Question about Dryers
Screeching noise when high velocity pedestal fan is turned on
When I turn on the fan, it makes a screeching high pitch noise. The manual states that the motor bearings are permanently sealed and do not require additional lubrication.
  • Anonymous Nov 29, 2008
    I have the same problem asd lbwilliams12, except that it sceeches on any speed (louder on high, spfter on low). Sounds like something needs to be oiled.
  • Anonymous Jan 31, 2009
    I have the same screeching noise coming from my Kaz HT-800. The noise continues on all speeds. If the bearings are sealed where could I try lubricating it? Is it even worth taking apart?
  • 55 Answers
SOURCE: kenmore dryer making excessive noise
Likely the main drum bearing in the back. I have seen these go bad, and loud squeaky noise tells you. You can get a new main bearing and replace. It is in the center of the back of the drum, accessee through back panel of dryer usually.
Posted on Mar 10, 2008
Benimur
  • 6966 Answers
SOURCE: My ceiling fan - Casa Viejo
Sorry for the delay in response. Electrically, there should be no potential hazard since there would be no more "juice" running through the circuitry.
Posted on Nov 14, 2008
SOURCE: dryer makes screeching noise runs for awhile then shuts off.
The 1,5 year new dryer makes a terrible screaching noise when it has a load of clothes in it. It still dries fine, no problem with the heating element. No noise without clothes, only when it has a load.
Posted on Nov 23, 2008
  • 1214 Answers
SOURCE: Kenmore 110.86874100 Motor (?) Squealing
I don't think they can be, but, also take a look at the fan bearing assembly too. You should be able to isolate if the noise is from the motor bearings or blower bearings.
Posted on Jan 26, 2009
onthejob5130
  • 640 Answers
SOURCE: Lady Kenmore Dryer Making Loud Screeching Noise When Drum Turns
defective rollers..replace
Posted on Jan 29, 2009
Car made high pitch squealing noise before it not being able to turn over
I wonder if you have a fan belt that is screeching? They get glazed over and eventually wear out and make a high whine and screeching noise. This might...be what it is
Feb 05, 2013 | 2005 Honda Civic
Screeching noise high pitched when i stop in traffic almost like a whistle noise
possibly your brakes are worn. there is a metal tab that contacts the brake rotor when it is time to replace the brake pads...
possibly.
Sep 30, 2012 | 1990 Mazda MX-5
2006 Chrysler sebring High Pitch Noise Screeching Sound
The belt is slipping or the compressor and/or clutch is bad.
If the compressor won't turn freely with the engine off, it may be locked up which will make the belt screech.
Jun 27, 2012 | 2006 Chrysler Sebring 2.7
RCA DLP HDTV making terrible noise
your color weel is going bad and needs to be replaced
May 19, 2010 | RCA HD52W59 HDTV Projection Television
What could be causing a high pitched screeching sound when I turn on my single handle shower?
If you haven't turned the main back on, this could cause the sound.
Re supply the water to the lines.
May 10, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Screeching noise
rear drum bearing needs to be replaced
Sep 25, 2009 | Maytag Dryers
Screeching noise coming from driver side tire
The high pitch sound may come from the brake pads as metal parts hit the disc to signal the owner that it needs change. The metal parts gets exposed when the pads have worn out. The brake also has a hub to cover the disc. See if the metal plate is hitting it but this issue would appear when the wheels are in motion. Check if it is the belts, have the tension checked out. Other than that the bearings are the other items on your wheel that could cause a high pitched sound when you car is in motion.
Aug 09, 2009 | 2005 Dodge Neon
High pitched screeching noise when in spin cycle
Sounds like the belt is worn and might need to be replaced. Let me know if I can do anything else. thankyou for asking.
Mar 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
High Pitched Sound
I am to believe that your static sensor on the playing head is touching the the head and it sould not. just bend it up "slightly" and the noise should disappear
Dec 14, 2006 | JVC HR-S5902U / HR-S5912U VHS/S-VHS...
Dryers Logo
438 people viewed this question
Top Dryers Experts
