Question about HP PSC 1510 All-In-One InkJet Printer
Paper feed problems hp PSC 1510
I tried to print an email and the printer made rough noise and now it will not print. Paper feeds halfway then gives error message. Sometimes paper feeds crooked, sometimes it comes through with a bent corner, and sometimes it seems to feed very smooth but then stops in the middle. I have checked for paper jams, power cycled printer, checked properties to conrim proper paper settings, power is not to surge protector and everything else on the troubleshooting list. Im lost
    Genius:
  • 2,035 Answers
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Oct 17, 2008
The problem is my printer when on it appear 'the cover is open' and it's pointed to the ink catridge...
Posted on Aug 08, 2009
Printing 5x7 card stock in HP 1510 injet all-in-one printer
You need to set up your printer preferences to accommodate the type and size of paper you wish to use, usually listed under printer/print or page set up.
Invariably, paper is loaded, butted to either left or right of the paper feed, but on the other side of the feed there should be a sliding stop which keeps your paper in place.
If feeding from the top feed, print side towards you, if printing from a tray at the bottom of the printer, print face down.
You can download a user manual from here once you've chosen your model printer:-
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=uk&cc=uk&h_page=hpcom&lang=en&h_client=S-A-R135-1&h_query=+HP+PSC+1510&submit.x=11&submit.y=7
Apr 22, 2010 | HP PSC 1510 All-In-One InkJet Printer
Paper feeds into printer 1/2way, stops, check paper light flashes
Yes, there is a sensor on the right side of the carriage that points down at the paper, you use a Q-tip moist with water and wipe the underside of this sensor, you may need a couple since quite a bit of ink sprays onto this sensor.
Jul 20, 2009 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 1510 All in One paper jams and wil not feed properly.
www.hp.com/support the people at HP have been very helpful to me try this and see what you get
biigg53566@gmail.com
Jan 07, 2009 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 2355 won't feed photo paper
You can't use the photo papers in this kind of printers
Aug 01, 2008 | HP PSC 2355 All-In-One InkJet Printer
Paper feed problem
usb port or printer adapter problem.check both of them.wish success
Jun 04, 2008 | HP Deskjet 2360 InkJet Printer
Paper wont feed
Printer needs a service: Paper feed rollers are dirty and can't pick the paper up
Apr 28, 2008 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 1610 All-in-One paper jam
ur printer paper feeder gears r jammed or misaligned. kindly get ur printer serviced from a good technician.dont worry its a normal problem.wish u success
Mar 11, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
HP PSC1510 Feeds paper half out then stops
Clean the roller that feeds the paper (located at the right side inside the feeding tray).
I did it ,with a cotton pad: first impregnated with water an soap, then only with water to clean the soap and then with a dry pad. I did making the roll to roll printing a page without paper in the try and continuosly presing the cancel/resume button.
Mar 11, 2008 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 1510 printer malfunction
Open the rear cover and clean the roller with clean water. Worked for me.
Mar 05, 2008 | HP PSC 1510 All-In-One InkJet Printer
Paper feed
Keith,
You are going to need to change or try and clean the pick up roller and seperation pad.
Feb 15, 2008 | HP PSC 950 All-In-One InkJet Printer
HP PSC 1510 All-In-One InkJet Printer Logo
1,347 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
