Question about Mag Innovision LT982s 19" Flat Panel LCD Monitor
Monitor lt982s Hope you can help! My monitor does not come on. Is there a magic reset button?
  • valerie403 Nov 30, 2008
    I didnt see a solution to this problem. My new monitor is just outside of the warranty and does not power on. Is there a fuse to replace, I can't afford to ship it out to be repaired. Thanks so much
  • 4 Answers
I can fix it for you
sekcov@yahoo.com
Posted on Nov 15, 2008
I have a mag innovation flat screen computer monitor but I need the power cord for the monitor it is a LT717S model # 700P made in 2006
The power lead you need for this monitor is a standard EU 3 pin. you can purchase these from any good electrical or computer store.
The look like the old Kettle plugs if its of any help
Jul 24, 2010 | Mag Innovision LT982s 19" Flat Panel LCD...
LT982s - 2 monitors 2 problems
With the SECOND (usually the RIGHT) mouse-button, click anywhere on your computer's "wallpaper".
Click Properties.
Click Desktop.
Click Identify and watch both screens.
One should display a large '1' and the other a large '2'.
Click 'Extend my Windows Desktop onto this screen".
Again, click Identify.
Apr 23, 2010 | Mag Innovision LT782S 17" Flat Panel LCD...
Power will not come on
Is there a separate ON/OFF "rocker" switch, in addition to the ON/OFF button on the front of the unit?
Have you tried a different power-cable?
If all else fails, take the monitor to a qualified technician, for more trouble-shooting.
Jan 16, 2010 | Mag Innovision LT982s 19" Flat Panel LCD...
Monitor only power's on NO sound and No Picture
check your cable to speaker of your monitor and to the audio output of your pc.
May 20, 2009 | Mag Innovision LT982s 19" Flat Panel LCD...
Mag lt982s no green light no power at all
try testing it in another outlet a known good outlet if it powers on then your outlets bad if it doesnt means a bad cord or bad monitor
Feb 10, 2009 | Mag Innovision LT982s 19" Flat Panel LCD...
Mag Innovision LT982s 19 inch flat screen monitor
Often the plug of the power cord and its mate, the jack in the monitor, would have to conform with the region/country of its intended use. Having said this, then it is possible that your particular version is meant for another country but is likewise sold in your country. A picture of the monitor's connector would help narrowing the selection and possible source/supplier. Pls post if able.
Alternately, you could try viewing the different types here, here or here to get the specific part number or model of the AC cord.
Incidentally, most electronics shops/stores sell a variety of power cords, perhaps a visual check would further assist you.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 02, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
yes the power supply or capacitors are shot. the part u want is from proview technology inc
attn: parts dept.
7373 hunt ave
garden grove,CA 92841
it is the lcd power supply, P/N 860-ALZ-M713W-f
F0742683G
1-800-776-8439 follow prompts....ed
Jul 20, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
Monitor goes blank less than a second after turning on.
Beautiful screen, lasts about for a few minutes, goes black. Power button still green. If I turn it off, and then back on, it works again for a while. Any ideas?
May 11, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
MAG Lt982s
Hi all,
Below is a re-post of my response to similar issues.
...Based on your post/description, I will initially suspect the inverter and/or the CCF Lamps since as you posted "dim screen picture" indicating that the backlight(s) are defective and/or the inverter is not supplying (sufficient) powere to the lamps.
If the unit is relatively new and under warranty, it may be to your advantage to have it replaced or seek the services of their Service Center. Should you want to do a DIY, it would be required that you be familiar with electronic circuitry and components, use of a DVM and a soldering iron and access to a service manual or at least a schematic diagram.
Incidentally, there are known cases where similar issues could be resolved if you try lowering your display properties (resolution and refresh rates) but that would also include the powerlight changing colors.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Dec 11, 2007 | Mag Innovision LT982s 19" Flat Panel LCD...
Mag Monitor LT982s model900p
Hi, Try this link http://www.pchub.com/uph/category/43/LCD-Inverter.html In some instances inverters for other brand/model will also work for your Mag. You just have to match the part number. Good luck and kind regards.
Oct 02, 2007 | Mag Innovision LT982s 19" Flat Panel LCD...
Mag Innovision LT982s 19" Flat Panel LCD Monitor Logo
88 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
