Question about Proview PL926WBi 19" LCD Monitor
Proview monitor fix
Hi, I am going to fix my proview monitor but, is the reason you replaced the 25v capacitors with 35v caps because you thing they ran them to tight on specs. I just want to make sre so I don't burn down something else in monitor.
Thanks Ray
I did it just because the higher voltage caps would give a lower heat dissipation thus leading to a longer life this time around.
Posted on Oct 20, 2008
Nov 21, 2008 - I have a proview 19" LCD TV PA-19DK5. In the last few days when I turn on the tv the picture appears and disappears after 1 sec. audio is fine, when I use my xbox 360 through the component...
Please post the pictures, that will help. Do find any fuse in the inverter circuits, if you do have 5v (for logic) and 12v (for backlights), then may be the power supply is OK but I am not sure that the inverter is using 12vdc since you have some caps rated at 35vdc, Iwould expect the inverter to be using 24vdc for backlights. See some of the pictures I posted here: http://s807.photobucket.com/home/budm/allalbums
Jan 11, 2010 | Proview PL913S 19" Flat Panel LCD Monitor
Proview PL926Wbi
On modern capacitors 2005 or up the capacitors can go bad and not even bulge at the top. I replaced a few in my moms flap panel monitor and found out that there were more that were bad and they didn't show any signs of damage but put your finger on one of those suckers and it burns like a smoking gun.
Apr 10, 2009 | Proview PL926WBi 19" LCD Monitor
Pl916s proview 19 inch flat screen moniter
I managed to solve the same problem by replacing the six 470uf 25v capacitors. I have notice that the old ones has a bulging top.
Feb 07, 2009 | Proview PL916S2 Monitor
Proview 926 wbi monitor
have a look at the board open up the monitor and remove the boards and you have to look for doomed or colored caps, they will be obvious compared to the good flat caps on the board. replacing these will most likely repair your issues.
Oct 28, 2008 | Proview PL926WBi 19" LCD Monitor
Proview PL926WBi 19" LCD Monitor flickering then shuts off
Capacitors are bad. I fixed one. There was 470 uf that was blown.
Go to electronics store and buy 6x470UF 25v. Thats how i fixed mine
Sep 23, 2008 | Proview PL926WBi 19" LCD Monitor
Proview monitor
Proview known to have problems with failing capacitors in the power supply, not too hard to do for a few pounds worth of new caps. and a soldering iron.
Aug 31, 2008 | Proview PT 15.1" LCD Monitor
Need help: ProView 700P Silver LCD Monitor
You do NOT need a driver. Your monitor is broken. The high voltage power supply that provides power to light the CCFL cold cathode fluorescent lights is broken. The most common problem is that the 470uF 25V capacitors on the power supply circuit board are bad. Bad Caps have a swollen and sometimes leaky top. There are 6 capacitors that cost about 50 cents apiece from www.partsexpress.com . Buy high temperature replacement capacitors rated at 105C. If you can't de-solder and resolder have some 14 year old kid do it for you.
Feb 26, 2008 | Computers & Internet
22" LCD monitor PL2230WDB
replace the caps on the psu. c215, c211, c213, c214, c216, c212. they are 470uf 25v. It comes apart very easy and the caps are in a good position for removal.
Jan 09, 2008 | Proview PL576Ws 15.4" Widescreen LCD...
Proview PL716s computer monitor
Bad Inverter. Or a surface mount component on the inverter. Either way it needs to be trouble shot down to the component level or replace the inverter board.
Sep 17, 2007 | Gateway FPD2275W LCD Monitor
Proview PL926WBi 19" LCD Monitor Logo
123 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Pawan Ambastha
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
