Question about Panasonic Lumix DMC-TZ1 Digital Camera
Message - "Please turn off camera and turn on again"
I recently (May 2006) bought Panasonic DMC TZ1 from Beach Camera. When i turn on the camera in the macro mode, normal picture mode,simple mode or in scenery1 and scenry2 mode, after 17 seconds the screen shows a message that says "Please turn off camera and turn on again", and then just hangs up. This message does not appear if the camera is in movie mode and functions normally. Please tell how I can solve this issue. I am currently travelling and had bought this camera with great hopes for this trip. Please reply soon.
  • sashawilby Nov 26, 2007
    i have the dmc-fx01 and the camera displays turn the camera off and on again i am unable to use the camera at all
  • SamuraiZ Mar 11, 2008
    I had the lumix DMC TZ1 for about an year now... I went for a trip, and after taking few shots, the camera displays the message "please turn off camera and turn on again" . when i do so, the camera simply zooms out to the max, and stays stuck for a few seconds, and then displays the same message again... I tried cleaning the lens... but that didnt work out... help please...
  • 53 Answers
If you need parts you can get good used parts from a guy in South Carolina. I got a used LCD for $49.00 plus shipping and it works great. I think his email is gerald.ray@aa-ark.com
Posted on Mar 12, 2008
Take out the memori card for istage!
Posted on Sep 01, 2007
No seriously im fixing to buy one at ebay with same problem came here and signed on as a tech since i have electronic and computer degrees and been fixing things since 1974. first u do need very small tools to get into the cameras.. try to find some small phillips and straight screw drivers. just try to get the back cover off. next as somebody mention look for that orange thin ribbon cable and wiggle it slightly and see if it falls out of its socket...to put it back in u need to study the socket it has a latch that flips up or pulls out..do this gently with a small staight driver. insert the rippon as far down as u can get it and close the latch it the rippon should be firm now...if u cant find a ribbon loose ..u might have to loose the lcd screen completely and look for loose ribbons or cables unpluged ..also look through a pair of reading glasses at the circuit board for cracks. then if nothing take the whole main board out enough to look over the other side with bright light too. if you find a crack most likely its toast..unless your good at pt-pt wiring. also before u start shake the camera and listen for loose bits. and note anything u find loose inside if lucky its just a piece of plastic ..unlucky would be a surface mount component. if its out warrenty and u dont want to slam dunk it ...sell it on ebay broken and alot buyers like me bid on it. good luck CrazyLarry
Posted on Jun 26, 2007
Take it a basketball court and try a slam dunk it ...that should break it all apart so u dont need any tools at all then try putting it back together with just your fingers and crazy glue. If still shows the error message attach it to the side of the space shuttle on its next orbit. hope Ive been some help CrazyLarry
I've dropped the TZ1 before and sent it in once for under-warranty repair. After a few months of use, the TZ1 could not power on again. So I decided to dismantle it myself and removed the case. I realised that one of the orange cables inside was torn. I'm no technician so I just used some sticky tape to ensure the orange wire contact points fitted well. And then when I reassembled and switched it back on, I got your problem - works fine in review mode but not in any of the shooting modes. I realise that the camera says this because of something to do with the lens' Am going to reopen up and take a look again. I'm sure by now you'd have found a replacement camera (or are you eyeing the latest model TZ3 for this summer?) Still this TZ1 has served me well, especially at concerts/sports stadiums with its zoom. It be a pity to just let it go without putting up a fight!
Posted on Jun 05, 2007
  • 513 Answers
If I were you I would get in touch with panasonic to make sure that the warranty will cover this fault, and get a throw away camera, or a cheap old fashioned one from a second hand store, so that I have something to take pictures with in the meantime. The only things you can do yourself is try to reset the camera - through the menu and also my taking out the batteries for a few minutes and replacing them. It's very strange that it happenes in every mode but video mode. If you try zooming in video mode, do you get the message again? If so it could be an obstruction to the lens, or that the lens has been obstructed and the camera got stuck on this error. If not, then it could be a problem with the card or camera processor, not able to store or process large stills. If you come across a camera shop in your travels, ask to test your camera with a good quality memory card. Maybe that's where your problem is. Another thing I would try is lowering the resolution gradually in the still images settings, try to see if there's a limit after which the problem is solved. Maybe on lower resolution it will work. but don't forget to get your camera fixed within the warranty period. Good luck, and have a good trip!
Posted on Jun 04, 2006
SOURCE:
Memory card error for the Panasonic DMC-TZ1
What type and size memory cards? The DMC-TZ1 works with SD cards 2GB and smaller. It will not work with higher-capacity SDHC cards.
Mar 15, 2013 | Panasonic Lumix DMC-TZ1 Digital Camera
Does the orange panasonic lumix dmc-ts1 go underwater?
Yes, but not very deep. It's specified to be waterproof to three meters (about ten feet). You can use it at the pool or walking/wading along the beach. I wouldn't take one scuba diving.
May 26, 2010 | Panasonic Lumix DMC-TZ1 Digital Camera
Message: Please turn camera off and then on again Have recharged batteries and turned camera on and off many times. This happened after iPhoto download.
k u need trun off u r camera for 10-15 mints and plz remove u r batteries and clean u r batteries with cloth and if prob still so change u r batteries
Oct 28, 2009 | Panasonic Lumix DMC-TZ1 Digital Camera
LUMIX DMC-LS80 SHOWING MESSAGE PLEASE TURN OFF CAMERA AND TURN ON
This fault is usually caused by a lens problem.
Over 95 percent of lens problems are from Knock damaged or sand/grit in mechanism. It will need to be serviced by an experienced technician.
Sep 30, 2009 | Panasonic Lumix DMC-TZ1 Digital Camera
Multiple copies of pictures
Yes may be, there was a same query here;
Check the settings for "Burst Mode" in your Cam, it will be under main settings menu. Turn it off, if the problem prevails better backup all the pics/videos and then Reset the Camera.
If helpfull, kindly do Rank.
Regards,
Waqar
Jul 17, 2009 | Panasonic Lumix DMC-TZ1 Digital Camera
Panasonic tz1
See my answers to others having same problem.
Aug 01, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera mesaage says turn camera off and on tis has no impact also the lens will not retract
hello, i did get also same message and lens did stay out. did put camera in play back mode and in menu did reset everything. now it works again. maybe i was lucky, maybe this is ,,the"solution.
Jack
Jun 18, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
Please turn camera off and then on again after a couple of seconds
Hello friends,
My Panasonic Lumix dig. camera Screen is showing the message that pl. switch off the cametra and on again. when i did the same again I face the same problem. Pl. help me to solve the problem
Apr 24, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
Panasonic Lumix DMC-TZ1 Digital Camera Logo
1,601 people viewed this question
Top Panasonic Cameras Experts
skyblue007
deton8 von Splosion
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
