Question about Canon PIXMA MP180 All-In-One InkJet Printer
Paper jammed have this problem.i press the ok but the dp says still jammed.There is no paper.in it.
  • 57 Answers
Open the top cover as if you were changing cartridge and take a flat screw driver lift up the white plastic paper guide above the metal roller and check if anything's there then check the paper sensor to the right (Usually a black arm) sometimes pieces of paper get lodged there, but if you don't see anything then you''ll need to take the printer cover off then the ink carriage assembly chances are you'll find the problem there.
Goodluck.
Posted on Oct 17, 2008
    Genius:
  • 1,142 Answers
Printer says paper jam on calibration
If you check closely, you may find there is a small piece of paper trapped between the rollers?
Feb 21, 2013 | HP PhotoSmart 7760 InkJet Printer
Cannot clear paper jam
Paper Jams in the Automatic Document Feeder
If you're loading legal-size paper, insert only 10 sheets at a time to prevent paper feeding problems.
If paper jams inside the ADF, clear the jam and reload the paper as follows:
1.
Open the ADF cover and remove any jammed paper.
Caution:
Do not try to remove the paper without opening the ADF cover first, or you could damage the mechanism.
2.
Press OK, then select Yes and press OK to clear any messages on the display screen.
3.
Reload the paper. Make sure the corners of the paper are not bent, folded, or curled up.
Jan 11, 2011 | Epson WorkForce 600 All-In-One InkJet...
DP 3530 error code E04-02
Hello sir; You have to look at heating unit you havv paper jam over there!
Aug 23, 2009 | Panasonic Workio DP-3530 Copier
Copy/Printing machine jams
This tells me your DUPLEXER is the one causing the jam, Ok like when you open the duplexer do you see the paper in their
second does your copier indicae that the duplexer is in stalled ?m print the config page to verify. if it worked ok until this incident then your paper feed tires in your Duplexer is worn and needs to be replaced, do not do this yourself call a Service tech or A dealer to do so, uf your in CT we can help.
Mar 06, 2009 | Panasonic Workio DP-3530 Copier
Please clear paper jam and press ok
hi i josh in cebu phils. may i help you? friend the paper jam means there is something blocked your paper feeder try to clean or check if there is something in there may be a paper pencil clifs etc. try to clean and restart the printer.good luck
Feb 19, 2009 | Office Equipment & Supplies
Paper jams at finisher when making multiple copies. Using 20 lb. paper. Any suggestions? Copier is Panasonic Workio DP-4510 with detached finisher.
first try to eliminate the finisher. turn off main power switch and unplug from the power outlet. Now unplug the finisher cable from the rear of the copier, then slide the finisher out of the way. Check to see if you still are having jamming issues. if not then yes the issue is with the exit of the paper or the finisher.
Many possibilities try to narrow it down.
Good Luck
Sep 27, 2008 | Panasonic Workio DP-4530 Copier
"Clear paper jam" error, but there is no jam!
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-23
Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Open Questions:
See all Canon PIXMA MP180 All-In-One InkJet Printer Questions
Canon PIXMA  MP180 All-In-One InkJet Printer Logo
75 people viewed this question
old marine
old marine
