Question about Panasonic TH-42PA20U/P 42 in. Plasma EDTV
Static on top part of screen
After 15 minutes of play it gets static at the top. can this be easily and cheaply fixed?
  • 513 Answers
What do you mean by static? any chance of having an attached screenshot?
Posted on Jun 04, 2006
Static on Powering on
You can start out by resoldering all poor solder connections and look for bad capacitors they will be puffed up on Top.
Oct 01, 2012 | Mitsubishi WS-65907 65" Rear Projection...
On a hot day the radio reception will stay clear for only a few m
It is the overriding by intersteller priority dimensional language conversion filtering. Nothing to worry about, It can be easily defeated and modulated by tightening your removable Radio Antenae.:-) Good Luck_Ned_
Oct 19, 2009 | 2002 Volkswagen Jetta TDI
After five minutes console freezes and static shows up on screen
Try to remove the hard drive and play a game. This will tell you if it is the system or the hard drive itself.
Jul 10, 2009 | Microsoft XBOX 360 ARCADE Console
My display screen is crakced can i replace it on my own
Hi I am Vortash providing you are reasonable with tools and dont have an un steady hand yes easily .
It requires close inspection of the camera and a set of jewlers screwdirvers and patience .
A reseptical for all screws and a notepad to roughly sketch any areas that you are unsure of to refer to on re assembly . screens are usually attached by means of a plastic ribbon into a slot plug that has two clips one either side ease them out and the ribbon will be free dont just pull or the ribbon may break and the clips snap , you will probably need a pair of good tweezers to remove and replace this cable ..Be careful with the clips they snap very very easily ..
A replacemnet screen should be obtainable from Ebay Or Amazon quite cheaply .
One thing I will warn you off is static damage .
components in electronic equipment are highly suseptable to Static damage generated by the human body and surroundings .. one touch can destroy an Ic and your camera . you will need to be earthed to a static arm band strap to eliminate this . ( this is a strap that fits on your wrist that is connected to an earth point through a flexicable attached to the strap . they are quite long and give you ample work movement and can save you pounds from destroyed equipment ) hope this is of help regards Vortash
Jul 04, 2009 | Fuji FinePix A500 Digital Camera
Unit quits after 10 minutes/ screen black and static- noaudio files on card
I call this a problem with a capcitor inside the unit has leaked or has bulged.. Witch is not provding the power it needs to function properly see www.badcaps.com just for a example what are bad capcitors.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 24, 2009 | Astar PD-3015 Portable DVD Player
System turns to red light standby in the middle of playing
you need to go to your setting and change your automatic shutoff timer. this will cause your system to turn off every 15 minutes no matter what you are doing...
Hope this helps... please rate...thanks
Jan 09, 2009 | Sony Playstation 3 (PS3) Console
Oil leak
there is a hose located under the engine on the left side if you looking at it out of the car. the hose may be broken or busted easily and cheaply fixed. or the oil header gaket is worn or even gone again easily and cheaply fixed.
Nov 18, 2008 | 1994 Nissan Sentra 4-Door
DS powers off during play
There is a ribbon cable that runs through the hinge. If the hinge is damaged, the ribbon cable can easily be damaged. If the ribbon cable is only slightly damaged, then movement will cause it to break the connection. When it loses connection, it will power off. You can test this by moving the top screen up and down a bunch to see if it shuts off more while doing this. To fix this problem, you will need a new top LCD screen installed by a qualified technician. The cost of the part is around $15, so use that as a baseline to know if you are getting a good price. Also, do not trust anyone without either credentials or experience, or they will very likely damage the console further.
Mar 23, 2008 | Nintendo DS Lite Console
Hitachi model no 50es1k---july 1993
loose connection on circuit board and also maybe bad caps in vertical area.
Mar 03, 2008 | Televison & Video
Screen blank
use the towell trick! Wrap the 360 in 2 towells turn on and leave running for 15 minutes. It gets very hot but after the 15 minutes turn off the console and power it back on again and it should work. Dont know if this is a permanent fix but my 360 hasnt broken again so far. Dont ask me how but it works, google it if you like. It also cures the 3 red lights problem.
Jun 22, 2007 | Microsoft Xbox 360 Console
Panasonic TH-42PA20U/P 42 in. Plasma EDTV Logo
77 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
