Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
Port forwarding issue
I have connected a 4 channel DVR Camera system to the westell 327w router. Did the port forwarding inside the router programming, and I am able to view the cameras remotely. But after a while it seems the ports are closing on the router, not allowing me to view the cameras. We have disabled the firewall settings and also replaced the router. We are using a DDNS service where we don't have to have a static IP to view the cameras. Can anyone help with this issue?
  • Anonymous Dec 11, 2008
    Same problem here, except I am using Static IP.
    Router/Modem is Westell 327w with ports 80 & 8000 forwarded.
    Home browser is IE7 with popup blocker off and active-x enabled.
    All done according to instructions, still can't connect at all.
SOURCE: VPN through Westell Versalink 327w
ok use this to goet to you setup
http://dslrouter/
and then use this to open ports but you have to chose the program you want to omp it for
http://www.portforward.com/english/routers/port_forwarding/Westell/Versalink-327W/Versalink-327Windex.htm
Posted on Nov 21, 2007
SOURCE: westell 327w
Your router is for DSL not cable
Posted on May 01, 2008
ayamaya
  • 143 Answers
SOURCE: westell model 327w
you can run another ethernet cable from your westell modem to your laptop. hence, if you want your laptop to connect wirelessly, it must have a wireless card/adapter inside. if it already has a wireless adapter, it should automatically detect your wireless network and you just need to connect to it (note: you need to enter the correct wireless security/network key if you have enabled it on your modem). by default the serial number is the ssid of the router and the wireless security is disabled. but if you are not sure of your wireless security, log on to the modem's web user interface by typing http://192.168.1.1 on your web browser's address. then go to the wireless section and verify your wireless settings from there.
hope this'll help you.
ciao!
Posted on Aug 20, 2008
rahul26485
  • 611 Answers
SOURCE: My Xbox 360 Nat is Strict. with my Belkin
again give it then save it then reboot it the router then try it
Posted on Jul 29, 2009
mbase213
  • 728 Answers
SOURCE: I need an IP address for my Westell 327W router.
Hi froggysmz321,
The best way to determine your IP address is to click start run and enter cmd then at the dos prompt enter ipconfig /all which will bring up all the IP address associated with that machine. The IP that your looking for is called the Gateway. Next to that is your routers IP.
Good Luck,
And don't forget to leave a rating.
Thanks
Mark
Posted on Oct 07, 2009
Testimonial: "Helpful, but the address there is not taking me anywhere."
I cannot access my internet viewer
More details are required.
The Samsung 'SmartViewer' program starts up on a computer. You can access it whether you have a recorder or not.
The Samsung 4 channel DVR has a menu to set IP address & ports to use and a netjack to connect to internet. You can access the DVR from any computer connected to the same router as the DVR by inserting the same correct info into 'SmartViewer' as in the the DVR.
Once you open the required ports in your router, port forward the router to the DVR, any incoming requests from the internet to view should connect and with the correct password you can view your security cams.
With minor adjustments..that's it.
What didn't you do?
Dec 25, 2012 | Samsung 4 Channel Dvr
I am having trouble with Port Forwarding for the Westell 327W Wireless Router.
Hello Michael Yancy,
Seems to be a bit dated... but the AMATEURS that have these ... like them.
Those trying to set them up... Not-so-much
see the videos at:
How to set up your Echolink Port Configuration
Port Forwarding For Noobs Linksys Routers
eHAM.net has the best forum (important)
http://www.eham.net/ehamforum/smf/index.php?topic=76200.5;wap2
May 20, 2017 | Westell Wirespeed VersaLink...
I have a Westell Versalink 327W with a strict nat and I want to open it up for Xbox Live. I have tried port forwarding but that only bumps it down to moderate not open. What should I do?
PS3 and Xbox ( NON BELKIN)
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is Enabled
May 19, 2010 | Westell Wirespeed VersaLink...
Need to open port 443 on my westell 327w how do i  do it
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on NAT then click on port forwarding .Then allow prot 443 it is for https then save settings and restart router .
Let me know if you need further assistance.
Thanks for using FixYa.
Apr 05, 2010 | Westell Wirespeed VersaLink...
Port foward on a westell 327w
Ok this is an easy one, have a look at this tutorial at the link below it is quite long but easy to follow . http://portforward.com/english/routers/port_forwarding/Westell/Versalink327W/DC++.htm
Feb 10, 2010 | Westell Wirespeed VersaLink...
I have switched to a Westell VersaLink 327W from a older Westell Wirespeed. The Wirespeed communicated via USB and the new Westell communicates via Ethernet. How do I get the computer to see the modem?
If you are using a Westell DSL modem with ethernet connection, then you connect the modem's ethernet port to the computer's network card. This also uses an ethernet cable. Good Luck
Jul 19, 2009 | Westell Wirespeed VersaLink...
Westell 327w channels
Type in http://192.168.1.1 in your browser window, this will take you to the Westell Home Page (your router). There are tabs at the top, select Configuration>Wireless>Basic, this will open a Wireless Operation Window. You will see Channel in the 3rd box down. Click on the arrow to change the channel, then click save at the bottom. Close all windows and X out of the browser.
Oct 18, 2008 | Westell Wirespeed VersaLink...
Hook up westell 327w to linksys router
the wireless won't work. i have the same problem. westell modems aren't compatible with wireless function on some laptops therefore routing signal through a wireless router allows that. it can be done, i've done it but after modem was reset having issues. keep searching it can be done...
thanks for the vague and non-informative answer though whoever that was.
Jan 14, 2008 | Westell Wirespeed VersaLink...
do you have login access into the Modem/Router?
if yes, look for port forwarding and set it to your IP of your computer. open port 500 or what ever is required by MS fro the VPN
Nov 01, 2007 | Westell Wirespeed VersaLink...
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
