Question about Uniden BC72XLT Handheld Scanner
BC245XLT trunk tracker II
Hi I have a BC245XLT trunk tracker II scanner that was bought new about 3 years ago.
I am trying to program it but except for the "manual" key and "scan" key the keyboard is dead.
No new frequencies can be entered.
I'm wondering if there is something locking the frequencies -the scanner works good on the frequencies previous programmed and most not trunk tracking. Like 155.233 or 42.20 They work but I can't remove any or program any. The keyboard is completely shut off except for the manual key.and scan key.
Thanks for any help you can give.
  • 204 Answers
Hello majorhart, I have never owned this model scanner, but by looking at the owners manual I see there is a keylock, which locks the keypad.
If you need a copy of the manual, go here and download.
http://www.uniden.com/pdf/BC245XLTom.pdf
I hope this helps out with what you were looking for,,Mechanc.
Posted on Nov 01, 2008
Radio shack iscan trunking scanner, pro-107
I no longer provide support for any scanners. As a Police Dispatcher I was working when two police officers were ambushed and killed because a person listening to a scanner told the suspects the police were coming. They should be outlawed.
Dec 19, 2011 | Radio Shack Radio Communications
Cannot recieve new Motorla trunking Feq after system upgrade on my Pro 95 scanner. What can I do?? Thanks, Ron
Hi.
They probably went into a digital trunking system. Your Pro-95 will only handle Edacs, Type I and II standard trunking.
Or they changed the trunking voice frequencies and the data (control channel) frequency.
Which system are you trying to listen to? Which city area ??
Feb 09, 2011 | Radio Shack Pro-95 Handheld Scanner
I have got a used bearcat trunk tracker 3 and i am wondering how to unlock the keypad , it has a small key blinking in lower right corner
Take a look at radioreference dot com. Search for similar problems, or join up and post your problem there.
Oct 11, 2010 | Uniden BC245XLT Handheld Scanner
No clue how to program the scanner !!
Your best choice for software is the BuTel program. You can find it on Butel.com, ScannerWorld.com, or RadioReference.com. Once you have it installed you can download and program both conventional and trunked systems directly from RadioReference.com. I have the BCD996XT with Butel and RadioReference, and the combination works great.
Bill B
Apr 20, 2010 | Uniden BCD996T Base Scanner
Trunking no longer works on my BCD996T scanner, Conventional work
Hi Mike,
Try updating the firmware and see if this solves the problem. While I understand that it "worked before", some of the programming software has been updated to work only with the newer firmware. Also, the newer versions of programming software are required when importing systems directly from radio database sites (such as radioreference.com).
If this does not work, try to enter system data by hand rather than importing. If trunking works then, it sounds like a software problem with your programming software versus the radio itself.
Hope this helps!
Feb 13, 2010 | Uniden BCD996T Base Scanner
Why won't Minolta film Scanner work with iMac and OSX 10.6.2?
Hi
I bought a secondhand, nearly new Minolta Dimage Scan Elite 5400 a few years ago but never tried to use it until now when I tried to get it to work with my iMac running OSX 10.6.2. I uploaded the Dimage software but I cannot get it to recognise the scanner - any suggestions? Do I need to get updated drivers?
Feb 02, 2010 | Konica Minolta Dimage Scan Elite 5400 II...
Unit (Pro 95) will not scan trunk tracker stations at all. I have programmed this radio many times previously and it seems that the programming ROMs are misbehaving. The radio works fine in all modes...
go to page 23 of the manual (at "http://support.radioshack.com/manuals/ome20-525.pdf" if you don't have it) it has some cures that you can try there. good luck!
Feb 02, 2009 | Radio Shack Pro-95 Handheld Scanner
Happy new year
find someone with a TECH II scanner , in the body control module bi directional controls he could open the trunk , another option call a locksmith , another option , verify in the owners manual if you have a lever or a button in the glove box , i totally don't know on that one , or emergency you could jump #16 lt blue wire at body module to open trunk , maybe you have a second key fob ? i'm out of options ...
Jan 02, 2009 | 2004 Chevrolet Malibu
Programming
If its just a normal frequency then select Hold/Resume and press the arrow keys until you find the selected channel, then program in the frequency for example 130.000 you have to make sure the decimal point goes in with the frequency then press (E) then press the arrow key up to go to the next channel and program and repeat steps.
Then select scan you may need to activate the banks so when scanning just press 1,2,3,4,5 so next to the bank icon all 5 should be up.
Cheers Shane
www.rochedalescan.com
Feb 24, 2008 | Uniden BCT8 Base Scanner
Programming Motorola type II system
The BR330T is an analog only scanner. Prince William County's system is 800 MHz digital, which your scanner cannot receive. You can receive the fire department simulcast of "5A" (their fire dispatch channel) on 154.325 in analog mode.
Dec 28, 2006 | Uniden BR330T Handheld Scanner
Uniden BC72XLT Handheld Scanner Logo
298 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
