Question about Frigidaire FTF2140ES King Size Front-Load Energy Star Washer w/ Tumble Action
Frigidaire model# fwxb45rgs1
Well when i do a load it goes through all the cycles but the final spin i can open the lid a turn the tub then its fine and it smells like something is burning. i have the washer a part the belt seams to be tight and dont look to be warn out.but i did notice a plastic peice or something broke into little peices it comes down from the tub shaft into the transmission im guessing thats what it is but i cant figure out how to take it a part?
  • 25 Answers
SOURCE: load noise in final spin cycle
turn the tub on the inside if it feels ruff as it turns and makes a noise then most likely you have a bad rear bearing, if it is smooth in turning and no noise then turn to drain or spin possibly something stuck in drain pump. the drain pump will start up first if you hear the noise then the drain pump is accessed from the front lower cover, if its the rear bearing probably not worth fixing about 400.00 in parts and alot of work.
Posted on Feb 16, 2008
  • 148 Answers
SOURCE: Frigidaire CWS3600AS Top Load Washer
I know it sucks but at least the repairman can give you a break on the cost cause you have it apart and he charges by the hour,tell him youll put back together yourself after he gets it out
Posted on Jul 13, 2008
  • 903 Answers
you can't really tighten a belt, I suggest that you change it, although it is extremely hard to replace a a new belt yourself. Have you checked the carbon brushes in the motor do not need changing, this could also generate a burning smell and leave you clothes wet if they are worn.
Posted on Nov 15, 2008
  • 10 Answers
SOURCE: Front loader will not spin
The problem is the door latch assembly. You can get it at your local parts supplier or oder it through Should cost $50-$55. My hubby is replacing mine now. Not an easy part to replace, but by all information I have gathered from the manufacturer and the parts department, this is a common problem and most likely the cause of the machine not spinning. It runs through all the rest of the cycles, but will not spin, even on spin only cycle. The good news... if you replace the door latch assembly once, the replacement part is much stronger than the original and shouldn't have to be replaced again.
Posted on Jan 02, 2009
SOURCE: frigidiare washing machine squeaks in spin cycle
use fairy liquid it works best
Posted on Mar 05, 2009
  • 130 Answers
SOURCE: crown series 12 cycle washer will not agitate and smells like something is burning like a for instance a vacumme belt kinda smell in that cycle it spins fine fills fine drains fine but just makes a so
It doesn't agitate If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Drive motor
Drive pulleys
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Posted on May 07, 2009
0 characters
1 Points
My model GLET1041AS2 Frigidaire Laundry Center fills/agitates, but does not pump or spin. The timer would make a slight buzzing/timer sound when it hits the spin cycle, but nothing else.
The circuit board has a Cycle generator and sequencer that accepts commands when you manually do a setting. When the sequence enters the spin phase a block occurs and discontinues further action. It is not the timer, but the command center on the circuit board. Because the board has many functions, it is like a set of Christmas Tree lights in series, and when one bulb fails, so goes the set. You will no doubt need a new command board for that model.
Mar 12, 2014 | Frigidaire Genuine Washer Timer 134049600
Frigidaire front loading washing machine will not do final spin
If you cannot manually turn the tub when it is off, and not in use, then the motor and transmission is possibly seized. If you can turn it with no issue or noise, then the control is not communicating correctly to the unit.
Dec 28, 2012 | Frigidaire Washing Machines
Machine makes loud banging noise during the spin cycle
The load is out of balance. Open the lid and redistribute the contents. When it's empty, grab the basket and give it a slight push sideways. It should move a little but, not free swing. If it doesn't have much resistance, the "snubber" has dried out and should be replaced. It is simply a piece of rubber in a metal bracket, that rests on the tub. When the basket spins,the snubber keeps it from jumping around.
Aug 31, 2009 | Frigidaire FWT449
GE top load washer does not agitate or spin.
sounds like a bad lid switch how old is it?
Dec 29, 2008 | Washing Machines
Front load washer isn't spinning out
The first thing to check is if the door is locking. Put the unit into spin turn unit on let it go for about a minute then shut it off, try to open the door right after you shut it off if the door opens you need a door switch if not chances are you need a motor control board. Before replacing the board call for service they are expensive if it is a guess. good luck
Dec 26, 2008 | Frigidaire GLTF1670A Front Load Washer
Sometimes won't start spinning cycle
In most cases, this is caused by a faulty lid switch.
Oct 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Frigidaire Gallery Model FWT449GF Tub issue
level and balance is very important for all machines. make sure it is firmly seated on floor and shipping bolts pins and brackets are removed (some have brackets inside.) the machine should be able to evenly distribute the load. finally the shock absorbers could be bad. (seems rare on frigidaire)
Mar 17, 2008 | Frigidaire GLTF2940ES Front Load Washer
Load noise in final spin cycle
Feb 14, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Frigidaire front load washer problems
My problem is that water is still draining when it goes to final spin. final spin is not working properly. then machine shuts itself off before timer.
Nov 16, 2007 | Frigidaire GLTR1670A Front Load Washer
Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
May 17, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
Open Questions:
See all Frigidaire FTF2140ES King Size Front-Load Energy Questions
Washing Machines Logo
146 people viewed this question
Top Frigidaire Washing Machines Experts
Richard Roth
Richard Roth
Dan Webster
Dan Webster
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
