Question about Refrigerators
Amana TC18HL Refridgerator (20 years old)
My Amana TC18HL Refridgerator makes a mild sloosh/warble/ocillating droning sound when the (compressor is) running. It still cools fine, but it seems like a new noise. (It could be freon migration with a low charge?) The unit very occasionally makes one loud bang (hammer-like) noise, but has done so for ~15 years without harm.
  • 33 Answers
SOURCE: Kenmore frig will not cool
if compressor is hot that means comp- is trying to start but the relay /overload is bad allow comp to cool down unplug from wall and replace with exact type 1/2hp 1/4hp 1/3hp etc make sure all wireing is correct and unplug before starting that model may or may not have a run or start capacitor replace it also..
Posted on Jan 01, 2008
leorcid
  • 281 Answers
SOURCE: noisy refrigerator compressor (?)
This is a compressor problem, and chances are there for this to worsen if not attended promptly.
Posted on Feb 06, 2008
22yooper
  • 828 Answers
SOURCE: compressor making a loud noise, freezer cannot cool
It sounds to me like the internal relief valve is lifting due to discharge pressure being to high such as it a system that is over charged with refrigerant. Have the system tested for pressures on high and low sides. If someone has serviced this unit recently there may be to much of a charge in the system. Also check the name place for the proper refrigerant and charge .
Posted on May 19, 2008
  • 1462 Answers
SOURCE: Loud buzzing noise from inside Jenn Air 2389G fridge
i don't know jennair specifically being from england.
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
Posted on Jun 25, 2008
SOURCE: Amana Mod # ABB2223DEB Refrigerator
I found this problem addressed on applianceblog.com and per they recomended part # 67006166. My repairman ordered this part and it had been superseeded by an even newer version, # 10127429. He installed that newest version in late June 2008 and it has been great ever since. So for me # 10127429 was the answer. Hope this helps
Posted on Dec 03, 2008
Computer board went out. when you remove the computer it has a black mark behind it on the plastic housing. how long is the warranty on the comperssor of this refridgerator?
the compressor usually has 5 year warranty in fact the sealed sytem itself which includes the compressor .evap coil and usually the condenser coil has 5 years... the boards usually only have a 1 year parts warranty or up to a 5 year parts warranty but after the 1st year you are responsible for the labor on the board....the compressor though should be covered through amana for 5 years total cost... good luck to you....
Feb 16, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Amana 20 - 20 years old. Freezer thawing - refreezing. Fan running very hot in the compressor arae at the bottom. Drip pan full of water - never saw that before.
IT SOUNDS LIKE YOU HAVE DEFINITE ISSUE WITH YOUR COMPRESSOR, IT MAY BE CONSTANTLY RUNNING OR RUNNING TOO OFTEN, THIS WOULD CAUSE THE LARGE AMOUNT OF HEAT COMING FORM THE BOTTOM. IF YOUR COMPRESSOR IS RUNNING TOO MUCH YOU WILL ALSO GET AN EXCESS AMOUNT OF WATER EVAPORATING DUE TO CONDENSATION ON THE EVAPORATOR COILS THEREFORE FILLING UP YOUR DRAIN PAN THAT MUCH QUICKER. YOUR FRIDGES COMPRESSOR MAY BE ON THE WAY OUT BUT YOUR FRIDGE SOUNDS LIKE IT'S WORKING THE WAY IT SHOULD BE.HOPE THIS HELPS
THANKS
Oct 12, 2009 | Amana Freezers
Amana refridgerator mdl abl2222fes knock noise
sounds like the compressor vibration dampers are wearing out. the dampers are the rubber washers that seperate the compressor from the chassis of the fridge. when they start to deteriorate, and the compressor kicks on, it will bounce against something in the chassis, causing a knocking noise.
Jan 22, 2009 | Amana ABL2222FES Stainless Steel Bottom...
Not cooling/freezing THERMADOR SIDE BY SIDE REFRIDGERATOR BUILT IN
Sounds like thatyou refrigerator has leaked out the refrigerant. If you have a condenser i.e. cage on the back , place your hand over it and see if it is warm if it is not then if deffinaltey the gas.
this is not a diy job and you will need an engineer with relevant qualifications..
hope this helps
cheers wash doctor
Aug 25, 2008 | Refrigerators
I have an Amana bottom freezer fridge model ARB2517CSR the freezer stopped working I cleaned the coils and the fan was working and the fridge was making a buzzing sound. The sound stopped, so did the...
If the coils were really dirty, the compressor is probably just overheated. Let it cool down overnight then try again. If it still won't stay running it needs serviced. Could be the start relay or internal overload/overheat sensor in the compressor. If the coils were really dirty and it was used like this for a long time, the compressor could be damaged. It is almost never worth replacing a compressor in a home refrigerator.
Jul 03, 2008 | Stainless Cruise 49 Marine Refridgerator -...
REfridgerator Failure
Refridgerator is 5 years old. Simply went out of cooling and freezing. Still makes operating sounds and lights work but losing our freezer full of food is disturbing on a refer only 5 years old.What could be wrong?
Mar 17, 2008 | Jenn-Air JCD2389G Side by Side...
Amana 8 yr old side-by-side refridgerator/freezer
sound like you said a sealed system problem if compressor is running check the black coil under ref by the fan and see if it is warm if not you have lost freon just trash it then if it is see if fan in freezer is running if so pull back cover in freezer and see if coil starts to freeze if you have a ice block on coil then it is a defrost problem good luck
Dec 04, 2007 | Amana AFD2535DES French Door Refrigerator
How to troubleshoot amana refridgerator
the evap fan, fan by compressor and the compressor should all be running. if they are then more than likely a bad compressor, so junk it
Oct 30, 2007 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
202 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
