We have the Canon BP37-DTS Bubblejet calculator and it shows a E in the left hand side of the display and doesn't allow you to enter anything
#324 chak printer alram cameing
when you power on your fax machine and display show DATA ERROR its mean that 3 volts battery on the main board expired and lose all data fax number, logo and related with cartridge ink data so first of all you replace the battery. (this is a pure technical job and if your are not a technician you must take help of a technician)
After replacement of battery you power on fax machine and press
function key display show DATA REGISTRATION
press # display show #1SSSW
press left arrow key one time display show TEST MODE
press start/copy key display show TEST MODE [1]-[8]
press # display show AMI MODE
Press 7 display show FACULTY 1-6
press 5 display show INK CHECK 1-2
press 2 and start key
display show INK=YES and INS (ink level any one within 100 for example 42/205 you just remember first two digit of lest side)
press stop display show FACULTY 1-6
press 6 display show LOST INK CHECK
press start/copy key display show LOST INK CHECK [1]-[2]
press 2 display show SET LOST CNT
press start/copy key display show LOST INK= (here you enter the last left side two digit which you remember for example 42)
press stop two times
and unplug fax and plug again now your fax machine is okkkkk
NOTE:- If you can't get the success first time you must try until you get the success because this is the only way to get success
Jun 11, 2012 | Canon FAX-L250
Canon_fax_b820_error_342
Do the following procedure 1. Press the buttons in the order of [FUNCTION]- [*] - [5]. 2. [TIME SET HH:MM] is displayed. 3. Current time is displayed following the date [12/12/12 xx.xx]. 4. Press the [START/COPY] button. 5. [DATA SET] is displayed. 6. [CS PRESCAN] is displayed. 7. [INK DETECTOR] is displayed. 8. [PRESS START/COPY] is displayed. 9. Press the [START/COPY] button. 10. [ # TST START:STBY] is displayed. 11. Press the [START/COPY] button. 12. [Please Wait] is displayed. 13. The machine enters the standby mode. 14. Press the [FUNCTION] button and then [#] button to enter the service mode. Execute [All Clear]. 15. [Please Wait] is displayed. 16. The machine enters the standby mode. 17. [LANGUAGE] is displayed. 18. Press the [START/COPY] button. 19. Select the language. 20. Press the [START/COPY] button. 21. [DATA ENTRY OK] is displayed. 22. [COUNTRY SELECT] is displayed. 22. Press the [START/COPY] button. 24. Select the country. (If country of your choice does not appear, turn the machine OFF and then ON. Press the [FUNCTION] button and then [#] button to enter the service mode. Select the country from the [Type Setting].) 25. Press the [START/COPY] button. 26. [DATA ENTRY OK] is displayed. 27. The machine enters the standby mode. 28. Press the [FUNCTION] button to set the date and time. If your problem not solved replace the SCNT PCB
May 01, 2011 | Canon FAX-B820 Plain Paper Bubblejet
Mi da errore ##331 .... dopo aver cambiato le cartucce . prima mi dava errore ##342 ... e non mi prende la carta . ho il fax canon b 140 AIUTATEMI Grazie mille
Do the following procedure 1. Press the buttons in the order of [FUNCTION]- [*] - [5]. 2. [TIME SET HH:MM] is displayed. 3. Current time is displayed following the date [12/12/12 xx.xx]. 4. Press the [START/COPY] button. 5. [DATA SET] is displayed. 6. [CS PRESCAN] is displayed. 7. [INK DETECTOR] is displayed. 8. [PRESS START/COPY] is displayed. 9. Press the [START/COPY] button. 10. [ # TST START:STBY] is displayed. 11. Press the [START/COPY] button. 12. [Please Wait] is displayed. 13. The machine enters the standby mode. 14. Press the [FUNCTION] button and then [#] button to enter the service mode. Execute [All Clear]. 15. [Please Wait] is displayed. 16. The machine enters the standby mode. 17. [LANGUAGE] is displayed. 18. Press the [START/COPY] button. 19. Select the language. 20. Press the [START/COPY] button. 21. [DATA ENTRY OK] is displayed. 22. [COUNTRY SELECT] is displayed. 22. Press the [START/COPY] button. 24. Select the country. (If country of your choice does not appear, turn the machine OFF and then ON. Press the [FUNCTION] button and then [#] button to enter the service mode. Select the country from the [Type Setting].) 25. Press the [START/COPY] button. 26. [DATA ENTRY OK] is displayed. 27. The machine enters the standby mode. 28. Press the [FUNCTION] button to set the date and time. If problem not solved replace SCNT PCB.
May 01, 2011 | Canon FAX-B840 Plain Paper Bubblejet
Can't find a manual online. What does 5/4 mean, and how do I turn it off? Same for E. My biggest problem is that when I add up numbers with the print function on (for depositing large batches of...
The manual for the Canon P1-DHV is online at http://www.usa.canon.com/app/pdf/calculator/P1-DHV_G_USA_HWB.pdf>.
When the display shows "5/4", the calculator is doing 5/4 rounding which means: 5 or above round up, 4 or below round down. To control rounding press the "5/4" key.
When the display shows "E" the calculator could not complete a calculation. It can be because of dividing by 0, or because the total exceeded 1 trillion, or because the operator entered calculations faster than the calculator could complete them. Press the CI/C key to clear it.
I can't explain why you are not getting a total on the tape. Try the following example from the manual exactly as shown, and let me know if your tape shows the total.
  1. Clear the calculator (press [CI/C])
  2. Choose 5/4 rounding (press [5/4] until "5/4" displays)
  3. Choose add mode (press [DEC] until "A" displays)
  4. Choose cost-sell-margin mode (press [B-T] until "B" displays)
  5. Turn printer on (press [PRINT] until "PRINT" displays)
  6. To calculate: $12.55 + $15.75 - $5.30
  7. Key in: 1255 [+] 1575 [-] 530 [=]
  8. Tape shows: [0. C] ... [12.55 +] ... [15.75 -] ... [5.30 =] ... [23.00 *]
Apr 07, 2011 | Office Equipment & Supplies
What value to set in set ink cnt?
At MaybeNow online guides are always there to provide technical support to troubleshoot Canon FAX-B840 Plain Paper Bubblejet Problems which is free of cost. You can also get Canon FAX-B840 Plain Paper Bubblejet, Fax Machines Help from archived solutions related to repair, maintenance, upgrades and installation problems.
Dec 30, 2010 | Canon FAX-B840 Plain Paper Bubblejet
How do I change the company name that's displayed on the top of the page of a fax??? It's a Canon Faxphone B740.
On the right hand key pad
1). Press Function
2). Press 01 (data registration
3). Press set twice
Display the tel number, change if that is wrong
4). Press set twice again
Enter the company name (unit name)
Use the numeric keys-max 24 characters
if you have otehr problem, please to to the following link and download the users manual.
http://www.usa.canon.com/cpr/pdf/Manuals/B740CanonUserManual3-13.pdf
May 22, 2009 | Canon FAXPHONE B740 Plain Paper Bubblejet
Texas Instrument TI-83 Plus error message ERR:MEMORY and the number keys won't work
Hit the "2nd" button in the upper left hand corner of the keypad, and then the "+" button (lower right hand corner). Then either click the down arrow once and then "enter" or just hit the "2" button. (the selection should say "2: Mem Mgmt/Del...") Hit Enter again (selecting the "1: All..." selection) Scroll through the programs on her calculator and either hit the "Del" button (upper right hand corner of the keypad) to delete the programs/variables, or hit "ENTER" to archive them. The archived programs have an asterisk, " * ", in front of them. (Note: Once you delete the programs, you CAN NOT get them back) If you have variables on there "L1" "A" etc. you can delete them and use them again later, obviously.
You can bypass this whole thing and just do "2nd" "+" "7". This combination will reset the calculator and delete any programs that are unimportant to the calculator. You will be left with the "Finance..." option in the APPS menu only...nothing else. You should be able to clear up the problem either way.
Apr 26, 2009 | Office Equipment & Supplies
Scanner feed hangup
NEEDS A SEPARATION PAD AND A BUSHING.IT IS NOT A EASY FIX
Feb 11, 2009 | Canon FAXPHONE B640 Plain Paper Bubblejet
Will not print anything. Full cartridge.
Remove the cartridge and clean your contacts with isoprophyl alcohol. A cue tip may work best for this. Allow to dry. Make certain the cartridge is secured properly and the locking latch is down.
Sep 25, 2008 | Canon FAXPHONE B640 Plain Paper Bubblejet
How do I use the Cost/Sell/Margin function on my Canon P100-DH 2 desktop printing calculator? Please for the love of god help me.
Cost/Sell / Margin can be very confusing it uses the following Account formulas (For Cost = Selling price - ( Selling price / Markup) For Sell = Selling Price =Cost / (1-Margin%))
It is not a pure percentage. Please respond back if you have any other questions.
Apr 22, 2008 | Office Equipment & Supplies
135 people viewed this question
k24674
