Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
HOOVER FLOOR MATE WILL NOT SUCTION WATER
THE FLOORMATE OPERATES WITH A SQUEAL AND WILL NOT SUCTION THE WATER BACK OFF THE FLOOR. DO I NEED TO CHANGE A BELT OR SOMETHING TO GET IT TO WORK PROPERLY AGAIN?
    Problem Solver:
  • 6 Answers
The squeegee needs to be replaced. Mine made a horrible noise, which I found I could fix by trimming the worn edge of the squeegee. This, of course, reduced the suction. I found a replacement part on Ebay, but you can also find them on Hoover.com
Posted on Sep 04, 2010
    Problem Solver:
  • 10 Answers
There are no belts. If it makes the noise with the brush assembly removed the motor drive assembly is bad. It ia a complete assembly that can easily be replace by a repairman or ypouself if you are cleaver with tools. Good luck.
Kirk Thompson
San Juan, PR
Posted on Oct 29, 2008
How do I Replace reservoir and tubing assembly on a hoover floor mate?
Hello, this is Ava with Think Crucial.
You may check the online manual for Hoover Floormate in this link: Hoover FloorMATE Hard Floor Cleaner Owner Manual Also, you may call Hoover for assistance which is 800-944-9200
You can order replacement filters for your Hoover Floormate directly to us. You can check the filters in this link: http://www.thinkcrucial.com/search?type=product&q=hoover+floormate
As a special offer here is an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Think Crucial Customer Care
Oct 13, 2016 | Hoover Vacuums
Hoover floor mate h3000 will not suction water from floor when cleaning
Your collection canister may not be positioned tight enough in its place ment site. Tip machine back using foot pedal (as if you were going tio start using machine to clean) Insert collection canister (bottom container, then insert top canister with solution. The two canisters must be flush with machine side seams and must sit in position tightly. This is sometimes very tricky and may take a little elbow grease to make it click into place. Hope this helps
Jul 08, 2015 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover floor mate sucks up water while in the wash position
They do that. They pickup the water in all stages but lower the squeegee to different heights. At no point does the suction turn off.
Jan 20, 2013 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover floor mate is not sucking up water, why?
First make sure that you are getting suction from the bottom of the machine. Most of the time the squeegee is worn out which does not allow it to pick up the water like it use to. Turn over the machine and inspect the squeegee. If it looks worn or bent then it may be time to replace it. You may also consider replacing the filter. These are the two most common parts that wear out.
here is a link the parts for your a h3000 floormate
H3000 Parts
http://www.usavacuum.com/category-s/85.htm
Feb 23, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
Floormate stopped vacuming water
I'll answer last question first. Your floormate has a 1 year warranty. And should be taken in for repair.
Your issue of not picking up water, is related to suction and getting the dirty water to the recovery tank. check for obstruction in the nozzle, check the filter for debris clogging. If you have an issue with this dealer I would call customer support.
Sep 26, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Our Hoover floor mate won't **** up the water. Motor runs but pick up is limited.
you will need to replace the squeege that is located on the nozzle. 3 screws will take it off. you can get this at a vac shop or order it from the company, filter may also need to be changed
Jul 18, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Troubleshoot floormate spinscrub 800 floor cleaner
The brushes are not designed to scub the floor, they only lightly touch the floor. Make sure the front nozzle is put on correcdtly. Make sure your filter is dry and clean. I wet filter will give poor suction down to the nozzel. Down load the manuel at Hoover.com. The model is located on the back of the unit. H3000, or H3010
May 24, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Floor mate
There is a little post in the back where you insert the top solution/water tank, if you put the tank in incorrectly, (i.e., shoved it in, instead of putting it in at an angle, bottom first) there is a chance you broke it or bent it backwards. My mother broke mine, i've got the post but don't know the part, without that post inserted into the tank the water will not come out.
Nov 06, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
I have misplaced my instructions and need to use it today
Thank You, but after I sent the FixYa mail yesterday, I finally found my instruction book.
I am not interested in a repair program at this time.
Diner
Aug 27, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
I just bought a hoover floor mate for hard floors. The problem is the water with cleaner is not coming down to the brissles at all. Help please. It is brand new. any ideas???
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40471&thid=603805
I just bought a Hoover
Posted by serdmann4 on May 17, 2008
I just bought a Hoover floor mate for hard floors. The problem is the water with cleaner is not coming down to the bristles at all. Help please. It is brand new. Any ideas???
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Floormate H3000 Upright Wet/Dry Vacuum. You can down load the owner manual from the Hoover website www.hoover.com . It looks like the one of the holding or recovery tanks my not be in place, leaking, cracked or damaged, or the clear tube is leaking and needs replacing. I looked 2 the owner’s manual and it does not show the clear tube but the vacuum does come apart and just back track the clear tube and mark the screws when you disassemble the unit. Other wise , please call the factory or a local Hoover warranty station in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 17, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
216 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Mike Cairns
Mike Cairns
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
