Question about Husqvarna Viking 1
Machine won't go into reverse
When reverse is selected, the arrow on the screen indicates reverse but the machine continues to operate in the forward direction. Any ideas on what could be wrong?
  • 201 Answers
What model machine are we talking about here? If it is a Designer 1, Reverse doesn't show up on the screen. You need to hit the Reverse button twice in succession, the button stays lit up, and the machine should sew in reverse until you hit Reverse again or change stitch.
When a reverse arrow shows on the screen, it is usually when a programmable stitch is selected and you need to hit Reverse to complete the programmed task.
Get back with more detail on your machine and the problem, and maybe I can offer some more specific help.
Pamsquilt
Posted on Oct 19, 2008
Kenmore 385.1500 sews only in reverse. it is stuck in reverse sewing.
The reverse mechanism lube us going bad. It is accessed from under the machine under the free arm. Usually indicates that the machine is due for a service and oiling. It shouldn't be a problem to get it done at a good sewing machine dealer/store.
Nov 15, 2016 | Kenmore Sewing Machines
Machine will only sew in reverse
You wrote,
"Machine will only sew in reverse - Sewing Machines" A: I'm just a tinkerer, hobbyist, who did run across this same problem before. I can give a general non-model specific remedy based on my limited experience with mechanical sewing machines that get locked into sewing backwards, that is "they only want to sew in Reverse":
1. Verify what is the normal direction of the fly wheel in forward sewing for your machine. Most sewing machines, including Singers, always sew with the top of the flywheel moving toward the operator, regardless if sewing forward or backwards; but older friction-wheel White Rotary (RF) sewing machines, have the flywheel running in the opposite direction (top of Hand-Wheel turning away from the operator when sewing.
2. If it has Reverse Lever/Switch; check that it is in the correct position; if still only sews in reverse, change positions of the Direction Control lever (or Button, etc.), and see if it changes direction to correct the problem.
3. If this does not help, then jiggle the Reverse Lever and follow the linkage inside the machine and see if there is anything broken, loose or out of adjustment. Some machines have reverse control linkage elbows in the top part of machine, and by poor design are prone to accidentally pop backwards, causing sewing in the opposite direction of the position of the Reverse Lever/Button (Backwards when you want to sew Forward). On occasion, a Kenmore 158.1787180 got locked into the backwards sewing mode (the dog-gone' est thing), but by following and analyzing the linkage, I found where it was going wrong, and popped the indecisive linkage elbow back the way it was supposed to be and fixed it. [ I had more detailed notes, on this fix, but when I read them, without the machine in front of me, made no sense to me today so I can't share that till I revisit the conundrum again.]
4. If all else fails, you may be able to hold or clamp the Reverse Lever/Button in the Reverse position, so it sews Forward (I've done this before too (as a short-term fix) until I figured out how to adjust it back the way it was supposed to be.
5. If this post helped you, don't be afraid to indicate so, so Fixya will know. If it was useless, "ouch", but I'd like to know that too, so I'll be more selective on what I really know more about. I try to help, though this is probably a trade secret that anyone who knows is discrete about who they share the information with.
Sincerely
-- Amender. (2016 FEB 24)
Feb 06, 2016 | Sewing Machines
Brand new Singer 4423 won't go in reverse ?
Your reverse lever may have become disconnected inside the machine. Return it to the dealer if you don't want to fix it yourself.
Jul 29, 2013 | Singer 4423 Sewing Machine
Won't sew in forward just reverse
the machine needs to be serviced
May 19, 2012 | Singer 7422
My Sears Kenmore Model #385.17822 will not reverse...
the machine may need to be checked at a sewing machine shop to find out why the reverse is not working.
Apr 15, 2012 | Kenmore Sewing Machines
Sewing machine wont stitch in reverse, needle hitting bobbin feed.
since the needle is hitting the bobbin feed it has to be replaced, if the machine continues to hit the bobbin feed the most likely the machine is out of time & has to be retimed at a sewing machine repair shop
they would also be able to see why the machine won't stitch in reverse
Mar 31, 2012 | Brother XR-65t Mechanical Sewing Machine
Won't operate. Won't go forward or in reverse, happened all of the sudden. Hand crank fine, but the whirring sound comes from that area.
it's possible that something in the machine has come loose or broken
it would have to be serviced at a sewing machine shop
Sep 23, 2011 | Husqvarna Prelude 370 Sewing Machine
Janome Excel 5124 reverse lever
If you pull the bottom off the machine (half a dozen screws) there is a cam on the main drive shaft. The cam is probably jammed in the reverse position due to lack of lubrication on the shaft. You can move the cam back manually and it will operate in forward direction. It appears that the shaft needs lubrication.
Feb 27, 2009 | Janome D'cor Excel Pro 5124 Mechanical...
Bernina Activa 131: buttonhole problem
There are TWO buttons on the machine that have the little u-turn on them. Look for the other one. That is the one that makes the second half of the buttonhole. Look in the owner's manual, it may tell you where it is on your machine. I spent a long time swearing at my machine before I figured out that the reverse is not the only button with the u-turn arrow. The manual is not clear on this. Why they use the same symbol twice is beyond me. Mine is on the front of the machine, down by the needle. Hope this helps.
Feb 28, 2008 | Bernina Activa 130
Sewing Machines Logo
605 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
