame
NO English manual - Help!
It looks like Pandigital's manual links are not working.
http://www.pandigital.net/?pageid=124
I would suggest filling out the customer service form here:
http://www.pandigital.net/?pageid=125
Let them know what manual you need and also that the manual links are not working. They should be able to help you get the manual you need.
Thanks for using Fixya.
Apr 12, 2010 | PANDIGITAL 8.0" Digital Photo Frame...
PANDIGITAL 7-Inch Digital Photo Frame with 2 Interchangeable Frames (DPF701) Digital Picture Frame Logo
229 people viewed this question
Top PANDIGITAL Photography Experts
LP
Gareth Cockram
Gareth Cockram
Are you a PANDIGITAL Photography Expert? Answer questions, earn points and help others
