Question about Memorex MMP8565 MP3 Player
Freezing when insert headphones
I have never used this and it is 8 months old...i thought i might give it a try and it works but when i plug in the head phone my screen freezes and i can't seem to find where the firmware updates are...its making me really mad!
Mine is not working totally tired of all this ****..if i knew all of this **** was THIS BIG..I WOULDNT HAVE BOUGHT IT!!!! THIEFS!!!!
Posted on Oct 26, 2008
The Sound has stopped working on my telly
if you have sound from the headphone jack the sound circuit is good--audio headphone jack when inserted cuts off internal speakers--it could be 3 days old and have a problem with the jack.
Jun 07, 2012 | Televison & Video
Four weeks ago I bought an iPod Touch 32GB. After listening to my iPod on an external speaker I tried using the headphone and the sound is just too low. I thought my headphone was damaged but I tried it on...
Sounds like plugging the external speakers in has damage the spot were the headphones go in. If this is under warranty that bring it to apple store.
Jan 19, 2011 | Apple iPod touch
Casio Privia PX-130, 8 months old: fluttering sound
If I were to venture an educated guess I would vote for failing filter caps in the power supply.
The power is likely collapsing under load of the speakers but headphones take much less drive.
If this has an external wall-wart power supply, you might try a new one IF the output is found to be under the rated voltage.
Internal power supply components are beyond those individuals that are not adept at electronics.
Jul 13, 2010 | Casio Music
BR 8 headphone jack
This may also sound stupid but; have you tried a different set of headphones? If you have never used the headphone jack there might be a chance that the contacts inside the jack are dirty from airborn pollutants such as cigarette smoke or cooking smoke. Another good example is if you have a flute or silverware laying around in the open , they will tarnish from the sulfur dioxide in the air. Try spraying a very small squirt of contact cleaner on a stereo plug and plugging and unplugging it into the jack. Make sure you do this with the power turned off. If that doesn't work, do it to the jack itself. Only use a very small amount. If that doesn't work you may have a bad solder joint in the connections to the jack or a circuitry problem. The jacks sometimes a have a built in switching circuit to defeat the signal when phones are plugged in and sometimes the jack fails. Hope this gives you some ideas.
Oct 30, 2009 | Boss Micro BR Digital Recorder
You may be able to take the back of the speaker can off the speaker plate on that side to rewire the headphones. You have to carefully remove the earpad and look for screws holding them together. Make note of which color wire connects to what at the solder connection. Cut your cord shorter and cut back the insulation. Test for continuity from the plug to the newly exposed wires with a volt ohm meter. You should be able to get the old piece of cord out of the grommet in the headphones to insert the working cord. Hope this helps.
Jul 04, 2009 | Bose on-ear TriPort Headphones
Motorola S9 headset won't charge batteries
This might work if you aren't using the ORIGINAL charger. I had this problem when my cat chewed through the original Motorola charger. I figured my Blackberry charger would work fine, but it didn't. I then discovered that my Blackberry charger was 700mAH and the broken charger was only 550mAH. When I found another charger with the proper power it charged. I also found that it worked when plugging it into my computer with a standard mini USB. I hope this helps.
Jun 03, 2009 | Motorola Mobility S9 Headphones
Lg cookie freezes when memory card inserted
hi format your memory card through the phone it will set it to your phones settings.
Mar 30, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Apple i touch 8 gb speaker not working
maybe u have the 1st gen itouch. the 1st gen itouch doesnt havent speakers. Your friend probably have 2sec gen which has speakers. If u look at each other's itouch carefully, u'll notice a slight difference near the edges. your friend's itouch's edge is probably curved like in the 2sec gen one while urs probably isnt.
This answer is my best shot at helping ya. Good Luck!
Jan 09, 2009 | Olympus Camedia D-425 / C-170 Digital...
Plantronics Bluetooth Headset P590
This is a "known issue" that I have raised to Plantronics. Whether they do anything about it, remains to be seen. The workaround I have discovered seems to work with both of my P590 headphones that stopped charging:
1. Plug in the USB charging cable to a laptop or computer that is powered on.
2. Connect the USB charging cable to the headphones
3. Connect the 3.5mm headphone cord cable to the headphone output on the laptop of computer (this is the long cable with the normal 3.5mm stereo plug at each end)
4. Plug the other end of the 3.5mm cable into the P590 input.
The headphones should start charging.
Carlos (New Zealand)
Jan 28, 2008 | Radio Communications
No Sound in any mode
I had the same problem... but I knew that my 2 yr old had been playing with the headphone jack on the BC-150. Evidently, the system thought that headphones were still plugged in to the port on the front right of the unit, even though none were present. The solution that worked for me was to take some headphones, plug them COMPLETELY into the system (another set of headphones would not insert all the way, so I found a new set and used those to completely insert into the headphone port) while playing a CD and listen for a few seconds and then simply unplug them. Viola! Sound came back. Hope this helps.
Dec 24, 2007 | Sony DAV-BC150 System
Memorex MMP8565 MP3 Player Logo
Top Memorex Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
