Question about HP Office Equipment & Supplies
HP Officejet 5600 has cartridge problem - HP Office Equipment & Supplies
Hi drornstil,
I assume that you had to replace the cartridge recently,
There is a few things that could be causing the problem:
Please remove the cartridge and check carefully that all tapes and seals that were for transport and storage purposes have been removed. Then re-insert the cartridge carefully, making sure that it is correctly seated in its holder, close the machine and try a test print.
Posted on Oct 17, 2008
Window vista driver for hp officejet 5600
Here is link to HP Official Support site. You will find the Vista Drivers HP Officejet 5610 All-In-One InkJet Printer.
Dont forget to rate the solution if I could have been of any help!
CreativeTECH
Dec 04, 2010 | HP Officejet 5610 All-In-One InkJet...
HP officejet 5600 connected but not printing
try a complete reinstall of the printer:
1) unplug printer
2) un-install all drivers, and make sure printer is removed from printer list
3) download the latest drivers from HP:
http://www.hp.com/sbso/bussupport.html
(the included CD drivers could be outdated)
4) follow HP instruction on how to install the new drivers and printer (sometimes it wants software first, sometimes it wants to detect printer first).
Jan 15, 2010 | HP Officejet 5610 All-In-One InkJet...
Cartridge Error: Cart. on left is not intended for this printer
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab64
Jun 29, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5600 All-in-One series
Is your question the top or bottom one? You have cleaned the metal contacts on both the cartridge and on the machine with a soft cloth, right?
Aug 13, 2008 | HP Officejet 5610 All-In-One InkJet...
HP printer
chances are the cartridge is installed incorrectly, please be patint caused this is sometimes annoying. pls there is no oter way around it. good luck
Jul 21, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
  5. Close the print-carriage access door.
Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
Installing HP Officejet 5600 all-in-one in Windows Vista
Go to hp.com. Click on 'software and driver downloads' (on the left of the screen). Next to 'for product:' type in Officejet 5600' and click the >> symbol. Then choose from the list that comes up. When in doubt, choose the first on the list, HP 5605 All-In-One. On the next screen select 'software and driver downloads' again. There you'll see where you can select Windows Vista. CLick on that and sleect, under "Driver", HP Full Feature Software and Drivers.
On the next screen, scroll down and select 'Install Now'.
Best wishes, Al
Mar 08, 2008 | HP Officejet 5610 All-In-One InkJet...
HP 5600 All in One
Try with another USB cable!!! Its no matter is the cartridges OEM or refilled!!!
Jan 24, 2008 | HP Officejet 5610 All-In-One InkJet...
Help
Go to START SETTINGS PRINTERS.
right click on the officejet 5600 icon and then click on preferences. On the color tab indicate, print in greyscale & black print cartridge only .Apply , then OK. Reverse process to use color again.
Jan 15, 2008 | HP Officejet 5610 All-In-One InkJet...
Ben Johnson
